3.1 problems still, take 2
Old Feb 1, 2004 | 03:03 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
Ok Heres the whats wrong, Idles bad once its goes into closed loop. Then after a few minutes the check engine light comes on and the idle gets fine again. Im getting code 45, rich exhaust.
Now for what ive fixed/replaced:
IAC
TPS
Coolent temp sensor (for ecm)
Blocked off EGR
o2 sensor
Plugs
Wires
I ran it on a snap-on scanner and came up with nothing wrong, other than the rich exhaust, which isnt even very rich. What could be wrong???
Old Feb 1, 2004 | 04:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
loop mode allways sucks if you ask me. Why when I start my car I hold the R's at 2500-3000 and warm the car up for a min so it drops loop mode. A 3 wire heated O2 would kill loop mode forever.
Why it runs in loop mode, it waiting for the O2 to heat up.
Old Feb 1, 2004 | 04:18 PM
Transmission: autos
my problem happens when the o2 kicks in
Old Feb 3, 2004 | 12:54 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
1. Check ignition coil.
2. Check ignition module.
3. Check timing.
4. Replace dist cap/rotor.
5. Have injectors tested for leaks. Especially the cold start "seventh" injector.
6. Check vacuum lines. Non regulated/metered air entering engine is a bad thing.
7. Check evap (charcoal) can/filter for clogging/other problems. This is one of my problems...
8. Replace plugs with different brand/heat range.
my $ .02...
Old Feb 3, 2004 | 06:51 AM
Transmission: autos
i fixed it, loose wire at air temp connector, and bad air temp sensor
Old Feb 4, 2004 | 01:17 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
As far as i know i have not seen the cold start injector on my 3.1. IT could be because you dont have a EGR my idle was all messed up when my EGR was not working right. Also check for vac leaks. Does it happen more when u step on the brake? Could be EGR related. Or check the hose from your power booster to your engine
Old Feb 4, 2004 | 06:30 AM
Transmission: autos
lol in my other post i said a loose wire and bad air temp sensor, all fixed now
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
