Southern California Area Southern California Members.
Good Cams
Old Feb 1, 2004 | 03:14 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Good Cams
This is for people who are looking for cams to use. Check out the websites http://www.holley.com/HiOctn/ProdLin...CC/Chevy5.html http://www.compcams.com/Technical/Ca...ML/128-169.asp
www.tpis.com
http://www.yearone.com/serverfiles/h...p?hid=G12AI427
https://www.thirdgen.org/newdesign/tech/mods3.shtml
These are good heads also, www.trickflow.com
You can also buy these cams through Summit or Jegs for a cheaper price.
Old Jan 14, 2005 | 08:11 PM
VincentZ28's Avatar
If you're still looking for a cam, I brought this link back from a year ago.
Old Jan 14, 2005 | 08:23 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Old Jan 14, 2005 | 08:37 PM
KiLLJ0Y
Guest
Posts: n/a
I went out and got me an LT4 Hot Cam from SDPC
now to select some heads, and intake.. (still working on the LT1)
Old Jan 15, 2005 | 12:26 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
The LT4 is a very decent cam, I suppose with an LT1 intake is should be more of a perfect match than a Super Ram like my combination. Though of course it would be nice to get an LT4 intake If you think of getting a Super Ram I would check out the LPE cam
Old Jan 15, 2005 | 10:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Take this with a grain of salt, but every Desktop Dyno simulation I've done shows the LT4 HOT cam makes more power across the board versus the LPE219 cam. The HOT cam is also cheaper. Your results may vary.
Old Jan 17, 2005 | 12:23 AM
BrandenCali's Avatar
I would not have a doubt in my Mind that Kevin Knows the lt4hot cam is making more power vs the Lpe219.. Gm put a lot of time and money into the spec of the Lt4hot cam.. I agree on results may vary as, Is there a factor of where it's ground at that could be the possible difference..?
Old Dec 11, 2005 | 11:26 AM
VincentZ28's Avatar
I brought this post back for the people who are looking for cams.
Old Dec 8, 2009 | 11:43 AM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Re: Good Cams
Subscribed.
Old Dec 8, 2009 | 12:05 PM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Re: Good Cams
Originally Posted by drb930
Subscribed.
There hasn't been any action on this thread since 2005....well until you dug it up.
Old Dec 8, 2009 | 12:11 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Re: Good Cams
Nobody does research here, they just trade cams between themselves.
Old Dec 8, 2009 | 06:19 PM
Guest
Guest
Posts: n/a
Re: Good Cams
Well what else is new. Not much new right?
Now the point is which cam is best for the legal combo.
And I guess the vs area of noise is the Ex. factor is a down side? Less Rumble! But it's need.
In my guess with my combo and refrence to the Dyno result is the zz4 cam vortec combo produced the tq. But was in majorly needing the Hp.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
