Fuel injector question
Old Feb 24, 2004 | 08:43 AM
gunfixr's Avatar
Car: 88 camaro
Engine: 2.8 v6
I'm still having idle trouble with my 88 -------2.8 Camaro.
Apart from changing the injectors and calling in a witch doctor , I stumpped.
The car still has a stumble to it idlewise. Plus the exhaust still smells rich.
So far I have replaced or rebuilt the following:
EGR valve
MAF sensor
IAC valve
Oxygen sensor
Fuel pressure regulator
TPS sensor---------adjusted to .54 volts
New wires, cap, rotor , plugs, coil.......
Rebuilt distributor.
Adjusted timing to 12* btdc
CTS sensor.......ad nauseam.............................
I did check the fuel pressure. It was around 42 lbs. However, it did bleed down to 0 after 20 minutes.
Since the fuel injectors and the ECM are about the only things that I haven't changed, I'm starting to think that I might have a leaking injector or one that isn't atomizing correctly.
The only trouble code that I have is a code 32 which I don't think is related to the idle problem since I changed the EGR valve.
Could a leaking or dirty injector cause this motor to stumble at idle? Also, this is not the original motor in the car. I was wondering if the injectors from this motor are causing a conflict with the ECM. Or are all the injectors the same for all 2.8's?
Old Feb 24, 2004 | 09:30 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
2.8's are to have their own injectors (minus fieros)
3.1's have their own
3.4's have their own
That fast of a bleed down, you do have a flaw somewhere. It could be injectors, it could be CTS, it could be in the tank.
In the manual, it tells a way how to check, heres what I rember "quick n dirty style"....
Pull upper intake, pull rail out, but leave lines and everything attached. Hang it from the hood somehow (wire, string, whatever) somewhat low close to engine.
Place paper towels/shop rags below it, , turn key on enough to gain fuel pressure, let it run the pump. Turn key off. Watch the tip of the injectors, if one leaks, it will drip onto the towels.
Old Feb 24, 2004 | 09:32 AM
Dale's Avatar
Engine: 350 S-TPI
BTW, still have cat on the car?
do you have digital EGR, or ufo style? If you have ufo style, they have a vacume control module that you should look into.
Old Feb 24, 2004 | 05:53 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
or you could block the damn egr off and be done with it.
Then live with the egr code FOREVER as i do.
Old Feb 24, 2004 | 06:03 PM
gunfixr's Avatar
Car: 88 camaro
Engine: 2.8 v6
The EGR valve is new. The solenoid is more than likely defective. It's a vacuume style EGR not a digital. I still have a cat hooked up. My idle problem couldn't possibly be EGR related. It has to be an injector acting up. The car is running way too rich judging by the smell of the exhaust and that lovely eye-burning effect that comes with it.
Old Feb 24, 2004 | 10:08 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Only thing you can do is pull the upper plenum off and test the injectors. There are 4 things you can do, but you need a fuel pressure gauge and an injector tester tool for a couple of them.
1- Injector balance test
2- Injector coil load test
3- Injector coil ohm check
4- Injector leak test: You can pull the fuel rail up out of the intake and then turn the key to ON and see if any injectors are leaking.
FYI, the TPI motors are NOTORIOUS for injectors shorting internally. It's not as common on the V6's but it happens.
This tester is sweet but too expensive: http://handsontools.com/store/show_p...roduct_id=1912
This one is cheaper but you can't do coil load tests with it: http://handsontools.com/store/show_p...roduct_id=5339
We have both of these at work and I use them ALL the time on GenII and GenIII 3100's. ALL THE FRIKKIN TIME.
Old Feb 25, 2004 | 12:52 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i had a similar problem. i noticed a bit of a stumble occasionally and it always smelled rich. i also had the problem of it cranking for a long time before it would start if it sat for more than 20 min. it ended up being leaky injectors. when i put in the 3.4 w/ those injectors, problem solved, fires right up, no rich running, no stumble. just my .02 fo ya.
Old Feb 25, 2004 | 01:51 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Here's TomP's favourite test tool sight. Real cheap injector tester.
http://www.sunpro.com/cgi-bin/web_st...d=3610534_5399
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
