will replacing cc carb cause havoc?
Old Mar 1, 2004 | 08:53 PM
twistydick's Avatar
Car: 85 berlinetta
Engine: lg4
hi guys. i gotta 85 camaro with the cc quadrajet that went kablooey.question is, can i replace with a non cc carb (probly temporarily), until i either fix this one or get a new one?was wondering if it would cause the ecm to screw my timing or something??????? thanks in advance. (tried a search, but really couldnt find a straight answer)otherwise, its drive the ford beater till shes fixed.
Old Mar 3, 2004 | 01:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
According to this https://www.thirdgen.org/techbb2/sho...hreadid=217860 , if you do a few things correctly, you can get it to run.
Best route would be to fix whatever is wrong with your factory carb (if it's really the carb that has a problem).
Old Mar 3, 2004 | 05:31 PM
twistydick's Avatar
Car: 85 berlinetta
Engine: lg4
thanks, five. yeah, carb is bad.cracked housing. bought an autozone cap and rotor when i got the car.anyways, the car started acting like crap, backfiring all kind of crap last week. pulled the cap and the rotor tip where the metal tip is was twisted an broken.so ima ssuming the backfiring did in the carb. anyways, i bought a rebuilt one today. worked fine for a few hours, but now it wont idle down past 1300 rpm an sounds like its missing on a couple cylinders. ive adjusted it the best i can.guess im calling their tech support tommorrow.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
pimp2303
Jul 27, 2017 02:03 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
