DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
Fan Control
Old Mar 25, 2004 | 08:11 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Fan Control
Is the 730 ECM capable of controlling 2 fans independently? If so what pin does the second relay need to be connected to? Also what pin does the A/C high side pressure(fan control not high pressure cut out)switch go on or should I wire that directly to the fan control relay.
Old Mar 25, 2004 | 04:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fan Control
Yes it can, $8D, SD as used in TPI Y & F body's.
Pin E8 is the primary fan control (stock as used in F body's)
Pin F8 is the secondary fan control (not used in F body's, but in use in Y body's).
Pin D12 is the A/C status input for fan control (stock as used in F body's).
Pin C9 is an A/C compressor signal to the ECM. Not sure what the ECM uses it for, probably IAC idle control.
RBob.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
formula1LE
Sep 12, 2015 08:31 PM
scottmoyer
Sep 7, 2015 07:06 PM
85Special
DIY PROM
Sep 3, 2015 04:21 PM
