Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Dont know where to post it, but anyone else find "Search" annoying?
Old Apr 1, 2004 | 11:17 PM
5speed4life's Avatar
Car: 83 Trans Am
Engine: 355 4 bolt main, One day it will run.
Ok, I was just wonderin if anyone else finds the "search" feature annoying? I am trying to look up "T-5 Horsepower limits" or something similar, but T-5 will not let me search, because its less than 3 letters. How else do i do it? I cannot type in 5 speed, because "5" is less than 3 letters. There were other things ive searched for before, and i couldnt do it because of this limit.
So, does anyone else feel my pain, or am i just the crybaby of the day. Also, Why is it like this? Thanks in advance, Also you guys should have a "Website suggestions/problems" forum, or if you do, point me to it, because i do not see it.
Thanks.
Old Apr 1, 2004 | 11:33 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Dont know where to post it, but anyone else find "Search" annoying?
Thanks.
Your topic of desire is covered all the time. There are threads going on right now in the drivetrain board on the first page. Try a search with a whole sentence like "how much power can the T5 take" etc.
Old Apr 1, 2004 | 11:37 PM
Car: 83 Trans Am
I just did exactly that, and this is what i got:
"The search term you specified (t5) is under the minimum word length (3) and therefore will not be found. Please make this term longer"
U should try it. I think typing in wheel sizes does it too.
like type in "17" wheel backspacing"
I understand that the topic is going on in drivetrain, ive been readin up, but i wanted to ween out all the non t-5 topics by searching.
Old Apr 1, 2004 | 11:57 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
This should help a bit and maybe give you some more clues.
https://www.thirdgen.org/techbb2/sho...hreadid=232321
Old Apr 2, 2004 | 12:04 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
We cannot do anything about the search as we are waiting for VBB3's revised search, VBB3.2.
Old Apr 2, 2004 | 12:06 AM
Car: 83 Trans Am
Got ya, thanks. But how about a forum for just the website stuff? It may not be too popular or active, but it keeps posts like this in them, and not on the other forums.
Old Apr 2, 2004 | 12:12 AM
Administrator
Not understanding you. The FAQ Board is the place to go through also when you have a problem because it might already be answered.
Old Apr 2, 2004 | 12:13 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What websites? You will get the hang of searching. It is really easy once you get the hang of it. The FAQ board has some good stuff in it too.
EDIT: IROC beat me to it
Old Apr 2, 2004 | 12:16 AM
Car: 83 Trans Am
no, like website suggestions/bugs, or other problems with thirdgen.org, and not car related.
Anywho, im gettin used to it, i just have to be creative on some things.
Thanks again.
Old Apr 2, 2004 | 12:24 AM
Administrator
You are in that section. ThirdGen.Org doesn't have Non-Tech, always read the Important/Useful posts.
Old Apr 2, 2004 | 12:30 AM
Car: 83 Trans Am
Lol, thanks for showin me the light. This is exactly what i ment, i must have missed it. Heh.
Old Apr 2, 2004 | 12:34 AM
Administrator
Old Apr 2, 2004 | 09:08 AM
JT's Avatar
JT
Community Administrator
Re: Re: Dont know where to post it, but anyone else find "Search" annoying?
Just helping out here. Even if the minimum search word were changed to 2 words to allow the t5 word to work and Dirk re-indexed the search, your sentence has several words of what vB calls "bad words" and makes up a bad words list. Words on that list are ignored as they contain common, unnecessary, search words. Words like how, can, the, etc. are currently on that list. If you do a search and use how can the, you will find no results as those words are ignored. Those words do not help when searching. You will need to use more descriptive terms. Sometimes, yes, it's not easy.
Old Apr 2, 2004 | 05:29 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
I found the 3 characters or less rule annoying too....but theres a easy way around it!
add * to take up space until your over the 3 characters. Try t5**.I did and found 2371 matches on the trans board.:rockon:
Old Apr 2, 2004 | 07:28 PM
JT's Avatar
JT
I don't think it's that easy. Doing a t5* will end up picking up t56 entries. From your results, you may have noticed several threads with no mention of t5/t-5, but did have t-56/t56.
Of course doing the above works in a way because both manual transmissions are often mentioned in the same threads.
I'm just saying that is not really a way around the 3 letter minimum search limit. You can't so easily get around such a limit because of what vB is recording from posts/threads (search criteria) to begin with. Since the search system on this version of vB doesn't record words from posts/threads that are less than what the minimum letter search is set at when posts are made/modified, the search results won't be much help. I'm not an expert and I might be wrong, but that was my understanding of the search feature.
Old Apr 8, 2004 | 05:58 PM
ponykiller's Avatar
Engine: lo3
You dont have to put the * last, try *56* or **56 or whatever combination.It takes up space the get around the 3 or more rule and is better than nothing!
Old Apr 8, 2004 | 06:24 PM
JT's Avatar
JT
But he wanted t5, instead of t56/t-56. Something like t*5 may bring up some, along with a lot of junk. It will also miss, I'm sure, a ton of posts from users only typing t5 in their message.
I'm just saying I don't think you can get around the 3 minimum rule. The way the software performs a search is probably different from what most people assume. The software builds a search index database that is in part based around what the admin sets the minimum character limit. If a word in a post really is shorter than the limit, it doesn't get included in the database when the post is created, so it can't be found when you do a search because it's not searching the post table database. You can't find something that isn't there. Atleast that's my understanding.
thanks.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Out-Cast
Aug 22, 2015 07:49 PM
