Thicker C-clips
Old Apr 5, 2004 | 02:05 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Thicker C-clips
I have a situation where I need to eliminate ALL the end play in my axles. I'm looking for some thicker C-clips. Standard C-clips measure .150". I need some that are .200" .
GM used to have a service kit that included select fit C-clips but dealers can't find the reference. ( They remember the kit...just can't find the listing anymore ).
Does any one have any Part #'s in either GM or aftermarket that they can suggest. TIA.
Old Apr 5, 2004 | 05:18 AM
ede's Avatar
ede
have you tried aftermarket sources? WAG a set could be made fairly easy with a mill and grinder from a piece of gage steel.
Old Apr 5, 2004 | 07:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i found this odd..
now it could just be wear, but it didnt look it.
i had blown up a 3rdgen rear and i was putting together a LT1 rear that was missing a C clip.
for some reason, the new 3rdgen clips were tighter(thicker) then the almost new 4thgen ones. i just thought it was odd.
Old Apr 5, 2004 | 10:18 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
I actually made some lash caps that fit over the end of the axle ends to take up clearance between cross shaft. One side was a bit thin ( Machining error ) so I made a couple more.
Took diff apart to change lash caps....found a starnge wear pattern on old caps. A symetrical " ripple " effect all around the contact surface. Didn't like this. Only thing I can think of is a that they are not hard enough and are getting pounded when I autocross. Heat treating may be necessary...but I'm time limited.
To be safe, I've decided to ( temporarily ) abandon this idea and serach for thicker C-clips. I'm going to a local rear end shop and have a look through their C-clip selection. Must be something from some make that I can use. I'll post back what I find.
Aftermarket just goes by year and model. Don't post dimensions, so it's PITA.
Old Apr 5, 2004 | 04:09 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Ok...still on my quest for .200" thick C-clips. No joy so far. Have a couple of options up my sleeves, such as maching down a pair of C-clips to .100" and then Tig welding them together.
Heat treating my home made lash caps may work as well.
However....FYI... I did find some thicker C-clips than factory. Factory is .150" as mentioned. Jeep C-clips are about .175" . Don't know year and model, as I was sorting through a box full of used C-clips at my local Rear End shop....but Jeep C-clips are the same OD and ID as ours, but .025" thicker. Doesn't help me but it may be usefull info to others.
Off to the machine shop now....
Edit: Jeep C-clips are ALMOST the same ID as ours but not quite. Eyeballing it looks the same...but they are too tight to go on the axle. Five minutes with a Dremel Rotary tool solves the problem.
Old Apr 12, 2004 | 01:42 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Well the home Heat Treatment didn't work....but I've found a better solution. Best of all it's dirt cheap!! Like 50 cents each
External snap rings avaliable at any Automotive jobber. Can't remember the danged size ( lost my Invoice ) but it's a very common size. .045" thick...spring steel, so they will take a ton of load. Install the snap ring in the axle groove so that it is butted against the axle end. The " button " end. Slide the standard C-clip in behind and Ta-Da.... no more slop. I'm down to .005" end play on my axles which is absolutely perfect. Make sure that the snap ring is between the C-clip and the end of axle, as oppossed to the snap ring being between the C-clip and the " splines " . This will lessen the load on it during hard cornering.
BTW, I wailed on one of these snap rings on an Anvil with a Ball Peen hammer to see if they could be deformed by heavy loads. All that happened is that I got all sweaty and breathing hard. Spring steel is darned tough!!!
Stock C-clip is .150" as noted. Jeep C-clips are .175" ( need a slight bit of grinding on inside diameter to fit our axles.
This should help out some people who have problems with excessive end-play in their C-Clip axles.
Pat Westerkamp
Jan 13, 2002 08:54 AM
enigma57
Apr 12, 2001 08:50 PM
91L98
Apr 10, 2001 06:39 AM
Paul D. '87 IROC 350 TPI
Jan 29, 2001 10:52 AM
89BlwnRs
Jan 17, 2001 11:44 PM
