Worth Replacing Stock Rockers?
Old Apr 13, 2004 | 01:55 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I'm considering replacing the Rocker Arms and Valve Springs on my stock L03 heads when I put my edlebrock performer intake on. What ratio are the stock Rocker Arms...1.5 or 1.52??? Also, would putting 1.6 Rockers on really benefit me with stock heads and cam?
Old Apr 13, 2004 | 02:10 AM
vjo90RS8's Avatar
Car: 2002 Z28
my car ran 2 tenths better in the quarter mile and 1MPH faster when i added 1.6 stamped steel rockers from www.sdpc2000.com ..... i think it is a good mod for the L03 if you dont want to swap the cam and get into PROM tuning just yet, but are trying to get the max from the engine. i got mine for like $70 shipping, make sure they are for centerbolt heads and self aligning, www.enginekits.com also has some that will fit our cars, they are vortec roller tipped rockers and are only $90 plus shipping, which is what i would have gotten if they were at that price when i purchased mine.
Old Apr 13, 2004 | 06:52 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They are worth it since they add some beef to the stock cam. The stockers are 1.5 but are very sloppy. They flex a alot and are not really a true 1.5. Even a set of aftermarket 1.5's would give you more power over the stockers. I would go with some 1.6's like vjo mentioned. Depending on the mileage of your car you could possibly get away with stock springs.
Old Apr 14, 2004 | 09:00 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
on a stock! would I run into clearance issues if i used them on a 96 LT1 cam? I have new springs that are rated to .500 lift.
Old Apr 14, 2004 | 09:04 AM
Z28GEN3's Avatar
Engine: 305TBI
also is it worth investing into those Posi-stop cool nuts from Crane Cams?
Old Apr 14, 2004 | 09:09 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would not use 1.6 rr with an LT1 can and stock heads. You would most likely have coil bind regarudless of what spring you go with. I would just use the hardware that comes with what ever set you choose to go with. Nylocks will work just fine.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Streetstuff
Sep 7, 2015 09:23 AM
Reborn756
Sep 4, 2015 03:42 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
