Just went from 2.73's to 3.73's.... Great results.
Car: Camaro
Engine: Carbed L98
Like it said, I just swapped out from 2.73's to 3.73's.
Talking about waking the car up. It has a killer 1st gear.
I had been running the 1/4 in 1st and 2nd gear. I was changing to third right at the line at about 5800 rpm. lol.
I will be going to test and tune next friday to see how much it helped. I will also be installing LCA relocation brackets before going. I hope to cut down the 60 ft times.
To keep it tech, I did a test before changing the gears.
At 2500 rpm with 2.73's in drive, I was running 60 mph.
At 2500 rpm with 3.73's in drive, I was running 50 mph.
I hope this info helps answer a few questions about the 2.73 to 3.73 swap.
Keep in mind my mods. Im not running TPI anymore. Check out the sig.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
im hoping going to 3.73 with a zexel torsen will wake my car up a considerable amount from the 3.08 and worn out posi
Car: '00 Chevrolet Corvette
Quite a few years ago I went from an open/2.73 to an Auburn/3.73. Oh damn the difference it made. The Grey Car was a whole different beast after that.
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
I am right now going from an open 2.73 to a posi 3.23. Do you think that will wake the car up a whole bunch?? Also does anyone here know if a 96 S-10 yoke will work on a 90 camaro rear?
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Yeah...
Awesome. Also does anybody have a yoke that they would like to sell me for my rear end? I need it like yesterday fast so if you have one speak up. Thanks-Joe
Car: Camaro
Engine: Carbed L98
I drove the car ths weekend. Lets just say it was well worth the money.
A definate seat of the pants difference.
Now to just get some more track times.
A definate seat of the pants difference. Now to just get some more track times.
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Should I migrate to 3.73 or 4.10s in the spring? I have a 700r4 with a shift kit. 88k miles on the current engine and trans.
P.S. POSI as well
P.S. POSI as well
Car: '82 Z28
I'm going from 3.42 to 4.56, think I'll feel a difference?
Should have my rpm's at about 7100 to 7200 crossing the line
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
hey bluegrassz and you guys who had your gears upgraded: how much did you pay? i just got home from the shop and my estimate was $650
. im going from 2.77's -> 3.73's posi. the guy said about 200-210 for the gears and $80 for the gear kit then about 4 hours of labor. i was hoping for about 400-500 bucks.
. im going from 2.77's -> 3.73's posi. the guy said about 200-210 for the gears and $80 for the gear kit then about 4 hours of labor. i was hoping for about 400-500 bucks. Thread Starter
Car: Camaro
Engine: Carbed L98
. im going from 2.77's -> 3.73's posi. the guy said about 200-210 for the gears and $80 for the gear kit then about 4 hours of labor. i was hoping for about 400-500 bucks. I managed to get a friend to do it for $70.
Was a real good deal, and no noise from the rear as of yet. (crosses fingers) Thread Starter
Car: Camaro
Engine: Carbed L98
P.S. POSI as well
P.S. POSI as well
If it is a daily driver, I would stick with the 3.73's. The 700R4 has a 3.06 first gear, which is lower than a th350. With the shift kit and 3.73's, you should be happy.
Right now, I have drivability. I think with the 4.10's, it would be pushing it on the street. You could drive it, but forget about saving gas. lol.
Engine: 5.0L TPI
Axle/Gears: 3.08
Car: 83 Brlntta in Z28 clothing
Engine: 305 LB9 POS until 350....
Transmission: hurting 5 spd- Crunchy...
I'm looking to do the same swap, from 2.73 to 3.73, but reading the Jeg's cat I have some worries. I've already bought a really clean 3.73 gear set (41/11) that came out of an 86 camaro. Will this fit in my 2.73 carrier? Reading the Jeg's, it looks like the 2.73 and the 3.73 use different carriers- is this going to make the 3.73's I got not fit? They are GM take-outs, not aftermarket, and the posi 2.73 rear end I've got that I want to put them in came out of an 89 (I think) I've also found a 5/16 inch spacer for the ring gear in case I need to go bigger, but what if I need to go smaller?
The local GM place said if I supplied all the parts, like an install kit and the lube, it's come to about$250. But I don't want to roll down there and pay them to laugh and point out I got the wrong parts. help?
Z
The local GM place said if I supplied all the parts, like an install kit and the lube, it's come to about$250. But I don't want to roll down there and pay them to laugh and point out I got the wrong parts. help?Z
Car: Camaro
Engine: Carbed L98
Z
The one from the 86 with the stock 3.73's would be a 3 series carrier. The spacer might work. Try calling richmond gears and ask if it will work. I know the aftermarket 3.73 gear for the 2 series carrier is thicker than one for a 3 series.
I would check with richmond to be sure.
Car: 4
Engine: 6
Transmission: 5
The spacer will work. It should be the correct thickness to make up for the different pinion diameter.
http://www.drivetrainspecialists.com...=28&cat=GM+7.5 Search the page for "spacer", the one you want is about 2/3 of the way down the page.
I would not recommend the Richmond gear, if it's going to be street driven. Their racing gear is purpose-built for racing, and experiences noise and short life in street duty. It will of course last far longer in a drag-race-only application; but it gets that extra durability in that application at the expense of properties that make it last a long time on the street.
On that same page, look at the Superior, Dana, or GM Motive gears. Those are better suited to a street car.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Every Richmond gear set I have had or experienced was noisey. I now run Motive, they are quiet & reasonably priced, not to mention they are GM OE supplier.
Car: 1988 Camaro Sport Coupe
i have an auburn posi w/ 373s and i love it but mine are noisy too cuz i have richmonds but i just crank the tunes louder haha. good choice for a swap
Car: 1989 C4
Axle/Gears: 307
In my truck I went from a 3.73 12 bolt to a 4.56 14 bolt rear end. It made a huge difference and the 402 hit the 7k 10 feet before the 1/4 mark so I went to a 7200 which solved the problem, on a good run It would cut out right at the 1/4 mark. of course try to get a good run on a track thats cleaned once a month.
A little comment that goes along with the above posts.. Dont buy a richmond gear set, they do make noise even a street gear setup properly will whine. Motive and Polar seem to be real nice sets that are usually less expensive then richmond.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
- how can the car have a lower cruise speed with bigger gears ?
RB83L69- I found a crapload of spacers for sale on that link, and a couple different ones made sense. What part number do you think is the right one? The GM shop quoted me $64 and hour for about 4 hours, but I think I'll help them out and save a little by taking the rear apart and cleaning it. There's a visible difference between the two sizes of ring gear, right? The pinions are about the same? I think I'll take it apart, and if the 2.73 ring and the 3.73 ring match up in height, I'm good. If they are different, I can measure to see what size spacer I need. Does this make sense?
Z
Z
Car: Camaro
Engine: Carbed L98
My speedo dosent work, so I wanted to see what the motor was doing at 2500 rpm for a baseline. Someone followed me, and when I got to 2500 in drive, I waved to them to check there speed.
I guess I could have got them to run 60 again and see what rpm I was running. I can still do that sometime.
Sould be between 300 to 500 more rpm say around 3000. Thread Starter
Car: Camaro
Engine: Carbed L98
Originally posted by nolanr0413
i went from 3.23 to 4.10 and they are sweet .
well , i was running a 700 but i just blew it up a few days ago. On the highway , using calcualtions since the speedo was way off , i would be goin 65 and the rpms were around 2700 to 2900 . But im going to do the t56 swap very very soon, so ill have some more gears .
Car: 1989 C4
Axle/Gears: 307
Originally posted by 25THRSS
Doesn't richmond make a street gear? Are they still stronger than other brands such as motive and strange?
Ive seen no proof that Richmond street gears are stronger then any other gear out there.
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
anyone tahts swapped from 273 to 373,how did your times change... i jsut swapped from 273 to 373 and i ahve a 5 spd... so i wanna know what to expect at the track..
before i ran a 15.4 w/ a 2.4 60 ft.
Car: Camaro
Engine: Carbed L98
Well, I just went to the track friday. My times before was 14.92
With the gear swap, carb tunning, finished exhaust, and going to mobile 1 synthethic I went to a 14.20
here is what my timeslip looks like.
reaction------------------.765 (I was asleep
)60 ft----------------------2.079
330ft---------------------5.944
1/8 et--------------------9.135
1/8 mph-----------------76.77
1/4 et--------------------14.203
1/4 mph-----------------97.57
I was happy. I still have LCA relocation brackets to install. I also need trans work.
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I thought i read in a magazine that soemone makes a 3.73 gear for a 2 series carrier. Am i right on this ?....Anyone know who makes this??
Transmission: t-5
yeah richmond makes em. its what i got for my 2 series carrier. i got em from jegs. with 2nd day shipping the total was 120 somethin
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Car: Camaro
Engine: Carbed L98
Originally posted by SweetS10v8
If you can post your time with the LCARBs installed, I want to see you 60fts before and after
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
