What Bolts???
Old Apr 19, 2004 | 05:58 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
What Bolts???
ok well i got hedman headers and am now bolting then it but i have a ?. the 2 front bolts on the drivers side hold all the brackets on for the PS pump and AC, what do i do about those bolts? i can't use the stock bolts and i don't know what to do about the bolts they gave me.
Old Apr 19, 2004 | 08:22 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You will be fine. You just have to cut the back ear off the ac bracket where it used to bolt to the manifold so it will clear the header tube. The rest of the bolts go into the front of the block and shouldn't be a problem. Just make sure you have the brace that goes from the ac bracket to the intake is on there or it will rattle a lot with the ac on.
You can't see it real good in this pic, but it gives an idea. I had a closeup but I can't find it right now.
Old Apr 19, 2004 | 09:14 PM
chio987's Avatar
Engine: 305 4bbl HO
so the brackets won't bolt to the front 2 bolts? i mean it's like an inch or more difference. should i be using the stock bolt that has a nut, or should i use the new ones that came with the headers?
Old Apr 20, 2004 | 02:32 PM
chio987's Avatar
Engine: 305 4bbl HO
ok this pic shows the stock bolt and the new one i got
Old Apr 20, 2004 | 02:33 PM
chio987's Avatar
Engine: 305 4bbl HO
this one shows how the bracket goes on
Old Apr 20, 2004 | 02:35 PM
chio987's Avatar
Engine: 305 4bbl HO
now this last one show the stock bolts in the stock mani. so what am i suppose to do about the header (that isn't thing like the mani) and brackes that went on the stock bolts?
Old Apr 20, 2004 | 02:41 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
goto the hardware store with the bolts you have.
get a stud the length of the stock bolt(or a lil longer), 3 nuts, and 3 washers to go on it.
thread the stud in... to get it in snug, you can jam two nuts together.. (it does not have to be tight... the nut will hold it tight. if you overtighten the stud, you can crack the head)
now tighten one nut to hold the header on.
slip one nut on, then slip a washer on, then the bracket.
now hold the bracket where it goes, and snug the back nut to it..
then hold the nut and tighen the front nut.... and there ya go.
there is a alternate method:
you can use a spacer and a larger bolt... but the spacer has to be cut/shimmed to teh correct length...
or you can use the stud and a spacer.
Old Apr 20, 2004 | 02:45 PM
chio987's Avatar
Engine: 305 4bbl HO
so i can use the stock bolts and just use some type of spacer that is the same thickness as the mani, right?
(spacer in pic would be the width of manifold)
Old Apr 20, 2004 | 02:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you could.
i just dont like reusing heat cycled exhaust bolts... they have the tendency to snap..... and then you have a bolt broken off in your head..
its cheap insurance considering the new stud is probly under $0.75
Old Apr 20, 2004 | 02:53 PM
chio987's Avatar
Engine: 305 4bbl HO
ok so just go buy a new bolt stud that's the same as stock? ok well atleast i have anidea what to do,
THANKS
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
