White Smoke Safe to drive? HELP
Old May 4, 2004 | 02:22 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Ok, here's the deal at lunch today I was headed out, when the car started acting funny. No power, rough idle, etc, so I immediately turned around and went back to work. I looked and no rediator fluid. hmmm.. I live in Florida and it is a warm day and I have had to make a bunch of short trips from one building to another... So i figure I must have burned it up or something.. I let it cool, and filled the reservoir with water, figuring that would get me home...
After sitting for 2 hours it has cooled, I just went out and started it and now it smells like it is burning the radiator fluid. White smoke coming out the back, etc.
So, 2 questions,
1, is it safe to drive home (9 miles, but some stop and go, 30 minutes tops).
2. I am going to remove the top end of the engine tonight, but I have never cracked the heads. What do I need to know or do before proceding?
Old May 4, 2004 | 03:19 PM
Rivven87's Avatar
Car: 87 SC
Engine: 2.8 MPFI
Check your oil... white smoke in the exhaust every time I've seen it has turned out to be steam and a blown head gasket. So check your oil first. If it looks like a bunch of soupy light brownish goo, you blew a head gasket and your radiator emptied itself into your oil.
Old May 13, 2004 | 03:03 PM
IROCthis88's Avatar
Car: 1988 iroc-z all stock for now
Engine: LB9 305
Transmission: 700R4 3.42 posi rear
it definately sounds like a blown head gasket, also check to see if any antifreeze mixed with the oil to make a tasty soup.
Old May 13, 2004 | 03:56 PM
scanman717's Avatar
Engine: LB9
Yep, blown head gasket.. I took the high road and had it towed home... Found #7 cylander full of radiator fluid.. yummy!!
A week and a half later and it is finally back together (almost) and I should be starting for the first time since tonight.
Old May 13, 2004 | 04:19 PM
IROCthis88's Avatar
Engine: LB9 305
it was a good idea to tow it instead of drivin it cause then youd have to most likely replace the motor and such depending on driving habits.
Old May 14, 2004 | 03:58 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
As most will probably recommend... Be NICE to the engine for a few thousand miles after replacing the head gasket.
Depending on how long it had been leaking - Probably a few days at least (My GTZ ran for 4 days until one day at lunch, it blew all the way), it may have done serious damage to your bearings. I would recommend driving as "granny-like" as you can until you have some more miles on it... Personal recommendation: Change yer oil within 1000 miles of replacement. The oil will collect any coolant still in the motor and by changing it a little earlier, you can clean that crap out and hopefully prevent any future damage...
Take it from me: I spent $1300 having a head gasket and water pump replaced on my Quad4 about 3 years ago, only to have the original motor's bearing die tragically about 3 months later.
Vintageracer
Jan 10, 2020 05:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
squiggy2
Aug 9, 2015 09:30 PM
