just finished up my oval exhaust
Old May 22, 2004 | 11:06 AM
cobrakiller1989's Avatar
it definitely gained me some ground clearence. with the car on the ground i now have 4 inches of clearenceon a car that has been lowered over an inch. so im pretty happy with this setup. in the pics it makes the exhaust look crooked, its not, i measured and leveled it all, i guess its just an illusion. anyway, enjoy
Old May 22, 2004 | 12:53 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
that is soooo simple and beautiful
with a ground clearance being the main problem with a dual setup 4" is very good
however, isn't there gonna be any bad feedback about having the outlets of the pipes under the car? like rotting floor pan or I dunno...
it might look funny in a cold weather when there are a lot of fumes coming out of pipes, sth like your car being on fire
Old May 22, 2004 | 03:59 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
At last! Somebody finally posts pics of an oval exhaust setup!!!!! Looks really cool man. Could you get some side shots on the ground too.
Old May 22, 2004 | 08:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
What are the dimensions of that tubing?
Old May 22, 2004 | 09:44 PM
the car isnt driven in the winter so im not too worried about that kinda stuff, and im not sure about not having tail pipes being any problems, i like it a lot cuz its all hidden
Old May 22, 2004 | 09:46 PM
i dont have a side shot on the ground yet, but like i said, i have 4 inches of clearence and the car is lowered just over an inch, so on a stock height car it would be great.
i dont know the exact dimensions of the tubing, spintech may have it on their site, i think i remember it being like an inch and a half high tho
Old May 22, 2004 | 10:55 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Wow, nicely done. What kind of headers are those?
What was your exhaust before? Did you notice an improvement? How loud is it dumping in front of the axle like that?
Troy
So Cal
Old May 23, 2004 | 05:58 PM
Troy
So Cal
the headers are hooker long tubes, i dont have any fuel lines on the car at the moment, so i dont have any other answers yet, but i will have em this weekend hopefully. i did fill the bowls in the carb and start it up for a second and it sounded very very nice.
Old May 23, 2004 | 08:44 PM
whiteshadow87's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 1991 L-98
Transmission: 700R-4
Shouldn't you put a cross-over of some sort in there?
Old May 24, 2004 | 07:20 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
where did you get the mufflers?
Old May 24, 2004 | 08:23 PM
it all came from spintech
Car: 89 RS
They look like spintech mufflers. Correct me if I'm wrong
Old May 24, 2004 | 08:28 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
what was total cost of your set up? and did you use 18" sections or 40"?
Old May 24, 2004 | 11:57 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
purty,
i would think that some turndowns would be a good investment.
-chuck
Old May 25, 2004 | 12:42 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Looks good but my only question is why didnt you route the pipes into the driveshaft tunnel? If you tilted them on an angle it looks like they'd fit perfectly and double your ground clearance...
Old May 25, 2004 | 12:52 PM
Originally posted by ssxmac
purty,
-chuck
they are in the plans. i just have to figure out what i wanna do. spin tech make a bend that goes down also, i may just get one of them and cut and weld it up.
88IROC350TPI,
i wanted to make the least amount of bends possible considering that my bends consist of cutting the tubing on an angle and welding it back up. i didnt want to restrict the flow any more that i have with the bend on the drivers side. also, if i did put the in the driveshaft tunnel on an angle there would be no where for the mufflers to go on an angle. good thought tho
Old May 25, 2004 | 03:21 PM
Apeiron's Avatar
Engine: 383 Carb
You could have used a couple of round-to-oval transitions to change the angle.
Old May 26, 2004 | 11:23 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
It looks like he's already got pleanty of ground clearence, from the pics it doesnt look like they'll be hanging down any further than his rear sway bar. But im not sure if thats right once he gets it back on the ground. Some side view pics sure would be nice. Is there any downside to an oval exhaust?
-chuck
Old May 27, 2004 | 02:53 AM
Car: 89 RS
-chuck
The hole in your wallet afterwards. I still wanna run oval exhaust too! Maybe even experiment with a boom tube. We'll see.
Old May 27, 2004 | 01:36 PM
-chuck
your right about it all. like i said, i have 4 inches of clearence and the car is lowered over and inch. i dented the floor board so i could tuck it up even tighter. for anyone who has hooker LTs they know that they hang down low enough on their own. the parts that i dented were all long the driveshaft tunnel to gain me a small amount, and underneith the rear seats i dented. the metal was very easy to dent up with a small hammer and when in the car you cant even notice. i alost had to heat and dent the passenger side front subframe for more clearence. im not too worried about meesing up the integrity of the car, because im having a custom set of subframe connectors bent for my car that are going to come out and be welded to the pinch weld all the way down the sides of the car to better stiffen it up(i hope that made sense)
Old Jun 3, 2004 | 01:49 PM
sound clip
the sound quality sucks cuz it was on a digital camera cuz his camcorder kept eating the tapes, hopefully this will give you some idea tho. ill get better stuff later. we had to do this real quick cuz it was starting to rain. anyway, im very happy, this setup is so much nicer than any i have had
http://www.2muchboost.net/Tom/exhaust.mpg
Old Jun 3, 2004 | 02:44 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
Thats sweet!!!! Sounds damn good too. I want 3" round exhaust, same set up as yours. Is it loud enough to attract good ol Johny law??? WHich spin techs did you use?
Messing with the digital camera and didn't even get us a side shot.....fine, I see how it is!!!!
Old Jun 7, 2004 | 11:09 PM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
Im glad someone else did it...now I know what my system is going to look like . I ordered 2 transitions, 2-40" lengths of oval pipe, 1-18" length of oval pipe, and 2 custom made Spintech Sportsman Street XL mufflers with oval in and round outlets and a 3" rather than the stock 4" thick case. Its was $498.00 to my door. Not cheap but its what I wanted. I got the round outlets so I can easily have tailpipes made when Im ready. Its good to know the clearance is gonna work out the way I hoped. Im going to used the 18" piece to make an H-pipe set up. By the way they have oval turn downs you can order for your set up.
Old Jun 12, 2004 | 10:48 PM
CamaroEFI's Avatar
please post a side pic
Old Jun 13, 2004 | 11:17 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Hummmmm nice answer to ground clearance I might start rethinking my exhaust lol.
Old Jun 14, 2004 | 11:31 AM
the car is currently having the custom subframe connectors put on it at the shop, so i cant take a pick. but if you have hooker LTs on a car and know how low they hang already, it sits up higher than the hooker LT collector. as soon as i get the car back ill take pics
Old Jul 25, 2004 | 11:38 AM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Get it back yet?
Old Aug 15, 2004 | 02:02 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
i wanna see a side shot...PLEASE PLEASE PLEASE lol
Old Aug 15, 2004 | 10:07 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
awesome. i am so stealing that design this winter i assume that when spintech says 3" oval, its equivilant to 3" round, or is that the width of the tube? what did you do for the collectors?
Old Aug 21, 2004 | 12:25 AM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
The 3" oval tubing is equal to the area of the 3' round. When I order my oval pipes that was my concern. It doesnt save you as much as you would think but its a enough...its still like having 2.25 round pipes running under your car. I had them make custom mufflers as well that have a 3" thick case rather than the standard 4" to 5" cases found on most welded mufflers of that type....but at 145.00 a muffler ya might wanna think twice....lol.
Old Sep 1, 2004 | 07:48 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The exhaust looks good, but get that fram oil filter off your car!
Don't you need some kind of crossover pipe?
Old Sep 1, 2004 | 07:54 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
whats so bad about fram? ive used a fram on my 89 mecury sable since it was brand new, every 3k miles for 23x,xxx miles and still going strong
Old Sep 1, 2004 | 09:53 PM
http://www.bobistheoilguy.com/
Fram has one of THE WORST filtration ratings. Go get a napa/wix filter those are good!
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
Djmathis123
Sep 8, 2015 08:42 PM
hdis2002
Sep 8, 2015 02:52 PM
89fast5oh
Sep 8, 2015 09:55 AM
