My Half Painted Functional Blistered Hood
Well after a few months sitting in class I finally got it back home. I didn't paint the top side because I'm planning on bringing the whole car into class next year to do the bodywork and a full paint job.
This was a pretty damn easy mod really. I don't know why there is only one other person that I know of (LBSZ28BLOWN) who has done this.
-Cut the holes in the hood slighty behind where the rad would be underneith it. You make the holes here so if water gets on the hood it won't drip on the engine.
-Then cut the holes in the blisters about a few millimeters short of where you the edge then sand and file it down so you don't accidently cut into the rest of the blister. (I did this by mistake but not badly enoguh to matter)
-I then got some mesh for the holes in the blisters so no larger crap will not fall into the engine bay.
And thats about it really. And now for the pics....
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Neat.
So whats it do? I guess it could pull hot air out of the engine area....ummm but thats all I can see it doing.
I like the mesh, makes it look stock
Car: '91 TA vert
Engine: turboLSx
Originally posted by StevenK
Neat.
Neat.
I like the mod, good ideas. Looks good. Have more pics of the hood with the blisters on?
Yeah they serve as heat extractors. GM made functional ones on some of the Grand Prix GTP's (not the new ones though)
I'll get some pics of it with the blisters on the hood tomorrow
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i thoroughly love that for the fact that now when someone goes "those things on your hood what are they for" you dont have to say "oh theyre just for show" you can tell em that they serve a function.
Car: 92 Camaro Z28
I just did the same thing to my car. I put the holes in the hood in the same spot. The only thing I did different was I put the screen over the holes in the hood also. I have a picture if someone can post.
Ray
Ray
Car: 91 Z28
Ray
Ray
netburnr@netburnr.com
wow i really like how that looks very sharp and clean
Originally posted by tornado
hey jimmyg-91 where did u det those blisters?
i have the same hood but mine came with some stock louvers
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
looks great man, that's exactly what I would have done if I would have kept the stock look, good job
that looks really really nice...now i wish i had me some blisters on my hood lol...i would love to do that...and the black mesh was a very good choice...also less chance of the wire rusting as well....excellently done:hail:
Car: 1991 Z28
Would that be possible to implement that kinda mod for a Z28 with "gills"? Gills like you'd see on say '88 Iroc. I was thinking of doing that, but what are the risks of some water getting inside the engine bay? I mean if you drive in rainy conditions, wouldn't that be the getting some water inside the bay through the bottom anyway?
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
what did you guys use to cut the bisters? I have been thinking of doing this for some time but was nervous cutting into them!
There's nothing wrong with water in the engine bay, especially up front. The holes are also located just behind the radiator, according to JimmyG, so most of the water going in is going to fall straight down between the radiator and the pulleys, I imagine.
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Very nice work. I like that a lot. It looks real good. Funny, I actually opted to go with the louvers on my 91 rather than the blisters... This mod is giving me second thoughts...
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i've always hated the way that the louvers/blisters on irocs and z's have been non functional. good job..
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
DOES ANYBODY KNOW IF ANY AFTERMARKET COMPANIES ARE MAKING THE HOOD BLISTERS?
P.S. I agree, nice work jimmy, it looks goood.
Car: too many ...
Looks great!! But I'm too cheap to buy those hood blisters, around $100 for the set!! Madness!! I'll run mine with the old crappy looking louvers hahahaha. But yeah the cutout idea is great. Will probably also help extract heat from the engine bay.
Car: 1991 Camaro
Engine: 2000 LS1
Originally posted by custom88camaro
If those second thoughts don't get too serious, how about selling your blisters? When I took my louvers off to paint, over half the studs broke off the bottom. The 3m double sided tape seems to be working well, but I REALLY like the blister look. ALSO,
Car: 88 camaro
Engine: carby 350
The reason I say aftermarket is b/c it isn't terribly important to me that they look exact to factory specs. Do you know what GM charges for them? I once had someone tell me they only sold it as the whole hood. If that is the truth....... It is a shame they are so expensive cause they look sooooo good.
You know what they say, "PAY TO PLAY" LOL
Car: 87 iroc
Engine: L98 350
Aren't you worried water will get on things like your alternator and other electronics? I bet the car will shutoff when it rains. And standing water in the engine bay will cause rust. Otherwise seems awesome.
Aren't those vallid concerns? When you're at speed in the rain water will be going everywhere. If I did something like that I would rig up a switch to something that would block the holes when it rains.
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
water gets under the hood all the time,,,anytime your drive in the rain you soak the engine with water...it spashes up from the tires and comes thru the grill and rad. You wont have a problem with rust or atleast any more of a rust problem,,, the engine bay should be most protected from rust as its usually dry and sometimes well oiled.
I think its a great idea and he shouldnt have any problems. Look at hoods or engine compartments in the past that where open......
toyota mr2, Pontiac fiero....and dont forget about the old hodroders trick of cutting in custom louvers.
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
i was looking at the pic of the hood and started thinking is that a standard IROC hood with the bisters on it or is that a hood specific for the blisters?
i only ask cuz i bought a standard flat hood and blister to put on it..
Car: '02 Z06
well i bought the fiberglass aftermarket blister from hawk or some company like that cant remember the name but i figured the standard flat hood would work the underside of the hood has the outline of an IROC hood. but as i said i just noticed the IROC hood has those side lips to sort of wrap up the side where the louvers are.
this would help, does anyone have a pic of a blister hood without the blisters?
has anyone tried mounting these to a flat hood? http://www.hawksthirdgenparts.com/in...l?v=1&pid=2560
i really NEED (not want) a fiberglass hood but love the z28 blisters. How do these look on flat hoods? Has anyone done this? How did u mount them?
Car: 87 GTA/88 Iroc
Engine: L98/LO3
Transmission: 700r4's
I have them on my 91 RS. They aren't quite as nice as stock but the do work, and you can forget about using that outline under the flat hood because they are no where close to following the outline. Its just a lot of measuring and remeasuring. And of course, as with any fiberglass product, they require some bodywork.
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
did the same thing to my hood blisters not to long ago, I made the cut in the hood twoards the front of the blister where any water would fall between the radiator and the serp. belts. The only thing i did differently with my set up was where I made the cuts on the hood I bought black door trim and put it around the boarder of where I cut the hood. So when you look at it when you open the hood you don't see a hack job, but rather a stock appearing job. may want to try that?
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
- Joel
Car: 87 GTA/88 Iroc
Engine: L98/LO3
I wish i could have gotten around to painting it but 2 days ago it got ran over by a ford. It sucks but i picked up an 88 IROC today with the factory TBI which is just weird for $300, so life goes on i guess.
Street Lethal
04-30-2019 12:14 PM
colton_carlson
03-08-2019 12:21 PM
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
