Formula 350 custom dual exhaust with different style crossmember
Old Feb 18, 2024 | 05:41 AM
4valvemach's Avatar
Car: 04 mach1
Here is the crossmember got it off ebay for $45 free shipping
Old Feb 18, 2024 | 05:43 AM
4valvemach's Avatar
Car: 04 mach1
Re: 1994-98 mustang transmission crossmember exhaust project
Giving it some thought
Old Feb 18, 2024 | 05:46 AM
4valvemach's Avatar
Car: 04 mach1
Old Feb 18, 2024 | 05:57 AM
4valvemach's Avatar
Car: 04 mach1
This is where im at now both sides will get boxed in twice inside original subframe.The rear will get plated and welded to floor.The driver side will be continuously welded to floor pan.The passenger side gap will get a half moon of sheet metal to match floor contour on both sides of tube.I will copy the mustang mount.This not for everyone but I cannot stand the sound of a crossflow muffler.I also dont want dual exhaust run under the factory transmission mount with little ground clearance.
Old Feb 18, 2024 | 06:05 AM
4valvemach's Avatar
Car: 04 mach1
This will be long tube headers to H pipe hung of off of factory transmission exhaust hanger.It will be 2.5 inch dual exhaust flowmasters under rear seats.I will raise the floor pan under the rear seat for more clearance.It can be done and still have the seat bottoms look normal.From there up and over axle the drivers pipe will go to passenger side then over axle.The drivers side exhaust will exit passenger side.The passenger side will be routed to drivers side for exit.
Old Feb 18, 2024 | 06:07 AM
4valvemach's Avatar
Car: 04 mach1
Old Mar 12, 2024 | 10:46 AM
4valvemach's Avatar
Car: 04 mach1
More room now on passenger side for exhaust
Next is crossmember hangers
Old Mar 14, 2024 | 07:10 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Nice job on that!
Old Mar 23, 2024 | 06:34 PM
4valvemach's Avatar
Car: 04 mach1
Success crossmember holding the weight ! Now Ill trim down the mounts and shape them like the crossmember and cap them.The headers can come out now and I will weld the ball and socket exhaust ends on.The passenger side will get turned away from transmission.Still got some welding to finish in this area then to the rear seat pans.
Old Apr 4, 2024 | 06:27 PM
4valvemach's Avatar
Car: 04 mach1
New headers came and did a test fit before finalizing this section. The old headers on passenger side it faced right into the transmission pan and angle was terrible. The new headers are perfect and the UMI kmember was worth it, plenty of room.The Hpipe will go right at end of transmission and Ill continue rearward
Old May 14, 2024 | 04:34 PM
4valvemach's Avatar
Car: 04 mach1
Re: Formula 350 custom dual exhaust with different style crossmember
Floor patches done and bedlined
Test fit and seeing how it looks,im going to take it back apart push the Hipe farther back and move pipes up into transmission tunnel more
The rear is supper simple waiting on a 25° bend to come in with couple extra 90° bends
Old Jun 1, 2024 | 05:26 AM
4valvemach's Avatar
Car: 04 mach1
Finally, now just to fully weld the rest and put the tips on
Old Jun 1, 2024 | 05:40 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Great fab work installing the crossmember and routing the exhaust pipes. Have you set the car on the ground to verify clearance for the pipe that runs overtop of the rear diff? Are you going to aDs any hangers on the pipes between the H-pipe and tailpipes - just to limit things moving around?
Old Jun 1, 2024 | 08:21 AM
4valvemach's Avatar
Car: 04 mach1
I kept the rear springs out and used a floor jack to raise the diff to its highest point of travel for driving for my pipe position.The crossover pipe is in the little area between fuel tank and rear seat rest.The hangers ill do last one pair at mufflers and one pair at tailpipe ends.
Old Jun 1, 2024 | 08:26 AM
4valvemach's Avatar
Car: 04 mach1
Old Jun 1, 2024 | 08:32 AM
battmann's Avatar
Nice! Please post some pics of the modified rear seat pans. Would like to see how you did that. How much did you have to raise them?
Old Jun 1, 2024 | 05:21 PM
4valvemach's Avatar
Car: 04 mach1
Its about 2 inches of clearance gained
Old Jun 1, 2024 | 05:23 PM
4valvemach's Avatar
Car: 04 mach1
Old Jun 2, 2024 | 02:08 PM
4valvemach's Avatar
Car: 04 mach1
All painted
Old Jun 6, 2024 | 03:53 PM
Catbox's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
This is a very cool solution to under car packaging.
Nice work!
Old Jun 23, 2024 | 04:58 PM
4valvemach's Avatar
Car: 04 mach1
Still going to wrap outher tube
Success 🥳 Thats a 4x4 on ground and still 4 more inches of clearance above that once everything back in maybe 5-6 inches of ground clearance
Old Jul 28, 2024 | 10:30 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
That rear tailpipe arrangement is quite clever. It packages well and also keeps the pipe length after the mufflers similar. Is that 2.5" pipe?
Old Aug 10, 2024 | 12:47 PM
4valvemach's Avatar
Car: 04 mach1
Yes 2.5inch pipes
Old Sep 14, 2024 | 12:33 PM
4valvemach's Avatar
Car: 04 mach1
Relocated fuel pump harness up to clear the exhaust pipe,just made a tape template of original hole and cut
I didn't want to run another line to front of car for evap canister so used a foxbody mustang one.I trimmed the bracket and mounted it behind filler neck
And with factory cover its out of site and protected just need to run a short metal line from tank to it
Old Sep 14, 2024 | 01:13 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
This is very clever. Way more ground clearance than my single exhaust.
Nice work.
Old Sep 14, 2024 | 01:30 PM
4valvemach's Avatar
Car: 04 mach1
Nice work.
thanks
Looking at it now I would do shorty headers
Dual pipes following the original route to passenger side (Dual 2.5 fit done it before) then where original hanger off transmission is do H-pipe followed by my setup going back.
Old Sep 14, 2024 | 05:12 PM
Engine: that I like
Originally Posted by 4valvemach
thanks
Why would you make that change? What you have done is packaged very well, and long tube headers tend to offer more power across the band, compared to shorties.
Old Sep 14, 2024 | 06:15 PM
4valvemach's Avatar
Car: 04 mach1
It would be the route I would take if I did this on another formula and didn't want all the extra labor of making new subframes.I really cannot wait to get it running I think its going to sound really good.
Old Dec 14, 2024 | 02:51 PM
4valvemach's Avatar
Car: 04 mach1
Old Dec 14, 2024 | 05:16 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Sounds great.
yaj15
Apr 27, 2014 11:52 AM
DeathMetalTony
Apr 11, 2010 09:16 AM
Winger4800
Apr 3, 2005 09:35 PM
Demon Z28
Pacific Northwest Region
Nov 16, 2001 07:01 PM
DeathZ
22
Oct 6, 2001 12:04 PM
