My Turbo Project (Pics)
Old Jun 2, 2004 | 09:53 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I'm using the BBDS turbo Header, everything else I'm getting from other sources. I'm using a T.61 Powermaster Turbo with a 70 A/R Turbine Housing and a 96 A/R Exhaust Housing. I moved the alternator to the Passenger side and made a custom tensioner rod. I also made the Hood Blisters into Functional Heat extractors, and Made a Custom Rear Strut Tower Brace. If someone can host Pictures I have Pictures of all mods listed.
Thanks,
Ray
92 Z28
Old Jun 3, 2004 | 08:16 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
feel free to e-mail me all the pic's you want. I'll host em.
e-mail is below.
Old Jun 3, 2004 | 09:29 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here ya go.. should be nice when done
more here
http://www.cecoatings.com/images/oth...ars/rtkjadams/
Old Jun 3, 2004 | 10:39 AM
Guido's Avatar
Car: 2000 Trans Am
Good job! Nice looking car and setup.
Old Jun 3, 2004 | 09:29 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Umm..... NO. J/K
Old Jun 3, 2004 | 09:56 PM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Nice Going!
Hi Ray,
I just figured out that user name "rtkjadams" was actually you.
So, how are you boosting?
Very nice and looking good. Love the alternator bracket. Keep me updated with the project OK!
Old Jun 3, 2004 | 10:38 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Thanks, still have alot of work to do. Good thing this isn't my daily driver! Next on the list is to Fab up the intake pipe.
Ray
Old Jun 4, 2004 | 03:32 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
ssend me more when you get pic's and i'll toss em in the same folder for you.
Old Jun 5, 2004 | 10:01 AM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
For some reason I just love that alternator bracket. Isn't it funny how little details like that get attention? I wish I had thought of that for my TT Iroc, instead of using the serp/v-belt combo. That would have really cleaned up the installation.
PS- I just looked at that again- how do you plan to route the belt? It looks to me that you will need to put an idler somewhere on the LH side. Or maybe convert to a standard rotation water pump and drive it off the ribbed side of the belt.
Old Jun 5, 2004 | 11:23 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
The way I have the belt running it is turning the water pump in the same direction as the stock config. did.
The Belt runs from Crank to Power steering Pump, over to the bottom side of the water pump pulley, then the alternator, and back to the crank. So the back side of the belt runs the water pump.
I can take a picture if anyone wants.
Ray
Old Jun 6, 2004 | 12:43 PM
89JYturbo's Avatar
No pic needed. I understand now. I should have picked up on that- now I feel stupid. Like I said earlier, that is an excellent idea. I just wish I had seen that pic before I converted to the pre-88 V-belt setup for my 89 twin turbo iroc! Serpentine belts just work so much nicer and give a cleaner look to the install.
Old Aug 17, 2004 | 07:41 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Well I'm finished... for the most part. Updated pictures coming soon......
Ray
Old Aug 18, 2004 | 09:27 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here ya go Ray
LOOKS great..
Old Aug 18, 2004 | 09:53 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
:hail: Wow! looks great, clean install! Makes my car look like some cobbled together junk (ok, well it actually is).
Any times or numbers yet? What kind of intercooler is that? It looks like you just had to space the radiator further back and put the IC in place of the AC condensor, correct?
Old Aug 18, 2004 | 04:46 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
The intercooler is a custom made job. A friend of mine owed me a favor so he built it for $100. It is 31" End to End, 12 " Tall, and 3" thick. It has a 2 1/2" intake and a 3" outlet. I had to notch the lower Radiator support so it would slide back toward the motor. Then for the Top I used a piece of Alum. mounted to the stock mounting holes and drilled new holes in the Alum. for the top Rad/Fan support.
The Turbo is a Power Master .60 w/.70 A/R Intake, and .96 A/R exhaust housing, All piping is Ceramic Coated, except the Intake Pipe ( getting that done this weekend)
Ray
Old Aug 18, 2004 | 05:01 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Old Aug 18, 2004 | 08:33 PM
89JYturbo's Avatar
Lookin good! What are you using for the intake elbow (at the TB)? Also, what is that hose entering the TB elbow on the RH side? (water injector?)
Old Aug 18, 2004 | 08:54 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
The intake elbow is from "Trick Flow" for the LT1's. That hose is for the Wastegate. The Wastegate is a TAiL 40mm.
Old Aug 18, 2004 | 09:19 PM
1bdbrd's Avatar
Car: 1991 Trans Am
do you have any pics of your exhaust setup? namely the crossover pipe that goes from the driver side bank to the passenger side (if you used one of course)? also what did you use for exhaust from the downpipe back?
Old Aug 18, 2004 | 09:26 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
The cross over is made out of 2 1/2 " Mandrel bent pipe that I made myself. No Pictures..... I bought 2 1/2" Mandrel U bends and cut them up and reweldeduntil it was a perfect fit, then I had it ceramic coated.
My down pipe is 3" Mandrel pipe Wrapped and sprayed with DEI's Header Wrap Silicone High temp Sealant Paint, connecting to ATR's 3" CAT Back exhaust.
Ray
Old Aug 18, 2004 | 09:29 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Ray
did you go behind the engine with the cross over or in front? if behind, what kind of ground clearence do you have? i hope you ran it behind for what i want.
Old Aug 18, 2004 | 09:33 PM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Quick Pit Stop
Ray,
Nice work, it does look very clean!!!:hail:
1bdbrd; The crossover should look like this;
Old Aug 18, 2004 | 09:40 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: Quick Pit Stop
Originally posted by BBSDesigns
Ray,
excelent. it should have about the same ground clearence as a 3 inch y pipe setup shouldnt it? im just worried because ill be running the eibach pro kit.
Old Aug 19, 2004 | 02:43 AM
83 Crossfire TA's Avatar
Why would you move your alternator from the driver’s side to right next to the turbo?
Old Aug 19, 2004 | 07:34 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
The Alternator would have interfeared with the Intake piping, locates it lower on the motor, and easier to run the belt without using the stock a/c bracket.
Ray
Old Aug 20, 2004 | 09:14 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
stupid question....on a turbo system whats the function of the wastegate???
Dan
Old Aug 20, 2004 | 09:41 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Dan
Limits the amount of boost created.. Bob
Old Aug 21, 2004 | 12:10 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Dan
The compressor is connected to the exhaust turbine. More exhaust heat/pressure means more power to drive the compressor and it spools.
The wastegate is a valve on the exhaust before the turbo an when that opens some exhaust gasses are wasted (= not going thru the turbine ). With the wastegate you control the amount of exhaust that is used to drive the turbine wheel.
Old Aug 21, 2004 | 03:44 PM
So the exhaust gases that arent going through the turbine just go into the exhaust manifold(s)..to the cat(s) and then out the muffler?
Dan
Old Aug 21, 2004 | 04:18 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Dan
Yes.
Or just out to open air like the on the picture posted by BBSDesigns above. ( wastegate in the upper right )
Old Aug 21, 2004 | 05:39 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Looks good man!! Clean install.
Old Aug 23, 2004 | 02:24 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
:rockon:
Old Aug 23, 2004 | 02:57 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Here's the big question, how's it run?
BTW Very clean install
Old Aug 23, 2004 | 10:09 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Just started tuning it, But with No tune this thing is fast............ Boost comes on strong at 2800 rpm's, feels like you hit the nitrous button!
I have a 2000 Pontiac Grand Prix GTP that runs 12's @110 mph and the Camaro feels alot faster!!!!
However, I just killed the starter yesterday. Gonna order a Mini High torque Unit.
Ray
Old Aug 24, 2004 | 08:45 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
That looks awesome and is super clean!! It looks alot better than these hacked together Turbo setups I seem to see alot.
A+ job in my opinion
Old Sep 12, 2004 | 11:35 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Well, I fixed the starter Thrusday and brought the Camaro to its 1st local car show (for you S.Fla guys, Tower Shops). Everyone loved it..... I had a few people ask how much I would charge to do there Cars/Trucks. You should have seen the Ricers that would walk by....
Everyone that looked at it would ask what does it dyno at or what does it run in the 1/4..... I told everyone, I don't know this is the farest I have driven it at one time. (10 miles) I still have alot of things I want to do to it. BTW: I'm running 6 psi of intercooled Boost.
Ray
Old Sep 13, 2004 | 12:15 AM
MdFormula350's Avatar
very very clean looking install, car, and engine bay. :hail:
Old Sep 13, 2004 | 07:25 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
How about some Intercooler pictures. What FMIC are you useing? or is it homeade?
Old Sep 13, 2004 | 11:27 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes I am very curious about the FMIC as well
Old Sep 20, 2004 | 04:08 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Any chance of getting some sound clips and possibly a video?
Awesome Setup
Phyte
Old Sep 20, 2004 | 07:23 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I don't have a camcorder....sorry
Ray
Old Sep 20, 2004 | 07:48 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Old Sep 20, 2004 | 09:32 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
OK, I will take a few pictures tomorrow morning.
Ray
Old Sep 26, 2004 | 11:12 AM
Mike-91 Formula 350's Avatar
Hey rtkjadams, you say your running 6psi.Do you have it wastegated to that? I was wondering how the Masterpower turbos performed.I have a RayJay with EE wheels and a .90 exhaust.It's done at about 450-475 fwhp and I'm looking for a lot more but the big Garretts are quite expensive.Thanks
Old Sep 26, 2004 | 03:27 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ray
any more pic yet?
Old Sep 26, 2004 | 04:50 PM
nick418's Avatar
Engine: L98, Hemi 6.2
super clean and nice :hail:
Old Sep 27, 2004 | 12:29 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
I just sent new pictures to Chris, I'm sure he'll post them soon.
As far as the Power Master Turbo is concerned, I think it works awesome. But this is my 1st ever Turbo car. And yes I'm only running 6psi using a TAiL 40mm Wastegate to control the boost. The other Night I was leaving a local car show where we get close to 500 cars every Friday Night, there was these 2 Firebirds (LS1's) both with Drag Radials lopey idles and pretty loud exhaust. Well we raced from a 45 mph roll, when I hit it I spun pretty good until I lifted alittle and got back into it. So they had about a 1 1/2 on me, Well that didn't last very long....... I SMOKED the both of them. By the time I hit 100 mph I had 2 cars on them and pulling away. I can't wait until I turn the Boost up to 10 - 12 psi with alittle alcohol injection. I'm also gonna get some Drag Radials too.
I had about 6 people at the car show ask me to build them a turbo setup for there cars. What do you guys think a fair price would be to build and install turbo kits into cars????
Sorry so long,
Ray Adams
Ray
Old Sep 27, 2004 | 06:15 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here are the Pic's
Old Sep 27, 2004 | 06:18 PM
Excellent! Sounds like it's turning on real good!Did you get your turbo off of e-bay?
Old Oct 12, 2004 | 05:48 PM
BLOWN85/TA's Avatar
Sorry so long,
Ray Adams
Ray
Six pack for single turbo apps, dozen for twins, and twins intercooled require one COLD case(insert your brand here) in advance and T-bones for all involved on completion. Seriously though I want to see a pic of your "Custom Rear Strut Tower Brace."
