What is the round thing?
Old Jun 28, 2004 | 08:13 PM
LostInPlace's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
Hopefully you all can help me learn some more about cars and tell me what that black, spherical object is thats under the car on the driver side. It is close to the front near the battery (but lower) and has a vacuum hose running out of it.
I need to replace those rubber hoses because they're starting to crack but I don't know how I'd replace the one that runs into that ball. Any advice is welcome and if you know what its called/does, please let me know. Thanks.
Old Jun 28, 2004 | 10:04 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
that is your vacuum canister. it helps to hold vacuum in the system.
Old Jun 28, 2004 | 10:26 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
thanks. now that i know what it is, can you tell me if there is a way to replace the hose coming out of it, please? thanks for the help.
-rob
Old Jun 28, 2004 | 10:43 PM
Car: 91 Camaro
you should be able to just pull the hose off of it. there could be some sort of clamp or something on there but i bet its just stuck on there. it might really be stuck.
Old Jun 28, 2004 | 10:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To clarify what he has said a little better. That is the vacuum canister for the cruise control system.
Old Jun 28, 2004 | 11:17 PM
Doward's Avatar
Someone here once claimed it was....
THE ORB... OF POWER!!!
Old Jun 29, 2004 | 05:47 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
:hail: :hail: :hail: :hail: :hail:
All hail the Orb of POWER!!! (insert latin chanting here)
Old Jun 29, 2004 | 03:41 PM
Car: 91 Camaro
my car has the vacuum canister but does not have cruise control...
Old Jun 29, 2004 | 04:04 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
good grief
My car doesn't have cruise control either... but the hose goes up to the manifold. So I say to you..."huh?"
Old Jun 29, 2004 | 04:16 PM
Car: 91 Camaro
its a vacuum canister, i don't think it only came on cars with cruise control.
Old Jun 30, 2004 | 07:04 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
I have another question..
Can I buy new hose at AutoZone? And how do I know what size or whatnot I need? Also, is it expensive? It doesn't seem like it should be, but I'd like to have an idea of what i'll be spending. Thanks everyone.
Oh yea.. "Orb of POWER" haha thats great. Seems contradictory to have an orb of power in my car
Old Jul 1, 2004 | 01:00 AM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
If you're talking about 'standard' 7/16" vacuum hose, you can buy it by the foot at ANY auto parts store for about $1/ foot.
I usually buy what I need, and an extra foot or two, just to have some in the shop.
Old Jul 1, 2004 | 01:04 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
isn't that the gas vapor canistor?
Old Jul 1, 2004 | 03:51 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
My car never came with cruise control either. And it has one. I've seen them on other cars with no cruise control.
Old Jul 1, 2004 | 03:28 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
seriously sounds like the gas vapor recirculation canistor
Old Jul 1, 2004 | 04:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Trust me GreyFox, it is not the gas vapor recirculation canister. That sits in the engine bay, what he is talking about is mounted to the frame under the engine bay on the forward left side. See attached picture.
Old Jul 1, 2004 | 06:04 PM
Nixon1's Avatar
That was me, d*mnit, that was me!
Seriously, it's an orb filled with a magical, unknown substance from a transdimensional parallel universe that allows our motors to run blazing 17 second 1/4 miles.
Here's an idea...put that thing to use. Crack that puppy open, fill it up with some starting fluid...and let engine vacuum do the rest. Starting fluid works like nitrous on a moped...I'm sure it will do the same on a 2.8/3.1!
Old Jul 1, 2004 | 07:46 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
YES, that is the thing I'm talking about! Thanks Trickster. So if that if meant for cruise control, what purpose does it serve on my car since I don't have c.c.? Does that hose coming out of it affect my engine at all? I am planning on going to buy replacement hosing tomorrow(cuz mine's beginning to dry-rot), but would that help my car since I don't even have cruise control?
I don't have a whole lot of car knowledge YET, but are you joking about the starting fluid? I'm skeptical..
Old Jul 1, 2004 | 09:56 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
BS!!! 17 seconds??? wtf I can't get below 17.6 with a brand new motor!!! someone has to PAY damnit!
Old Jul 1, 2004 | 11:05 PM
Nixon1's Avatar
Oh yes, it'll work. Once. And your motor will pick up quite a bit of power. Once.
Old Jul 2, 2004 | 12:40 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
my apologies, thought he said it was near the batt isn't where the can is?
Old Jul 2, 2004 | 12:49 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
starting fluid?, what? ahhh you guys confuse the crap out of me sometimes
Old Jul 2, 2004 | 09:45 AM
Nixon1's Avatar
Starting fluid man! It's HIGHLY combustible! On a moped, a trick my buddy uses to pick up an extra couple mph and a little bit of umph is to spray starting fluid on his air filter....gives it an extra kick in the butt. So I was saying hell, it might work on a car motor too! Once. Before you hear a dull explosion as spark plugs, rods, and valve shrapnel is sent everywhere.
Old Jul 2, 2004 | 02:54 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
ohh ok , feelin kinda slow lately: prego woman 9 months so please excuse my stupidity :hail:
Old Jul 5, 2004 | 11:28 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's also tied to the HVAC controls. The 'orb of power' is a vacuum resivoir that helps keep the cruise steady and the vacuum actuators (that hold/move the ducting doors) in position when there is none/little manifold vacuum present.
To know if it works/leaks, right after you turn the engine off, you should be able to use the HVAC controls briefly and hear the 'pshew' sound from the actuators using up the reserve from the almighty 'orb'.
Old Jul 5, 2004 | 01:30 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
oooooooo :hail: :hail: :hail: :hail: :hail: :hail: :hail: i get it now, the OOOOOOOOOOORRRRRRRRBBBB,
Old Jul 5, 2004 | 02:22 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I broke my orb of power off it's mounts a couple of weeks ago and now it's just rolling around inside the bumper. (I drove the car up onto ramps and bent a few things in the process because the car is lower now.)
Old Jul 5, 2004 | 09:13 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
wow, thanks to everyone for sharing the knowledge. i replaced the hosing from the "orb" a few days ago (i would've updated sooner, but i couldn't access this site for some reason). the hose had actual holes besides the millions of cracks but now its brand new... i have no idea if it made any difference in anything, but i feel better having parts in better condition.
From what i'm reading, it sounds as if that canister is functional on cars without cruise control too? Have we finally gotten down to the bottom of the mystery of the black orb?!!:hail: :lala:
Old Jul 6, 2004 | 05:18 AM
ScrapMaker's Avatar
aint no mystery... I think every car has em... but it's good we "solved" it...
Old Jul 15, 2004 | 10:56 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
If this thing is connected to the cruise control system, how difficult would it be to add cruise control to a car that doesn't already have it? Just a thought...
Old Jul 16, 2004 | 12:22 AM
Well the round thing isn't going to get you very far for adding cruise control, but it's doable if you really want to. Some switches, a cc module, a vacuum switch attached to the throttle, a cc signal lever...
Old Jul 18, 2004 | 01:55 PM
ScrapMaker's Avatar
hrm, so what normally causes cruise control to not work? the light doesn't even come on in the dash, no response.. I wonder if the computer in the car has just had it... maybe its the lever itself... but I dunno, I really want it so I can stop getting tickets.
Old Jul 18, 2004 | 01:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the wiring under the dash below the column, the switch on the brake ( & clutch If manual) pedal, the cruise control module under the dash on the passenger side.
Old Jul 18, 2004 | 02:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There's a Tech Article on fixing the switch. More often then not it's been the switch that don't work and that is why someone created the tech article.
I fixed my switch following the tech article (you will need a multimeter for this) and other than installing the power switch upside down (let off of the gas and the cruise kicked in on me one time when I thought the switch was "off" ) mine works great....
Old Jul 18, 2004 | 02:12 PM
ScrapMaker's Avatar
ah, thanks for the info... is there anything I can "hotwire" or something so that I can see if all the components work when the car is parked? just want to make sure I don't need to replace anything else.
Old Jul 18, 2004 | 02:25 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The car MUST be moving at at least 35 MPH for the system to kick in IIRC.
Old Jul 18, 2004 | 03:03 PM
There are a few diagnositic charts in the GM shop manual for determining if different components of the cruise control system are working. As well, that tech article tells you how to test the switch. HELP (www.motormite.com) brand sells a new lever if you want to make it look original (part #49286).
Old Jul 18, 2004 | 04:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the part #, CJ! Found a price of $50, not bad for a factory-looking replacement!
Old Jul 19, 2004 | 01:50 AM
ScrapMaker's Avatar
I had an electric problem, where one blinker was just staying on and the other wouldn't blink... and they said they replaced the blinker ****, but I guess they just replaced the part that attaches inside the steering column... is this possible? is it one peice or multiple pieces... this was about 2 years ago, and my lever looks fairly worn... could just be cheap paint.
Old Jul 19, 2004 | 12:30 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The lever is separate because it also acts as the wiper and cruise control switches.
Old Jul 19, 2004 | 05:08 PM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
Ok back to the vaccum canister... or the "ORB" Well I had an 85 non ac car with cruise contol it had the mechanical doors but the orb was for the Cruise control. ... Eventually took it all out when putting the 327 in. I now have an 89 firebird with A/C vaccum doors but no cruise control. It also had the orb. Like other people my mounting tabs broke off and it was rolling aroundso I just removed it and all the vaccum lines with it. and capped it off at where it when into the line that goes to the vaccum hvac doors. Even with out this ORB I have had no problem with the doors or hvac controls at any rpm and even after I stop the engine and switch the a/c to off or other positions I can hear the "whoosh" decribed eailier, and the door moves, so there is plenty of vaccum and if you dont have cruise contol you dont really need this. It will be ok to remove it. I think GM just installes it because its easier going down an assy line and cost effictive maybe?
Old Nov 24, 2004 | 04:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I still get a kick out of that
Old Nov 24, 2004 | 08:15 PM
Resurrected! I know you didn't disappear for that long Tom.
Old Nov 26, 2004 | 11:21 AM
redraif's Avatar
Transmission: Th700R4
The orb of power
I was wondering about that when I saw it in that other thread...wow we have been getting alot of search resurrections lately!
Old Dec 1, 2004 | 10:52 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
my orb lacks power
Old Dec 2, 2004 | 08:55 PM
Nixon1's Avatar
Originally posted by 83_Camaro_83
my orb lacks power
Time for a rebuild....
Old Dec 2, 2004 | 09:16 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
AHA I was always wondering wtf that thing was. Not to mention the servo that went with it.
Hmmm. Maybe if we make a chant, and then rub the orb and chant it, our cars will be faster and avoid accidents?
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
