Rooting a Turbo.. "plans" and i'll need some help along the way....
Old Jul 27, 2004 | 03:35 PM
NEEDforSPEED's Avatar
Well, iv recently been to a few junkyards, i found a 7.3 ford turbo... and a turbo coupe 5spd ... turbo
iv been wanting to run a turbo for awhile now
and last night i did some looking around my Camaro and some measuring seems like that this would be a good rote for a single
turbo "see pic"... with less work for me... this well be going on a 305 TBI Camaro... btw, im well a where of the work that all be putting into this
im not sure if all the work well be wroth anything????... ok with the 7.3 turbo on a 305 when well it start spooling up, then droping off?
same with the turbo coupe isn't that a .63 turbo?
witch would be better to run for my application, everything being stock except headers and a few other odds and ends, what would be the simples cheapest way to do things with out replacing much... like injectors and what not.... maybe 6psi?
Attached Thumbnails Rooting a Turbo.. "plans" and i'll need some help along the way....-rootingturbore.jpg
Old Jul 27, 2004 | 04:34 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that exhaust tubing is running extremely close to mastercylinder. i would rethink. look at bbsdesigns setup, that i think is the absolute best singlt turbo setup you can go with!
Old Jul 27, 2004 | 04:39 PM
i can only do so much in photoshop...
i gotta about 2.5" to 3" between the pipes and the master cly
i could also put heat shelid around it...
Old Jul 28, 2004 | 07:27 PM
TwinTurboROC's Avatar
swap sides... get rid of a/c
dimented24x7
Sep 17, 2015 06:58 AM
neekolzun
Aug 24, 2015 04:59 PM
JAY4SPEED
Jul 14, 2002 09:59 PM
forsaken_one
Jun 29, 2002 10:18 PM
TransAMan
Nov 7, 2000 09:53 PM
