13's from a daily driven 305...YES!!!
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
went to the track yesterday for my birthday. i turned 20, i had a blast.
when i got there i wanted to get 2 base runs down to have something to compare the tweeking i was doing.
stock ignition curve springs/wieghts and a 275/60/15 tire (3.73's in the back)
60': 2.152 (tire spin)
330': 6.007
1/8: 9.186
mph: 76.99
1000': 11.959
1/4: 14.309
mph: 96.35
60': 2.168(more tire spin)
330': 5.997
1/8: 9.157
mph: 77.51
1000': 11.909
1/4: 14.240
mph: 97.13
put a set of 235/60/15's on to see if a better "gear" would help.
60': 2.231 (spun, let off, got back on, spun HARD)
1/4: 14.212
mph: 98.35(picked up mph and et)
played with launching at different stall speeds(got a 2000rpm stall converter) and netted this best run:
60': 2.160
330': 5.936
1/8: 9.078
mph: 77.81
1000': 11.808
1/4: 14.114
mph: 98.23
changed to a mr. gasket advance curve kit with the lightest springs
60': 2.223 (spun HARD AGAIN!)
1/4: 14.235
mph: 98.84
went back up and did a burnout (hadn't been cause of the street tires, i thought that a burnout would hurt...)
60': 2.105 (better but still spinning!)
330': 5.874
1/8: 8.992
mph 78.49
1/4: 13.976
mph: 99.33
then i wanted to reach 100mph so i took the power steering pump belt off...best run of the night...
60': 2.104
330': 5.848
1/8: 8.947
mph: 79.10
1000': 11.628
1/4: 13.888
mph: 100.24
traction will eventually be dealt with, but i am putting a hood and some new accessory brackets on it first. overall, i am EXTREMELY pleased.
www.cardomain.com/id/mw66nova for specs on the motor...
330': 6.007
1/8: 9.186
mph: 76.99
1000': 11.959
1/4: 14.309
mph: 96.35
330': 5.997
1/8: 9.157
mph: 77.51
1000': 11.909
1/4: 14.240
mph: 97.13
1/4: 14.212
60': 2.160
330': 5.936
1/8: 9.078
mph: 77.81
1000': 11.808
1/4: 14.114
mph: 98.23
1/4: 14.235
mph: 98.84
330': 5.874
1/8: 8.992
mph 78.49
1/4: 13.976
mph: 99.33
60': 2.104
330': 5.848
1/8: 8.947
mph: 79.10
1000': 11.628
1/4: 13.888
mph: 100.24
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Great job on the 13sec run. I too am considering building a 305 just to p*** off the 350 guys. My car will have a t5, other than that it will be the same as yours, less the roll bar. Any ideas?
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Box your lower control arms, take off your front sway bar and get relocation brackets for your lca.
That would help your traction for less than $200.
LB9GTA
LB9GTA
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
congrats. i'm sure there's a few more tenths in there that you could pull out with traction.
Car: 3
Engine: inboard
Transmission: underfloor
Great job man! I wasted my 20th birthday trying unsuccesfully to get laid (If I can remember that far back) and should have been at the track instead. Remember, there's a song with the line "there's women who wait for the man and machine with the best time" (OK- name the band and the song and you win a cookie!)
You didn't say what the temp was last night but I imagine is was a bit cooler than your runs you made this summer.
I can see that the "gear" helped you, but it made the 60' somewhat worse- smaller diameter and less tire contact.
I wish I had time to work out my S10's bugs and go to the track again. I should send you my truck for tuning.
Eric
Eric
Engine: 7.0L
the car is going to get a hood next. then i am going to put a set of spohn lca's on it. i would like to put a set of the new m/t drag radial 275/50 tires on it. i think that they are like a 26.1" tall by 10" wide tire.
temps last night where in the mid/low 60's with a relatively high humidity...track prep was minimal as well...my father wouldn't drive his car, even though he had it there....85 z28 with a big solid cam and dart iron eagle heads (about 550hp) and a power glide with a trans brake and 4.56 gears in a 9" with 28x10.5 mt's...3100lbs. street car...completely street legal
lighter spring in my secondaries may make traction a bigger issue than it already is.
TMZIrocZ350
Oct 7, 2015 12:09 PM
