Post pictures of your nice TPI engine bays.
Old Oct 24, 2004 | 09:50 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hey guys, I'm finishing routing my Painless TPI retrofit harness on my 327. I'd like to see pictures anyone has of their nice clean TPI engine bays, so I can see how the factory routed some of the wiring (I'm tempted to route the injector hookup wires inside the TPI runners to keep everything neat, but am not sure if the factory did this). I'm just being really paranoid because I don't want to pinch or burn any wires on my $325 harness.
Old Oct 24, 2004 | 10:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
too lazy to resize so i can post htem, so i give you link to where i had posted them elsewhere.
http://www.hardcoreware.net/forum/sh...ad.php?t=19773
Old Oct 24, 2004 | 11:01 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Here are a few.Hope they're helpful.
Old Oct 25, 2004 | 08:15 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I moved the injector wiring inside the runners on my car, and tucked the remaining wiring between the runner and valve cover, which required positioning them there BEFORE installing the valve covers. I think it neatened up the engine bay considerably though.
By the way, what motivated you to use TPI on a 327? That seems like an unlikely combination to me. Most of chevy's 327s that made big power did so by using a solid lifter cam and turning a lot of RPM, which seems to be very much against what the strengths of TPI are. I've got 461 fuelie heads on my car, and the fuelie head/TPI combo sucks in my application.
Old Oct 25, 2004 | 10:03 AM
grndprixss's Avatar
Car: 85 pontiac grand prix
Engine: 355 tpi
one quick tp i can give you is run the main bulk of wires through the top of the transmission hump right as it breaks off from the firewall you will never see the wires although it does make the distub area a little tight but still looks great, cant see too many wires on my engine
Old Oct 25, 2004 | 02:49 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Since purchasing my TA new back in 86', I've had just about every intake on my motor. Large tube, SLP, SuperRam and now MiniRam.
The MiniRam runs great and the installation is a snap but whenever I see a nice TPI motor like Jim's IROC, it makes me want to go back to a TPI. I remember the first time I saw a sales brochure with a pic a TPI motor, I thought it was the hottest motor ever.
www.geocities.com/dzperf
Old Oct 25, 2004 | 03:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 86 after I did the carb to TPI swap,
Old Oct 25, 2004 | 08:30 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey 87tpi, that air box u have? does that run down to a filter on the passenger side to the filter or no? I have a box just like yours that a friend gave to me but its all cracked and taped up.
Old Oct 25, 2004 | 10:11 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Bad lighting but atleast it was clean that day
Attached Thumbnails Post pictures of your nice TPI engine bays.-000_0565a.jpg
Old Oct 25, 2004 | 10:21 PM
Abubaca's Avatar
Old Oct 25, 2004 | 10:39 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
not to be a thread killer but zepher where did u get the intake setup.... ie plastics?
Old Oct 25, 2004 | 10:45 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Vortec77,It is the stock air intake setup.It does go down to a filter on the passenger side.It is one of the worst designed setups I've seen.
Old Oct 25, 2004 | 11:45 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
mine is clean...but I need to hide some of the stainless steel lines...going a little crazy there....
Old Oct 26, 2004 | 01:29 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Well, it *used* to be TPI...
A HSR doesn't leave much room for hiding lines.
Old Oct 26, 2004 | 08:45 AM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
Old Oct 26, 2004 | 09:43 AM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
In the picture Vortec77 posted, the air intake looks the same as the one off my 2.8?
Old Oct 26, 2004 | 04:24 PM
FIREBIRD7777's Avatar
Hey Jim85IROC nice polo green c4
:lala:
Old Oct 26, 2004 | 05:32 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
here you go
Old Oct 26, 2004 | 11:25 PM
Car: 2000 BMW M5
Thanks for the pics guys, and keep em comin! I'm going nuts with plastic looms trying to cover all my precious new wires, and it's giving me a headache. I think I gained 30 underhood wires going from non emissions 60s style carb to TPI.
Old Oct 27, 2004 | 01:45 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Here's mine. Love it or leave it!
Attached Thumbnails Post pictures of your nice TPI engine bays.-picture-011.jpg
Old Oct 27, 2004 | 02:02 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Although my funky looking filter is part of functional cold air kit.
Attached Thumbnails Post pictures of your nice TPI engine bays.-picture-009.jpg
Old Oct 27, 2004 | 02:10 AM
semiller26's Avatar
Car: 1986 Trans Am
here's mine, though its changed lately
Old Oct 27, 2004 | 07:13 AM
Jim85IROC's Avatar
:lala:
Thanks. That's my daily driver
Old Oct 27, 2004 | 08:37 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
here's mine
Old Oct 27, 2004 | 08:47 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
maybe this time..
Attached Thumbnails Post pictures of your nice TPI engine bays.-enginesmall.jpg
Old Oct 27, 2004 | 08:59 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
AND HERE"S MINE......
Attached Thumbnails Post pictures of your nice TPI engine bays.-mvc-001l.jpg
Old Oct 27, 2004 | 09:48 PM
vortec77's Avatar
Car: 86 T/A
Hey guys, I shouldnt have a problem finding an air filter that mounts right to the MAF sensor temporarily until i get the rest of the air intake system right? Thanks,
Old Oct 27, 2004 | 11:05 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Not the cleanest engine bay around. But the TPI sure is purty!
At night and the camera sucks at night!
Old Oct 28, 2004 | 12:31 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
here ya go looks like the rest
Attached Thumbnails Post pictures of your nice TPI engine bays.-hpim1159.jpg
Old Oct 28, 2004 | 12:32 AM
JeffW's Avatar
Engine: 305 tpi LB9
i may have the other side too
Attached Thumbnails Post pictures of your nice TPI engine bays.-hpim1157.jpg
Old Oct 28, 2004 | 01:17 AM
Car: 2000 BMW M5
Nice polished intakes Jeff and Semiller!
Thirdgen89GTA, those look like stock runners that were opened up to siamese configuration with some tig work. Please tell me more! I may eventually get a spool gun to feed aluminum wire in my Lincoln 135 plus mig, so I'm definitely interested in finding an alternative to $500 aftermarket runners.
PAForm, I like the painted intake. Definitely a unique change of pace for a TPI setup.
Razor, pontimaniac, and PAForm, what runners are you guys using?
Old Oct 28, 2004 | 11:34 AM
They aren't stock runners. ^_^
They are Arizona Speed and Marine Semi-Siamesed runners. I got them for a steal, but thunderracing, and summit carry them for about $475 before shipping and taxes.
Extruded aluminum, 1.66" inner diameter, and siamesed about halfway down. With a nice ported intake, and siamesed plenum these things run just short of a Super Ram setup. A few old dyno shootouts on a stock 89 Vette with headers showed the non siamesed versions actually producing more HP and torque than a First Injections setup, and a Mini-ram setup below 5,000rpm. This was with a ported plenum, and ported stock base. With siamesed and a ported aftermarket base I'm sure there is lots more potential.
Old Oct 28, 2004 | 12:06 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Attached Thumbnails Post pictures of your nice TPI engine bays.-blowngta5.jpg
Old Oct 28, 2004 | 12:51 PM
I'm REALLY Jealous of you! But you are also the 2nd person I have ever seen post on the boards with a set of AS&M runners.
The shear cost of these things keeps lots of people away. I wouldn't have if I didn't get the deal I had on them.
Old Oct 28, 2004 | 01:01 PM
Tony89GTA's Avatar
Car: 89 GTA
Ya there's not to many of us, but just like you I got a smoking deal on mine $275 new with gaskets off of some guy in the classifieds.
Old Mar 1, 2006 | 12:23 AM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Ditto on the runners guys just thought I'd say howdy since I also have a set on my 91, hey thirdgen89 do you have any dyno numbers yet or 1/4 times with the runners?
Old Mar 1, 2006 | 03:20 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
Here is one w/ the new valve covers.
Attached Thumbnails Post pictures of your nice TPI engine bays.-100_0030.jpg
Old Mar 1, 2006 | 03:25 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
Another
Attached Thumbnails Post pictures of your nice TPI engine bays.-100_0033.jpg
Old Mar 1, 2006 | 07:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Here is a picture of mine. When the picture was taken the focus was the CAI.
Attached Thumbnails Post pictures of your nice TPI engine bays.-gta-intake-2.jpg
Old Mar 1, 2006 | 07:55 PM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
My no frills 1LE
All the frills IROC-
Old Mar 5, 2006 | 06:14 AM
DSM's Avatar
DSM
Car: 84 Z28
Axle/Gears: 3.73 Torsen
Old Sep 25, 2006 | 06:57 PM
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
My engine picts 1 228,000 miles !
Attached Thumbnails Post pictures of your nice TPI engine bays.-dscf0210.jpg   Post pictures of your nice TPI engine bays.-dscf0211.jpg   Post pictures of your nice TPI engine bays.-dscf0212.jpg
Old Sep 25, 2006 | 06:59 PM
Dreambird's Avatar
Engine: 6.0l LQ4
my engine picts 2 228,000 miles !
Attached Thumbnails Post pictures of your nice TPI engine bays.-dscf0213.jpg   Post pictures of your nice TPI engine bays.-dscf0214.jpg
Old Sep 25, 2006 | 10:43 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
here....
Attached Thumbnails Post pictures of your nice TPI engine bays.-cam-018.jpg   Post pictures of your nice TPI engine bays.-random-pictures-393.jpg   Post pictures of your nice TPI engine bays.-cam-019.jpg
Old Sep 26, 2006 | 03:27 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Just try to picture without the wiring in the way that has since been cleaned up!
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
LittleFranks
Aug 20, 2015 03:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
R3500
Aug 17, 2015 12:16 PM
