can u guys post 4th gen int pics
Old Oct 27, 2004 | 08:13 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i really like alot the 3rd gen with the 4th gen interior can u guys post some pics and some good info on the swap
Old Oct 28, 2004 | 12:04 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
my 4th gen interior (seats, seatbelts and console)
seats are direct bolt in.
console took some modification to the shifter.
seatbelts were direct bolt in
Old Oct 28, 2004 | 12:08 AM
MNformula350's Avatar
93 Camaro seats, 96 Trans Am center console
Attached Thumbnails can u guys post 4th gen int pics-copy-interior-summer-04.jpg
Old Oct 28, 2004 | 01:25 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Dave I have the exact 93 seats as you waiting to go in one of my 91's. Just started cleaning them tonite. I've decided it was the best 150 bucks robbed out of the change jar this year! Nice to know what they look like installed.
Old Oct 28, 2004 | 02:03 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
thats gotta be the most comon interior seat combo i have seen it alot i also have em installed
Old Oct 28, 2004 | 06:40 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Old Oct 28, 2004 | 09:00 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i need to get another digi-cam cause these are pre-4th gen seats and the correct year center console....
Old Oct 28, 2004 | 10:26 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
Here's a partial pic of the console area (yeah, I know, the shift **** was pointing backwards then). Doesn't show much of the 2002 Firebird power leather seats or the overhead console, but "what the heck".....
Old Oct 28, 2004 | 10:35 AM
LUVmy92's Avatar
Car: Camaro
Old Oct 28, 2004 | 11:10 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I reeeeaaallly want a 4th gen center console now. It looks soo much better.
Old Oct 28, 2004 | 02:28 PM
85f-bird's Avatar
Engine: 2.8L, LS1
yeh, i think it's about time i update my pic, on that one i was still working on things, didn't have the underdash panels setup, no hush panels, etc, wires hanging everywhere and the wrong center console, (although i still have that version so i can switch to a later model dash for the cupholder console. All i have to do from the 4th gen now is door panels and A-pillars, both of which have been purchased, a-pillars have been trimmed some, need some more trimming, and the doors have the full 9 yards to go, but that i'm not worried about, if ya can do a dash/autoconsole, you can do a set of door panels, right? lol.
Old Oct 28, 2004 | 03:13 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
I like it a lot too. What do those run typically?
Old Oct 28, 2004 | 03:48 PM
KiLLJ0Y
Guest
Posts: n/a
hey guys..
on a scale of 1-10(1 beaing a moron can do it, 10 being hard as hell)
how hard is putting in a 4th gen dash, gauges, NO A/C, NO Heat controls?
i dont have a/c or heat, all i really need is to get the guages to work and the headlight switch(how does that work?)
Old Oct 28, 2004 | 03:53 PM
vernw's Avatar
Not to steal a thread here, but....
4th Gen consoles in really good shape can run anywhere from $75-$175, The thing you have to watch is which time period and which type you get.
First, a Camaro is a lot harder to put one in and make it look good due to the one piece console and radio pod. Several folks have done it, and most use a Firebird radio and heater/AC pod to make it work. Luckily I have a Firebird and had no trouble.
If possible, get a 98 or newer console. The earlier 4th Gens have a big protrusion on the front that is a stinker to cut off and get out of your way.
Also, if you have an automatic be prepared to have to due some fabricatin to get the shifter in there correctly. Lot of people just get a manual console and do without the gear indicator, it's a lot easier to do that way.
Hope this info helps a little bit.
Old Oct 28, 2004 | 07:34 PM
nick418's Avatar
Engine: L98, Hemi 6.2
Originally posted by LUVmy92
Sal, mooo i love your seats man
Old Oct 28, 2004 | 07:41 PM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
i see that u guys use the t/a consoles but on ur firebird 3rd gen,wat console do u use for a 3rd gen camaro?sence the console and the radio are all one piece?
Old Oct 28, 2004 | 10:24 PM
85f-bird's Avatar
Engine: 2.8L, LS1
alright, if you've got a camaro and you want a 4th gen center console, what is normally done is this. The console u use is from a late model maro/bird (98+,LS1 styled cars all have the same console) You'll have to do one of two options (as guys normally do) you either get a firebird radio pod from a 3rd gen and use that removing your factory 3rd gen maro radio pod which is connected to ur center console. Or, you hack up your old pod to fit the 4th gen setup, crappy situation all together. If you're ambitious using a early model 4th gen dash and console can be done, and can have great effects, but it doesn't have the same look as the newest styled ones, however, its very very very clean, good lines, and the lines will flow very well w/ factory camaro body lines....just an opinion though.
On that scale of how hard it is to do, i personally think my automatic center console was more difficult to do than my dash, however, the dash was more time consuming, wiring things for guages to just about a week to get the guages wired, headlight wired, blower motor wired (which udon't have) and the radio re-installed, and after that week things still weren't the way i want them, and infact, im still working out bugs and kinks to massage it how i like, but that's to say with any project.
If a 0 is no mechanicalskill needed, and a 10 is rebuilding a indy engine for 500 miles of racing, then i'd go with a 5. You'll need some knowledge and basic tools, you'll need to have a lot of patience, a good eye for konwing what needs trimming and why, a good mechanical sense (ability to see a "mechanism" and know what makes it work and how to make it work better, or more to your liking) etc, If you're just getting into the car stuff, then this might not be ur cup of tea, if you're good at fabricating thigns, and have a good ability with metal working and aren't afraid to hammer out a couple knocks, bang down a couple humps, and cut out a seems, then more power to you, and with enough time, im sure you'll be jumping up and down with the results.
Old Oct 29, 2004 | 12:16 AM
Car: 86 T/A
Engine: HSR 355
Banging and cutting my shifter makes me a bit nervous although I'm good with tools. Thats why I'm going with a manual transmission console.
Old Oct 29, 2004 | 10:32 AM
KiLLJ0Y
Guest
Posts: n/a
i was actually refering tot he whole 4th gen dash.. i already have the console done. i really want to do the dash, im just intimidated by all the wiring
Old Oct 29, 2004 | 10:48 AM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
the 99 Euro spec Z28 seats in my 86 sport coupe.
total 100% bolt in fit.
Old Oct 29, 2004 | 09:14 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
Here's an old pic of my interior- before I added white-faced glow gauges and custom door panels...
The seats were easy, but I did do a small amount of cutting to make the console drop right.
Old Oct 29, 2004 | 11:50 PM
1 BAD AZZ Z-28's Avatar
Car: 1987 Z-28
Engine: YOU WISH !!! COME RACE ME AND FIND OUT !!!
Transmission: YOU WISH !!! COME RACE ME AND FIND OUT !!!
Hey. I'm wanting to put in the '98 and up console, but I was just wondering what the height difference is between the 3rd gen Camaro compared to a 4th gen camaro? I ask this because the height for my arm rest is perfect for me right now(3rd gen) and I don't want to have my arm way up in the air. Anyway, any info would be great, Thanks,
1 BAD AZZ Z-28
Old Oct 30, 2004 | 03:47 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Is it possible to get those seats with red instead of black? my car has red interior and I would really love red on white just like that.
Old Oct 30, 2004 | 04:07 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
my 1999 SS Seats....thinkin about 4th gen dash and console..
Old Oct 30, 2004 | 04:36 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 86 Trans Am
With new Dash,
Before the Dash,
My 88 Formula after the Auto to Manual Swap,
Old Oct 31, 2004 | 01:29 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
02 ebony with T/A doorpanels and new carpet/headliner.
Will
Old Nov 1, 2004 | 02:33 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Transmission: 700r4 w/ about 7500 miles on rebuild
Hmmm.. 86 Trans Am... 4th Gen Camaro Steering wheel... hmm... oops? ur a little bit mis-matched..
Originally posted by Zepher
My 86 Trans Am
With new Dash,
Before the Dash,
Old Nov 4, 2004 | 11:23 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
My 2000 TA ebony dash and console.
Old Nov 10, 2004 | 04:26 PM
blk91z's Avatar
Car: 1991 camaro z28
Engine: 5.7
Transmission: 4l60
hey guys this is my second post on the boards hopefully this pic of my 4th gen interior shows up
Old Nov 10, 2004 | 05:42 PM
IHI's Avatar
IHI
Wish the pic was'nt so cloudy.
Dash install was a peice of cake compared to the door panels, those are a pita Part that took the longest for me was getting the dash pad trimmed to fit contour of the windsheild so it butted up tight. That was made somewhat easier since my windsheild was out for paint, but I have a new pad and must redo it.
Dont know how the rest of your guys pads are holding up, but I did'nt add enough support up by the windsheild and after 2 yrs of street driving/racing ever weekend the pad is cracked in 3 spots. So I'm going to pull it back out and start using expanda foam to make a solid foundation all the way across the dash for the pad to sit against.
Console was an auto, could'nt find a manual at the time in the color i needed to match the dash/door panels so I made due. Turned out a lil better once I got the new shifter installed.
Attached Thumbnails can u guys post 4th gen int pics-bird-pre-track-debut
Old Nov 10, 2004 | 08:50 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
I'm waiting for jason to show us his monster...
Old Nov 11, 2004 | 06:46 AM
Zepher's Avatar
That was a temporary wheel. I had a grant wheel on there before,
Old Nov 11, 2004 | 07:43 AM
LUVmy92's Avatar
Car: Camaro
Just call Hawks and ask them, I am sure you can get the seats however you want from what I understood.
Old Nov 11, 2004 | 07:59 AM
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
all those interiors look sweet
Old Nov 11, 2004 | 08:04 PM
RSFreak's Avatar
Transmission: TH700R4
Heres how a guy with the Camaro radio pod modified his. I would have made the cut at more of a 45 degree angle.
Old Feb 6, 2005 | 07:56 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Hey I didnt want to make another thread of a 4th gen interior swap, so I just dug up an older one to post this. but the past few weekends I swapped out my old seats for '01 TA seats and a 98+ console.....Im sitll not completly done I have to clean things up a little bit more, but I figured I would post a couple pics (BTW Ill never touch a console swap again...that was a bitch)
Old Feb 9, 2005 | 10:17 AM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
Camaroguy18 thats a nice looking swap. Your seats actually look ebony...some of the others seem to be differing shades making the console not match the dash as well.
What kind of pedals are those?
Old Feb 9, 2005 | 11:45 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
These are out of a 1993 Camaro.
Old Feb 15, 2005 | 02:51 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I am about to put Ebony Leather '00 Formula seats into my 1988 formula.
I'll post some pictures when its complete.
Old Feb 15, 2005 | 05:49 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
4thGen Int.
Old Feb 15, 2005 | 11:08 PM
Xceleratemaro's Avatar
Old Feb 15, 2005 | 11:10 PM
Old Feb 16, 2005 | 11:12 AM
thx....the pedals are just some covers...they were on when I bought the car but I know they're in jegs/summit/possibly pepboys etc
Old Feb 18, 2005 | 12:31 PM
Whitels1's Avatar
Car: 99 Z28
Engine: ls1
Transmission: A4
Axle/Gears: 3:42
I love the feel of the newer seats. Pictures aren't that great I'm gonna update it soon.
Old Mar 27, 2005 | 07:31 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
4th gen dash.. what can u use for speakers?
Old Mar 27, 2005 | 10:12 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
i just put mine in this weekend.. plug and play for the ls1 now..
Old Mar 27, 2005 | 11:09 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
heres one of mine with the 98+ console
Old Mar 27, 2005 | 11:38 PM
82knightrider's Avatar
Transmission: TH200C....700R4
All theses interiors are awsome.Nothin like a 4th gen int in a 3rd gen.
Casey Meyers
Mar 2, 2016 10:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
