Tire Wear, isn't this amazing
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
for damn near 9k miles of driving on the street.
yes this is also my borla exhaust in the pics.
heres where they used to be,
and jsut for you guys who are wondering,. here are the tipcs froma distance.
Shane
Shane
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No Shane, that is not amazing considering the many burn-outs you mentioned in an earlier post from a couple of days ago.
https://www.thirdgen.org/techbb2/sho...hreadid=266292
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Car: 1986 Trans Am
Engine: 305 LB9 TPI
either i never did burnouts, or the tires ar so quiet that i never knew. But usually when i do this, the car drifts to a side so iunno.
I called a left a realy nice and professional message on their machine, hoepfully we can work out some kinda prorated warentee or whatever.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
thats the thing
i've never looking in ym rear view and saw smoke.
i question my burnouts now.
cause even the guy at the local tire shop said that not normal even for me todo a burnout 3 times a day, especially since they we're warenteed byt the placei bought them from for 20k miles, i jsut dont wanna wait unitl they blow.
he said clal cooper and se what i can do.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
my Fulda Carat Extremos lasted two summers practically. They were new in March 03 when i bought the car and by august 04, they were replaced. at replacement time they were showing threads LOL REALLY worn out.
Anyway, I put on about 12 thousand miles on them with about a dozen small burnouts here and there. Tread ware rating was 180.
when new they are loud as hell when you spin them off. LOL, but when worn out, you hardly notice them spinning but could always tell by your Rpm's and sense of acceleration.
At a 109 a piece, they are a real nice tire. go easy on them and they will serve you well. handling/traction is great. especially in the wet weather and even in the cold.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well these have atread rating of 280
and they oly laster nearly 9k miles. I am very disappointed and they will be giving me some kinda discount on these new tires.
thats rediculoud, i paid $260 for two mounted tires and then this.
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
it could also be the quality of the tires...i work at a tire shop for 5 months now and only 5 times at the most have i seen cooper tires on a vehicle...theve all looked like crap and i was told these tires arnt the greatest.
Car: 89 Iroc-z
Transmission: TH400
tread wear of drag radials are low and you can get 9 thousand miles on them
mid 200's to 300's will last a good time like 14-17 thousand miles.
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Hey shane have you ever lived in and driven in the midwest during winter? I am going to guess not........ if I was you I would find a set of all weather radials...........and a beater to go with them before the snow and ice hits. (which wont be long, I only live 200 mi from where you are at and they said we might get light snow on thur.)
P.S. Did someone put a quarter in you and pull you string tonight?
Car: 05' GTO
Engine: 6.0L
Transmission: A4
wow that sucks. normally if your tires are worn that much most shops wont give u a discount or much of anything off the final bill mainly becuz they wore so fast like. andits also there judgement on weather to give a discount or do anything besides put new tires on the car.
ive worked at pepboys for over 2 1/2 years in ther service dept. and i change alot of tires and more then likly the place u got those tires from, the most they might do is prorate the tire. which means takes the tread depth and then the computer will calculate how much is taken off the price of a new tire. but if there worn close to the littlewear sensors on the tires, ud be better off just goin in and askin for a new tire then try to hassel them.
also i have Futura (which are made by Cooper) tires on my camaro and ive had them for about alittle less them 2 1/2 years and still have great tread on them and thats after a few burnouts on the street and plenty of burnouts at the track and also plenty of street driving.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
iunno, but i'm normally pretty good about gettign what i want.
and those tires are past the wear bars guys. The wear bar was 300miles ago.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Originally posted by CaysE
Suddenly that whole conversation about getting tires cheaper than TireRack is coming back to me...
I ended up not paying cheaper then tire rack, install was alot but each tore was $108, plus install. so....
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i had some goodyear 75,000 mile tires (sry, don't remember what model) and they wore away in like 5-6k miles....even the fronts (just incase someone thought i was burning out) i mean they had more tread than RC's tires but still, after 5k miles......it was
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Originally posted by megaracerx
how can you not know your doing a burnout?
Lol, I was thinking the same thing.
Car: 89 Iroc-z
Transmission: TH400
i was wondering the same thing but just didnt bring it up. lol, loss of traction is a noticeable thing.
Car: 89 RS
Engine: 383 in building process
Originally posted by CrazyHawaiian
I only do burnouts on used/free tires. Light em up!! hahaha. My good S-03's and good RE730's have never seen a burnout. Too expensive ...
Cooper is paying 75% of the new tire cost. So i'll only be responcible for $75 for two rear tires. Great deal guys....
shane
shane
Car: 1986 Trans Am
Engine: 305 LB9 TPI
they agreed, its actuaslly cause the place i boguth them from recoomended me 40psi, and even wrote it on my printed recipt. So its actually their fault but....
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Now whats the max pressure that is writen on the side wall ofthe tire? normally you want to go just a few pounds under that. so if its 44 psi do 40psi if its 35 do 32. thats how ive been settin my air pressure on all cars i drive and all cars ive put tires on and so far not one problem as far as wear.
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
shane
shane
open your drivers door and on either on the door or the body theres some stickers...one of them tell u what to set the tire pressure to from the factory...i got 35 psi in my tires
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
ok help me understand this. you have a thread saying you do alot of burnouts, and then you come here to whine about your tires wearing out.
simple doing a BURNout burns the rubber and melts it, i'm surprised the place is paying a nickel. hell i'm surprised they didn't tell you to **** off.
this isn't a flame just an observation
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Originally posted by Camaroguy18
Didnt you have an Edlebrock exhaust not too long ago?....how much was the borla?
The Borla was $50 sounds the same but performs soooo much better.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey 83Firebird420 do u still have ur factory tires on your car? do u know what the max psi is on those tires? more then likly u dont. now look at the tires u have on your car right now. whats the max psi? you go just under that mainly so u get even tire wear out of it if nothign in your suspention is messin up the tires. all differnt tires have different sidewall strenght and are made out of different tire compounds. take a Bfg tire and compare it to a futura. threres a big differnce in compounds and sidewall strenght. now if you run the bfg tire on 32 and say the max is 44 u wont have exzactly the same tire wear u would if u have it at 40. all tires are differnt, they dont match the tires that came from the factory back in the 80's.
u may go by a sticker from the 80's but i go by what the manufactours that make the tires.
but hey if it works for u
hey timz2882, i understand what your trying to say, but at my work we always go by the number on the door no matter what the tire is or year of the car and the psi hasnt really changed much since then...sure the tire compounds have changed but the psi hasnt. also its the factory that makes the car that knows what psi is best for it, for example u buy any tire nowadays and they have a max 44 psi or 41 they are all different but the car manufacture is who knows best....if u choose to follow what teh door says, then its better for the tire, if u go higher or lower then it could be better or worse for the tire. At my work when people come in and ask what psi their tires should be at, we always tell them the psi on the door. noone forces u to put the tire at what the door says it can also be personal prefrence what u want the tires set to
I prefer the door method, and only for stock sized tires... because it is generally lower than the recommended PSI on the tire, which means a more comfortable ride.
That's on my 86 Sport Coupe... a daily driver with not much in the field of performance. The difference of 5 PSI or so really shows in the feel of the road. And with all my stock clunky suspension, I'd rather have the tires doing the work than the springs, struts and shocks.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Went to another dealer and now i can get both tire,s since they charge cheper prices in the start, for $60. i'm ectremely happy guys.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
it pulls alot better at high rpm, yet i cant feel a bit of differnce at the bottom. Borla makes some good shizzle.
oh and yes cooper tires are the real low end of all tires made. even bfg cost 160+ each but will last much longer. No tire will last with burnouts or poor diriving habits.
most all passenger tires call for 35 some z rated tires call for 40. i usually go with 32-35 for any tire on a car. check you sidewall and forget the door sticker.
jeff
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Originally posted by CaptPicardsZ28
Beam me up Scottie...I can't take anymore!!
Scottie, is there enough power left over in the core to beam up one more? I've had all I can take too.
Car: 89 Iroc-z
Transmission: TH400
LOL, yeah, not sure an exhaust is that noticeable. Just alittle bit but wheel spin is noticeable. Traction loss is felt immediately
I run 30psi on my tires
