another Q about roll cages?
Old Dec 8, 2004 | 08:38 PM
mcwille's Avatar
Car: 1987 Trans am 5.7 TPI
Engine: 5.7 TPI
ok i am ripping out my trans am interior to redo it all, and to make it a two seater, but sometime down the rode i will want/need a roll cage. So i can take it to the track once my engine mods are done (down the rode means when i get enough money to build a new block) but once i do all this work to the interior i dont want to rip it all out again to put in the roll cage especially since i need to form the rear panel around the roll cage. Does any one know what specs are needed to go to a track in MI and really all over, 4pt 8pt 10pt???? just general info one roll cages???
thanks
mcwille
Old Dec 8, 2004 | 08:56 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Basically NHRA is 11.99 or faster you need a roll bar. 10.99 or faster you need a roll cage. Unless you have not modified the firewall or floor pan then you're good to a 10.0 1/4 mile with a roll bar setup.
4 Points are worthless from tech inspection stand point because they will not let you pass on that "officially". Basically you need the side bar to protect the driver too. Check out the links they got some pics.
Course this is all for hardtops... verts there more strict on that.
http://findfastcars.20megsfree.com/NHRARules.html
http://www.nhra.com/contacts/tech_faq.html
Here's a TGO link that has some pics:
https://www.thirdgen.org/techbb2/sho...hreadid=262101
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
