My ~2" Drop Photos.
Old Dec 12, 2004 | 02:40 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
My ~2" Drop/(SLAM) Photos.
SCROLL DOWN TO SEE BEFORE/AFTER PICS, THE FRONT IS PRETTY SLAMMED.
Cost me $1.97 for the angle grinder cut-off wheel, and $3.99 for the paint.
Rides firm and looks good. Hope this helps if you are thinking about buying drop-springs. Just the rear as of now (sunday, local auto store is closed, need spring compresser for the fronts) but I'll post more pics in the next few days of it all done. Looks good huh?
nidyanazo's Avatar
Old Dec 12, 2004 | 02:53 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
so you cut the springs... but the spring rate is still the same correct? so you car wont be riding stiff like it should when a car is lowerd..
Old Dec 12, 2004 | 03:14 PM
nidyanazo's Avatar
No, the spring rate has increased, yeilding stiffer springs.
Old Dec 12, 2004 | 03:46 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
could`nt you have just removed the biscuts at the top of the spring to lower it?
Old Dec 12, 2004 | 03:57 PM
nidyanazo's Avatar
Well they are made of rubber, seperating metal to metal....So I don't think that's a good idea.
Old Dec 12, 2004 | 04:06 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
doesnt look like that big of differnce over say like a set of stock worn springs, but probably rides better then worn springs
Old Dec 12, 2004 | 06:17 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
So what, those things combined add up to almost a pound!
Old Dec 12, 2004 | 07:17 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
lol
Old Dec 12, 2004 | 08:42 PM
nidyanazo's Avatar
"doesnt look like that big of differnce over say like a set of stock worn springs, but probably rides better then worn springs"
I removed alot of weight from the car, and it started to raise up....
"So what, those things combined add up to almost a pound!"
I'll get 'em!
Old Dec 13, 2004 | 10:31 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: My ~2" Drop Photos.
whats the paint for?
Old Dec 13, 2004 | 10:33 AM
nidyanazo's Avatar
Preventing rust
Old Dec 13, 2004 | 10:59 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Trust me here. After you cut those fronts you are going to love it...at first. Then you are going to be driving down the road, feeling everything and hating life. You are also going to have one hell of a time getting it to hold an alignment. Take it fron a guy that did it that way...twice, it is a good way do decide how low you want to go both for looks and for driveability (it's going to drag on everything). Once you decide on where you want it to sit, you really should put a proper set of lowering springs in there, or better yet, find a set of lowereing spindles.
Old Dec 13, 2004 | 12:49 PM
nidyanazo's Avatar
Thanks GTA, but im not going to be driving on the road with it.
Old Dec 13, 2004 | 01:17 PM
Graboid's Avatar
still looks SUV-ish to me
Old Dec 13, 2004 | 01:35 PM
nidyanazo's Avatar
You got to be kidding. It is lower than stock...So an original car must look like a lifted truck to you then huh?
Old Dec 13, 2004 | 01:40 PM
Graboid's Avatar
That's exactly how they look, like lifted trucks
Old Dec 13, 2004 | 01:54 PM
nidyanazo's Avatar
I'll show before and after pictures....With so much weight taken off the front, it looked like the motor was out! That is what got me going on lowering it. The front will be a bit lower than the rear when I'm done.
Old Dec 13, 2004 | 04:11 PM
you want it like this...do it do it
Old Dec 13, 2004 | 04:32 PM
nidyanazo's Avatar
haha That's pretty badass, but a bit overboard for me. It's going to look sweet though and it will def be LOW. Just finished getting the springs out ~5min ago, and am trying to decide where to cut them....where oh where....hmmmm......
Old Dec 13, 2004 | 05:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You dont need spring compressors for the front.
Old Dec 13, 2004 | 06:15 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
True story. I didn't.
Old Dec 13, 2004 | 06:40 PM
greezemonkey: that is sweet, I take it that its not your car, but still....damn
Old Dec 13, 2004 | 07:03 PM
nidyanazo's Avatar
DONE.
Here is what it looked like before.
Crazy huh? I took quite a bit of weight off.
Here is the drop...more like slam
I may drop the rear just a bit more...But I like it now.....WAY better then before!
Old Dec 13, 2004 | 07:34 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
drop the back about 1'' max more then it will look good. also is the car lopsided? looks like from that one front pic.
Old Dec 13, 2004 | 07:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i would deffinately drop the rear a bit more
looks too much like drag car even tho that probly is what your going for LOL
Old Dec 13, 2004 | 07:46 PM
nick418's Avatar
Engine: L98, Hemi 6.2
WERD, i agree.. I was thinkin the same, the rear is lil bit high and it does look like a drag car, id say drop a lil bit more, JMO
Old Dec 13, 2004 | 08:06 PM
nidyanazo's Avatar
Well thanks, ya I'm going for the "drag car" look, and it's just the 12 year old bra that makes it look lopsided, like 4 of the straps are broken that hold it to the bumper...It's level though I may drop the rear a bit more tonight, of remove those "biscuits" in the back.....
Old Dec 13, 2004 | 08:23 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
You can still take them out if you want to drop the rear a little more. Use heater hose & slice them open. Then run it on the top coil & you're set Someone else on the boards taught me this trick. Thanks man
Old Dec 13, 2004 | 09:42 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Do you rub the fenders?
Old Dec 13, 2004 | 09:50 PM
nidyanazo's Avatar
No fender rubbing, but I guess that's the purpose of the bumb-stops...actually, on a full-lock turn, yes.
Old Dec 13, 2004 | 10:05 PM
jocww's Avatar
Car: 84z, 65 elcamino
Transmission: t5 m21
Axle/Gears: 373s 411s
hows the speed bumps doin to your under body
Old Dec 13, 2004 | 10:33 PM
nidyanazo's Avatar
like I said, it's not a streel legal car anymore, but i do drive it on occasion. When I finished the springs today I took it for a fast ride down a bumpy alley. The spring rate is much higher now, so that makes up for the low stance, and it handles bumps fine. The only odd thing is it seems to lack low speed steering response...It may be due to the fact that i took out the sway bar......
Old Dec 14, 2004 | 12:30 AM
jocww's Avatar
jsut because it isnt street legal doesnt mean u cant drive it on the street anymore.
Old Dec 14, 2004 | 12:49 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Only if you get progressive springs, will they be better. All lowering springs are, are shorter stiffer springs, which is the same as cutting stock springs.
Old Dec 14, 2004 | 12:50 AM
nidyanazo's Avatar
Right? I guess one of these days, when my reg expires (feb 2005) and I can't renew it (stupid emmisions) I'll find out how much the fine is...I'm picking up another third gen end of jan. and making it into a nice daily driver....Thinkin 5-speed, 305tpi, black, hardtop....But maybe a monte ss if the price is right....
Old Dec 14, 2004 | 01:29 AM
Kandied91z's Avatar
looks good... not low enough. i'm still trying to get my back end lowered, just can't cut anymore spring out of it??
Old Dec 14, 2004 | 03:37 AM
nidyanazo's Avatar
Just worked the rear springs again, looks alot better. It's 2:00am so I'll take some more photos tomorrow....I think you will agree, much better...looks evenly poised now...:lala:
Old Dec 14, 2004 | 03:54 AM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Just dropped my Vert with some dropzone springs i got off of ebay. I'm amazed howlow it is. havent taken any pics yet but i cant wait to get some to show everyone.
can some1 tell me where to adjust my drivers side wheel from leaning in? it looks likethe strut has moved, from under the hood you can see where the strut used to be bolted down, and now the bracket is more than an inch off, it's closer to the engine now. tire is really leaning bad
Old Dec 14, 2004 | 03:59 AM
nidyanazo's Avatar
The bracket with the 3, 10mm bolts in the engine bay holding the strut is adjustable. Loosen, adjust, tighten.
Yes, lets see pics. How much did you pay for your springs $$$??
Old Dec 14, 2004 | 04:21 AM
jer4251's Avatar
Car: They all sit.
ill try to get picstoday. paid 99 shipped to my door brand new
Old Dec 14, 2004 | 04:59 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
lol.
Old Dec 14, 2004 | 05:30 AM
CrazyHawaiian's Avatar
Car: too many ...
Are you guys getting the car re-alighed after dropping it? I had to ghetto fab align my car in my driveway just to get it drivable to the alignment shop (right after I slammed it). If not, that explains the different feel of the car (your alignment is now off).
Old Dec 14, 2004 | 05:31 AM
Camaroguy; Yea that is my car it`s not that low that`s a photochop I had some of the guys over on the siggy board do for me
Can`t wait to see the finished picture
Old Dec 14, 2004 | 11:15 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Well maybe I should clarify what I was driving at here. I figured that most of the lowering springs available for the 82-92 F-Body were progressive, since it is pretty much limited to Eibach, Edelbrock (Eiback), Hotchkis and Drop Zone springs. I know the Eibach's are progressive, as are the Hotchkis ones. I wasn't sure about the Drop Zone springs but foolishly assumed that they were progressive as well. I guess what I was really tring to convey was that the ride quiality went to hell when I had my cut-offs in my car but came back to reasonable with lowering springs. I lowered my current car with spindles instead of springs because of the alignment issues I had with my old car. I didn't realize that his car was a race only car where ride quality means nothing, so just disregard my previous post.
Old Dec 14, 2004 | 11:41 AM
ME Leigh's Avatar
Car: 82 Z28
I cut the crap out of my springs, and it rides just as good if not better then before. I get no hard jolts, or jarring.
Maybe i'm just one of the crazy ones that likes to feel the road and what the car is doing.
I do have to say i have no complaints at all and would do it again in a heartbeat. No problems at all.
Old Dec 14, 2004 | 01:57 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
I am not saying that MY car is some kind of Caddylike ride, but it is much better than the cut offs I used to have. I'd still wouldn't call it comfy, but it's not out of control. You may have better struts and shocks than I had. I have great ones now, but back then, who knows. Of course where I live, the roads are just crappy...everywhere. Lots of worn out asphault and a bunch of potholes.
Old Dec 14, 2004 | 02:59 PM
nidyanazo's Avatar
Here are the finished pics, back is droped a tad more now....
Old Dec 14, 2004 | 03:01 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
That bra has to weigh at least a few pounds... LoL
Old Dec 14, 2004 | 03:04 PM
nidyanazo's Avatar
I know, but it covers up some nasty cracks in the bumper
Crazy: I'll take it to get the alignment done, it seems pretty on point, but you can't really just eyeball that sort of thing huh?
