MAF and Boost
Old Feb 20, 2005 | 10:12 PM
turbobike's Avatar
Car: 87 WS6 Firebird
MAF and Boost
I have a single turbo setup on my 87 MAF Formula. What is the best way to add the additional fuel?
my current plan: I am going to add larger injectors (30lb/hr) reconfigure the factory prom for the 30lb/hr injectors. Using the MAF sensor for the additional airflow calculation. I figure the factory mass air can flow about 490hp (crank) before the MAF reaches it's max voltage i.e. max air flow.
This will be about 9psi of boost on my sissy 305ci.
Therein lies the problem, after 9psi I will have need of a different solution.
Old Feb 21, 2005 | 12:28 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Easiest way- FMU
Best- change ECM to either a 1227730/749 and run the $58 code in prom they you will have control of fuel and spark under boost.
or if you have alot of cash......buy a Aftermarket EFI from Accel/fast/holley/bigstuff........
/N.
Old Feb 21, 2005 | 12:29 AM
oil pan 4's Avatar
Car: 89 Firebird
I think you will have to go megasquirt or some thing totaly after market like that.
Old Feb 21, 2005 | 07:18 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The SuperFueler is another option. It's worked for me since 1999.
Old Feb 22, 2005 | 07:09 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: MAF and Boost
Why not just repin and use a 2-bar map sensor? A lot of us have had VERY good luck with the $60 code.
-- Joe
Old Feb 28, 2005 | 12:25 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Your maf will work. There is a guy on Iroczone.com Who has a supercharger running 13 lbs of boost and he still uses a stock maf sensor. Just need to get the proper tunning done to it.
$750 L98
Feb 1, 2025 02:25 PM
Mark_ZZ3
May 24, 2018 01:02 PM
racereese
Oct 3, 2015 03:46 PM
Dragonsys
Sep 25, 2015 03:51 PM
