Southern California Area Southern California Members.
Check out the New Air Tube
Old Feb 25, 2005 | 06:48 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just got it back...this should flow some Air
Old Feb 25, 2005 | 06:53 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Old Feb 25, 2005 | 07:08 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Lookin good :good job:
Old Feb 25, 2005 | 07:12 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Rich people stuff it looks nice
Old Feb 25, 2005 | 07:40 PM
Mr. TurboTA's Avatar
Wow!
Look at that really rare under hood light!
And that Firehawk cross support!
Really though, looks great!
George
Old Feb 25, 2005 | 08:22 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
So, Don, what would it take to get or make one of those for my 383 Superram setup?
Pretty please?
Old Feb 25, 2005 | 08:23 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Wow, that looks great, Don!
Old Feb 25, 2005 | 08:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Rumor control has it that is worth around 16 horsepower over the stock Trans Am unit.
Nice catch on the under hood light for a Trans Am. As I understand it there are very very few with that light. Allen
Old Feb 25, 2005 | 10:20 PM
Dyno Don's Avatar
Originally posted by Mr. TurboTA
Wow!
George
Thanks!
George, you forgot to mention the 120 amp B4C Alternator
Old Feb 26, 2005 | 09:01 AM
Hi Don!
You're right! I forgot that!
And that wonderbra on the bottom of the car too!:^)
Oops, I meant the wonderbar!
George
Old Feb 26, 2005 | 10:45 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Pretty please?
First you'd have to bring the car to CA.
Old Feb 26, 2005 | 11:21 AM
JERRYWHO's Avatar
You got that right.
Jerry
Old Feb 26, 2005 | 11:38 AM
82knightrider's Avatar
Transmission: TH200C....700R4
Originally posted by Dyno Don
Thanks!
lookin real fly dyno don
He also forgot to mention the clean radiator resouver(sp) tank,which is a rarity in its own..lol
Old Feb 26, 2005 | 02:47 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Now if I could just get one made that would actually work on a serpentine setup Camaro with the battery still in it's stock location. Otherwise it's having the tube riding on the hot water return tube or relocate the battery to get a firechicken style one
Old Feb 26, 2005 | 05:53 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
What's this? A fancy chrome part on Don's car? Is there some natural disaster about to occur? I thought you were all about "get the cheapest thing that gets the job done"?
Looks good Don!
Old Feb 26, 2005 | 11:22 PM
Dyno Don's Avatar
Looks good Don!
Bret:
That's thermal coating ....and I think it will get the job done.
And no...my reasoning is...why dump a lot of cash on feel good things. When "one" has the cash "one" should put it where it will do the most good.
Or as the Grump once said "get all the variables under control"
So with that said, I think you must have misunderstood my reasoning.
Old Feb 26, 2005 | 11:51 PM
Kevin91Z's Avatar
After playing with the last setup, it was found to be still too restrictive. So he bent up some 3 1/2" pipe, had it coated, and installed it. Hopefully now the restriction is gone.
You Pontiac guys got screwed on your intake.
Old Feb 27, 2005 | 07:46 AM
Kevin,
My Pontiac intake works just fine!
George
Old Feb 27, 2005 | 10:43 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Kevin,
George
Suction is a good thing
Old Feb 28, 2005 | 02:49 AM
1fsstgta's Avatar
Car: F-Bodys
Transmission: shifting
Looks good Just like mine
Old Mar 2, 2005 | 05:03 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Look at this one.
Old Mar 2, 2005 | 05:19 PM
Car: 1989 GTA
Engine: 369 TPI
Hi Vicent
That one looks like an oval to 3.5 inch. Need to find out where he got the piece next to the throttle body. What Don needs to do is get a mandrel made up that spreads the 3.5" tubing to the shape of the throttle body oval. Just money Don.
There are no restrictions in his air intake system. One thing I would do if I had his car is box in the airfilter so that it can't draw hot air from the engine bay. Cold air only. Allen
Old Mar 3, 2005 | 02:48 PM
vernw's Avatar
Originally posted by 1989GTATransAm
Hi Vicent
And then offer them as kits to other poor Pontiac souls liek myself....
Old Mar 3, 2005 | 09:08 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
You going to sell that Don? We are going to switch my buddy over to TPI from TBI here in the next few weeks and that would be nice in there at the same time.
Old Mar 3, 2005 | 11:47 PM
Dyno Don's Avatar
Making some up
I hadn't thought about it.....I made it up from pieces I had laying around. I'll check on what it would take and go from there.
Old Mar 4, 2005 | 12:44 AM
Yeah let me know would be nice. It looks one piece?
Old Mar 4, 2005 | 07:13 PM
JERRYWHO's Avatar
Re: Check out the New Air Tube
That thing looks like it needs a Turbo on the other end of it.
Jerry
Old Mar 9, 2005 | 02:23 PM
vernw's Avatar
Re: Making some up
Please do! I'd love to have one. Already got the LT1 elbow....
Old Mar 15, 2005 | 06:08 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
Okay, I am planning on starting to build my own CAI and would it be better to have the filer, K&N of course, located up where the factory location is at or cut a hole and mount it under where the factory one goes? I have seen pics of it done both ways. Just wanting to know which would be better for more HP gain? I have an 89 Firebird Formula 350 with MAF incase you are wondering.
Old Mar 15, 2005 | 10:30 PM
Russ-So Cal's Avatar
If you isolate the filter from the underhood heat, putting it in the stock location with an intake at the bottom with some baffelling to keep rain from soaking your air filter is probably a better choice for a daily driver. Don's system is designed to be changed over for use at the track, but he puts the filter in the stock location on the street to keep water out of the intake.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
beast94
DIY PROM
Aug 20, 2015 06:44 AM
drathaar907
Aug 6, 2015 04:20 PM
