heater hose routing?
Old Feb 28, 2005 | 12:06 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Does anyone have a map of the heater hose routing? I don't have my heater core hooked up right now, and would like to hook it up. My car is a '88 Formula 350.
Thanks.
Old Feb 28, 2005 | 12:56 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
How's this?
Attached Thumbnails heater hose routing?-c-my-documents-my
Old Feb 28, 2005 | 12:26 PM
ssean92's Avatar
Car: sold
anyone have it for a lt1?
Old Feb 28, 2005 | 12:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
try over at camaroz28.com
Old Mar 1, 2005 | 02:47 AM
stingerssx's Avatar
Gracias amigo! I'mma gonna check my ride, and see what I need.
I want a working heater in atleast one of my cars, then when I get it working in the Bird, I'll fix the Nova. Thanks again.
Old Mar 7, 2005 | 04:38 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
In the diagram above i am try to change the hose that is marked number one how in the hell do you get to the bottom clamp it is driving me nuts.
Old Mar 7, 2005 | 05:33 PM
Jade Grey's Avatar
Engine: 305TPI
I used 15" long needle-nose pliers to compress the spring clamp. I then moved the clamp downward towards the steel pipe and off the hose's end.
If it's not stock, use a gearless 1/4" mini-ratchet or a long box-end wrench to reach the worm-drive clamp.
Old Mar 7, 2005 | 05:44 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
This one is one of the ring clamps
Old Mar 9, 2005 | 05:14 PM
Abubaca's Avatar
Here's one I got here awhile back.
Old Mar 9, 2005 | 08:13 PM
Jade Grey's Avatar
Engine: 305TPI
Abubaca, that's a great diagram showing the routing of the factory oil cooler. Sometimes a vertical view of things can help.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
