Ati Procharger 3core install Firebird Trans Am
Old Apr 1, 2005 | 01:06 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Alot of peolpe had/have trouble with installing a ATI 3core IC on TA's/firebird. This shows how I did my installation.
1. Not doing any mods my IC had to be mounted to the left and not centered.
2. The IC was to close to the radiator and was blocking of the air passage.
This was because the 2*45 deg pipe on the IC outlet was hitting the fog light.
1 picture showing how I grinded the foglight house and the fog light (plastic)bracket, I also had to cut some plastic below.
Attached Thumbnails Ati Procharger 3core install Firebird Trans Am-c-documents-settings-niklas
Old Apr 1, 2005 | 01:11 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
2 picture: I cut the 2*45 deg pipe just behind the "neck", on the IC side.
Old Apr 1, 2005 | 01:12 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
3.
I used ATI's mounting bracket, just bent it some. I used the existing hole in frame.
Old Apr 1, 2005 | 01:14 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
4. other side......same way....
Old Apr 1, 2005 | 01:15 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
5. Center bracket.
Old Apr 1, 2005 | 01:17 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
6. the IC...........
I had to cut some plastic off the front along the IC that was in the way.......
/N.
Old Apr 3, 2005 | 10:33 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
gta324 I see you got yours figured out.
Old Jul 8, 2005 | 05:21 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Update...
Before I put the air scoop on car it ran at 182Deg F. Now when the scoop in on ( A home made one, litle higher than ATI's) it runs at 200Deg F. So it does affect the cooling..........
/N.
Old Jul 10, 2005 | 10:06 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Originally posted by gta324
Update...
/N.
Please keep the updates coming especially engine temps and also wouldn't hurt to know ambient temperature in F. Forget how to convert that damn celcius deal. Thanks .
Old Jul 26, 2005 | 06:47 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Hey thanks for the pics. Do you have a pic of the scoop attached and a front end shot?
Old Jul 26, 2005 | 04:27 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I made a custom scoop a little higher than the stock ATI... Give me a day or two and I will post some pictures.........
/N.
Old Jul 31, 2005 | 11:10 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
a new picture
Old Aug 2, 2005 | 10:16 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
how many problems do you have bottoming that scoop out?
Old Aug 3, 2005 | 04:51 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Bottoming never heard/seen that word before..... sorry.. What do you mean?
/N.
Old Aug 3, 2005 | 06:44 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Hes asking if it scrapes the ground
Old Aug 4, 2005 | 04:01 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
No..... or maybe I should say not yet...
/N.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
dhonda200
Aug 11, 2015 11:50 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
