CAI is in!!!
Old Apr 5, 2005 | 08:37 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
CAI is in!!!
I finally got all the parts for it and got it installed today. I love how it looks and I can feel a little difference in power since I put it in.
I do want to thank Roostmeyer for all his help with this. I wouldn't have been able to do it without his help with this. Thanks you were a big help. Here are some pics of it installed in the car. I still think I need to shave down the overflow line coming out of the radiator because it does bind up a bit and I dont want it to get pluged at all. Take a look at these.
Old Apr 5, 2005 | 09:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Looks good. Did you use 3.00" tubing? On my CAI I relocated the radiator overflow outlet to the side. I then plugged up the factory location with an Allen set screw.
Old Apr 5, 2005 | 09:23 PM
Gambit69's Avatar
Yes it is all 3 inch tubing. I think just cutting down the outlet coming out of the radiator a bit will do the trick. It looks to be working fine right now, I just want to be careful and make sure it doesnt get pluged up when the car starts to heat up and blow off the cap because of too much pressure.
Old Apr 5, 2005 | 09:59 PM
Car: 1989 GTA
Engine: 369 TPI
You are probably right with the 3" tubing. I ran the 3.5" tubing and needed to relocate the overflow outlet to obtain proper clearance. Allen
Car: 1989 GTA
Engine: 369 TPI
Slow upload and I clicked again.
Old Apr 5, 2005 | 11:53 PM
89formula350tpi's Avatar
Car: 1989 Firebird Formula
Engine: 350 tpi
Your CAI looks great, I have a similar setup but I still used the stock air duct from the mass air to the throttle body. I would like to add a piece in like yours. Could you tell me where you got the rubber piece on the throttle body that goes from oval to round. Also is that aluminum tubing or stainless. Thanks
Old Apr 6, 2005 | 01:16 AM
subliminal's Avatar
That piece is a 4 inch to 3 inch adapter available at any hardware store
Old Apr 6, 2005 | 07:52 AM
Gambit69's Avatar
Subliminal is right. I got it at Lowes and it wasn't that expensive. The tubing that I used is polised aluminum madrel bent 3 inch tubing.
Old Apr 6, 2005 | 07:58 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Oooooooo look at mister fancy pants with his new overflow tank and washer resevoir! Need me some of those.
CAI looks good, though I'd rather see actual reinforced silicone connectors in there. Good job on the fabrication though.
Do you tune your own chips? If you ever want some tuning done, all you have to do is drive to West Des Moines and we can work on it.
Old Apr 6, 2005 | 08:01 AM
Gambit69's Avatar
Hey bnoon. No I dont burn my own chips but I have wanted to have one done. Would love to get together sometime for some tuning. As for the overflow tank and washer tank, my overflow tank developed a crack at the bottom of it at the beginning of winter so I had to order a new one. Since I was getting this one, i figured I might as well get a new washer bottle as well.
Old Apr 6, 2005 | 09:59 AM
bnoon's Avatar
Did you order the tanks locally, or have them shipped from some place online? Price? Part numbers?
Old Apr 6, 2005 | 10:10 AM
Gambit69's Avatar
I ordered them through classic industries. I believe the part numbers were these
Overflow tank 82-88 G6353 15.95
89-92 G6354 17.95
Overflow New Cap 82-92 G7149 7.95
Washer bottle 82-87 G2116 20.95
88-92 G6314 28.95
Washer bottle Cap 84-87 G5037 3.95
88-02 G8312 5.95
Washer bottle fluid Screen 88-92 G7034 11.95
all of these part numbers and prices are directly from Classic Industries new catalog for 1967-2002 Firebirds and Trans Ams. Hope this helps.
Old Apr 7, 2005 | 10:10 AM
bnoon's Avatar
Thanks man!
Old Apr 7, 2005 | 03:28 PM
Gambit69's Avatar
Hey bnoon, are you going to be at the f-body meet this july 16th down in Norwalk? I was there last year and I plan on being there again this year and hope to have something new to share on my car by then but until then I will keep it a little secret. Let me know.
Old Apr 8, 2005 | 10:54 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Your CAI looks great! I have been working on the same thing for my GTA for the past week or so and I have a question for you. Where your MAF is connected to your polished aluminum that is a simple 3" to 3" connector correct? I notcied where your tubing runs down through the hole you cut you have the same 3" to 3" connector that I have, is that the same as the ones you used to connect the MAF? Did you makes the ones around the MAF shorter so you could see more polished aluminum?
Thanks!
Old Apr 8, 2005 | 07:05 PM
Gambit69's Avatar
The connectors that go to the MAF is one 3" to 3" connector cut in half so that half is on one side and half is on the other side. That is all that I did for mine.
Old Apr 8, 2005 | 07:08 PM
speed88's Avatar
Engine: 383
Thanks, thats all I needed to know.
Old Apr 26, 2005 | 01:27 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I love what you did man. I have been wanting to do the same. Where did you say you got the tubing from? Lowes? Also did you have to move your Charcoal canister?
Old May 1, 2005 | 08:38 AM
Gambit69's Avatar
Use this link if you need help with it. It helped me out a lot with doing mine.
CAI Install
Hope this helps.
Old Jan 17, 2006 | 07:30 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
How does this mod relate to the Air Cleaner Cut Out Mod
http://www.gmtips.com/3rd-degree/dox...low/warn-1.htm
Old Jan 17, 2006 | 07:45 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Am I right to think that it's going to get heat soaked very quickly?
Old Jan 17, 2006 | 08:27 PM
Gambit69's Avatar
is what going to get heat soaked?
crazyjoe
Jan 7, 2003 09:11 PM
Zepher
May 15, 2002 09:48 PM
SillyWabbit
Nov 17, 2001 10:55 PM
Zepher
Nov 15, 2001 11:51 PM
3.1EyeCandy
Aug 29, 2001 09:43 PM
