South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Racing Friday night!
Old Apr 6, 2005 | 09:26 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I have to go see what my car will run!
Seally has this Friday night:
TNT, STREET STOCK, JACKPOT
I'm thinking it would be good but I'm willing to consider HMP if someone wants to go there (never been myself).
So who's interested?
Old Apr 6, 2005 | 09:48 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
HMP's website says this for Friday:
Friday - April 15th / Gates Open at 5:00 PM
5 PM - 9 PM
Test-N-Tune... Run Wha Ya Brung!
Then
9 PM Til Late
IMPORTS-SPORTS COMPACTS- MOTORCYCLES
HMP is "THE HANGOUT!!"
Anyone know if they are still racing after 9 and if so will they let US race?
This is 20 miles closer for me so I would be willing to go there instead...
Old Apr 7, 2005 | 02:56 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I want to go. Sealy is great for practicing reaction times, launches, shifting. I need to practice and get used to my new setup. I think Barry might come too. We can run test and tune, or even street stock bracket race. It doesn't cost any more and you can still run T&T between or after you lose. Hey, you might even win a trophy.
Old Apr 7, 2005 | 03:33 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
So you would rather go to Seally?
Do you think Seally will be less crowded than HMP or do you prefer it for another reason?
Like I said I've never been to HMP. But I've always had fun at Seally.
Do you want to meet up before we go, or just meet there?
They open at 7 and I want to be there when they open. I'm guessing that with Friday night traffic it will take over an hour to get there.
Old Apr 7, 2005 | 03:42 PM
Car: '91 Formula
I much prefer Sealy. First, its closer and easy for me to get to from Katy, no traffic, just a liesurly cruise down rural I10. Second, it is more organized than HMP. They direct you to the proper staging lanes. Third, there is tons of room in the pits, not all crowded like HMP with people walking everywhere.
I think Barry may go, he lives about 4 blocks from me. We usually cruise out together. Just meet there at say 7 or 7:30. I have a bright red 91 formula, easy to see. I need to confirm with Barry that he is going
Also on a Friday night with no special event going, like this one, you can make as many runs as your car can handle. Not that crowded at all.
Old Apr 7, 2005 | 06:10 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Well those are severall good reasons. But the "It's closer and easy" doesn't apply to me, it is actually 25 miles farther for me (55 instead of 30).
So I guess I will meet you there at 7 or 7:30 tomorrow. Barry has seen my car before and I've seen his so we should be able to pick each other out. But just in case, where do you normally hang out/pit?
Let me know what Barry says.
Old Apr 7, 2005 | 08:03 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Transmission: TH-350
Axle/Gears: 3:73
Barry says I'm goin on the 7th. Tomorrow. Probably be there about 6 p.m. I'll find ya, or you'll find me. Grey just like the avatar.
Old Apr 7, 2005 | 08:59 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
[i]Probably be there about 6 p.m. I'll find ya, or you'll find me. Grey just like the avatar. [/B]
When do they open the gates? I think I saw that the racing starts at 7:00.
My avatar looks suspiciously like my car too.
Old Apr 8, 2005 | 06:46 AM
Car: 1985 IROC Z-28
Axle/Gears: 3:73
Gates open at 5 every Fri.
Old Apr 8, 2005 | 10:51 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Should of brought the ET streets...
I was there, but I didn't see any other third gens.
I'm not too happy with the results. My traction sucks. My best times were after retarding my timing to the point that the car would hardly run. That cut down on my wheel spin enough to get my best run of the night. (best 60ft and ET, I lost a couple of MPH) But it still spun off the line and in 2nd gear. I never had to use 3rd gear.
After a lot of test runs I think my mufler is my biggest bottleneck. So it is getting movind to the top of my mod list.
Old Apr 8, 2005 | 10:59 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
OK, the jpg didn't upload properly the first time so here it is.
Overall I guess it's not too bad. I used to have to use N2O to get times like that.
Old Apr 9, 2005 | 04:12 AM
Car: 1985 IROC Z-28
Axle/Gears: 3:73
All set to go..Get to Larry's, and his trans mount bolts are stripped out. Got it fixed (Helicoils)Will go this P.M. I didn't need to get beat THAT bad.
I'll be there soon (low 8' )......sooner than you think.
Old Apr 10, 2005 | 10:13 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: Should of brought the ET streets...
Sounds to me like the priority would be to get it to hook up! so U don't have to detune it!
Never got out of 2nd? What gear are U pulling?
For that matter, what's the run down on your engine + drivetrain anyway?
Old Apr 10, 2005 | 07:46 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Re: Should of brought the ET streets...
Like I said; "Shoulda brought the ET Streets" I think they will get my traction back to a reasonable level. The Kuhmo VictoRacer's I normally drive around on just aren't designed for getting the best launch.
Gear? 3.31:1 in a Dana 44, with a 7,500 redline and a THD 400, 4000 stall. Mathmatically (assuming no torque converter slip, but there is actuially a lot of that) it should do 112MPH in second gear.
Engine is a SBC 377, 11.3:1 compression, CNC Ported AFR 210's (2.08/1.60), Victor Jr, 900Cfm TBI, Hooker Super Comp Long Tubes, .580/.600 253/260
The reason I think my muffler is a bottle neck is because my air filter SHOULD be, but running without it had NO effect on my times. The headers have two 3.5" collectors but it is choked down to a single 3" OD muffler.
Old Apr 10, 2005 | 09:51 PM
Car: '91 Formula
Sorry man, I was ready to go Friday night and was changing the oil and noticed that on bolt had came out on my recently changed transmission mount, and the other one was about to fall out. Had to pull everything off and helicoil an remount. Barry helped but by the time we finished at aobu 9 pm it was too late. Lets go next weekend.
Old Apr 11, 2005 | 07:01 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
This weekend is no good for me.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Derrick86
Oct 1, 2015 05:12 AM
gord327
Sep 29, 2015 10:18 PM
