Northern California Discussion board for Northern and Central California.
how much HP at the dyno?
Old Jun 16, 2005 | 12:00 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
time to guess how much hp is everyone gonna make at the dyno next month..
i think ill make 280hp
eric - 250
del - 270
terrel - none lol
caddilac (forgot real name) - 180
vindeezil - 260
will - 200
Old Jun 16, 2005 | 12:03 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i take offence to that
your no way at 280 im gonna say 270
and me at 260
Old Jun 16, 2005 | 09:09 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Are you talking to the wheels?If so I don't think you guys are even close.I think if it is to the wheels
Travis 220
Eric 219
Del 235-240
Vin stock? 210
Cadillac 190
Will 200
Me(might bring our 87 runner after new stroker motor 160
Alex's car with all his mods put down 243 to the wheels,which is 291 @ the flywheel.
Old Jun 16, 2005 | 12:21 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
hahaha if I was to bring my turdgen then I would say 175-205rwhp
I may take the vette so I say 300-320rwhp
travis eric what are you guys thinking you have hardy any mods and you in the high 200's no and im sorry I don't think a super ram/stealth ram is gonna give you 60hp I think a stock tpi(350) only puts like 180-190 to the ground
Travis@220-240(pre stealth ram)+15 for stealth ram
Eric@200-225(pre super ram)+15 for super ram
Del @240-265
Will@200-240(we're gonna see if the cross fire is resticting or not cause his motor is rated at 290hp)
Alex@290-310(wasn't his old tune dyno'd at 29?)
Old Jun 16, 2005 | 05:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well i was figuring stock was 200at the wheel and with full exhaust and stealth ram(it will be on for the dyno) that its a good 80hp at the wheel. espeically with the timing and fuel pressure to play with. its been shown that just a stealth ram swap on an otherwise stock motor has gone 60hp over stock at 5200rpm.
Old Jun 16, 2005 | 06:02 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Don't the l98's put out 225 at the fw?20% loss would put that at 180,+ the, say 60 hp would be 240 right?I don't think the stealth will boost it that much at all though,I could be wrong but...The stock heads still won't be able to push that much cfm through,and the cam?Why would Erics car put down so much?
Old Jun 16, 2005 | 07:46 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
2 things
drivetrain loss cut in half i have a 19lb flywheel, and my clutch is 22lbs a stock torque converter full of fluid is over 50lbs so less rotating mass, not to mention its a more efficent way of putting power to the ground.
and good old factory freak......
Old Jun 16, 2005 | 09:29 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I think most stock L98's put between 185-200 at the wheels.
Every car runs different as we've seen.
But I wouldn't go by factory #'s and an exact 20% loss.
I would go more off the #'s you've seen at the track (MPH or ET) and calculate your estimate based on that and your weight to get a rough idea.
I see your point Steve on that seeming like gaining a lot from factory, but take Alex's car for example, 240ish at the wheels, running about a mid 14.
Obviously Travis/Eric are faster and will have even more power now.
Not sure who will benefit the most now from the diff. ram intakes, but I know they should have much higher #'s than me.
I have to give Eric the slight advantage pre-intake stage because of his mph.
He won't have to worry about not being able to perform like at the track, the machine will do all the work.
On that note. .. I think I'll be around 250 at the wheels.
Travis/Eric - around 275 (after intakes).
No point to guess others that I haven't seen any evidence of power yet.
1 month to go!
Old Jun 16, 2005 | 09:32 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
I'll be lucky if there are any numbers near 180 on my car.
Does anyone think we will have time to make adjustments between trials? I want to do two things: Compare ratings with timing at 8* and 3*. I also want to see what the stock PROM does in comparison to the new PROM.
Will that be possible?
Old Jun 16, 2005 | 11:26 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yup
Old Jun 17, 2005 | 01:13 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Thanks for rememberin' me Trav
I certainly hope that I'm close to where your at bro
And to the reply above, no, I'm not stock
Old Jun 17, 2005 | 01:35 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Axle/Gears: 8.5" 10-bolt 3.73 Posi
260-270 hopefully. I might splurge on another mod before then though. Maybe I'll do a cam before it too.. seeing as now I have to replace my water pump
Old Jun 17, 2005 | 10:17 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
That's right,I forgot you were building up your engine.
Old Jun 17, 2005 | 10:21 AM
Cadillac's Avatar
Tony, a lot of questions:
  • How long will it take to do one trial?
  • How long will they give us between trials?
  • Will we have to do all runs at one time or can we back out and try again after a spell?
  • Will your car be ready with a new water pump?
If we knew the answers to the first three e could estimate how long the day will be.
Old Jun 17, 2005 | 10:54 AM
Car: '72 Chevy Nova
I'm not sure how long, but he said that starting at about 930, it could take up until 4-5 o'clock if there were a lot of cars, around 20 or so.
I'd imagine that it doesn't take too long.
All three pulls are at one time, but maybe if we talked to him we could do them at different times, but I don't really know why we would want to.
I'd imagine the dynos would be kind of continuous, one car finishes and the next comes on board. I'd imagine there will be a nice lunch break though.. that's where the BBQ comes in!
Yes it will be, and maybe a Lloyd Elliot cam. The WP is getting replaced next week. It'll also have a little bit of paint work done, including shiney tail lights!
I would expect the dyno to finish somewhere around 3-4, because I don't think we'll have quite 20. After that we can eat BBQ or go cruising or what have you! We'll decide at the dyno day what to do.
Old Jun 18, 2005 | 01:51 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I vote for BOTH!
Old Jul 12, 2005 | 01:56 AM
JesasaurusRex's Avatar
you guys tell me how accurate desktop dyno is and ill let ya know
Old Jul 12, 2005 | 01:57 AM
Car: '72 Chevy Nova
Not very accurate at all
it's mostly useful for tracking the changes between mods, the differences they make, rather than tracking actual HP/TQ readings.
Old Jul 12, 2005 | 02:03 AM
k not guessing then
oh and anybody interested in a zz4 cam
208/221 @.050
.474/.510 lift w/ 1.5 ratio rocker
112 lsa
or a comp custom grind solid roller
264/272 @.050
.649/.649 lift w/ 1.6 ratio rocker
107 LSA
have cam card for that one
also have a quiet gear drive for an OEM type hydraulic roller cam
also got 2 sets of hyro roller lifters
probably some other stuff too just ask
Old Jul 12, 2005 | 02:04 AM
ive heard like 50/50 on the desktop dyno thing being accurate or not its weird
actually know what guys we could test it now, put ur motor into desktop dyno and see what she says, double check it when we get to the dyno
Old Jul 12, 2005 | 02:20 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
i'll probably put down a whopping 100 to 120 horses (i forget if these things are 140 or 160 from the factory)
YEAH BABY
OUT OF MY WAY
Old Jul 12, 2005 | 02:29 AM
Old Jul 12, 2005 | 10:51 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
You guys forgot about me
I think ill be making around 200HP or maybe a little more if its a good day. For the Dyno run is it first come first serve? Im going to work on my car and try to fix my problem
Old Jul 12, 2005 | 11:09 AM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
From my experience it takes almost as long to get the car up the ramps, lined up, strapped down, and plugged in, and backed off as it does to run the load test. 20 mins if everything runs right, maybe as much as 30-40 when all is said and done because the engine needs a few minutes to cool after each test. There is only fan blown forced air cooling the radiator - so cars are notorious for overheating during a dyno. Watch those temps !
No set time, maybe 3-5 mins. . . plenty of time for you to make a timing change, or recal your VE Adder tables at the least. For those of you who have laptops. DATALOG the entire session! It's invaluable info.
-Caddy and other TBI'ers : Watch those injectors, especially if your still running stockers - expect to run out of fuel (stop making power) around 4K.
As stated above, it takes almost as much time setting up, and down as it takes to run the test, maybe more. So any changes are best done between runs.
If there are 16 cars -- averagin' 30 mins each. . . I'm callin the day goes from 9-5. And unfortunately, unless someone drives my car - I'm not making it. Prior plans are unescapeable.
-Good luck everyone.
Old Jul 12, 2005 | 04:56 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Oh I'm sure someone could do that for you no problem
If it was me you might need rear tires a little sooner than planned hahahaha
Old Jul 12, 2005 | 05:08 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Don't think I'll be making it as I haven't found a decent car yet and don't want to take the runner.
Old Jul 12, 2005 | 08:29 PM
Car: '89 GTA
Thanks for the info. Alex, I figured the setup was the most time consuming.
I figure there will be some flakes, so who knows, maybe only a dozen or so will be on the dyno.
Bummer you can't make it since we're actually near you this time.
Are you going Dizturbed?
. .. and it's 140hp. about 115 to the wheels, yah baby.
You guys forgot about me. I think ill be making around 200HP
Ramair21 - what mods do you have to that tbi?
the dyno would show about 140rwhp if it was stock.
What hap'd to that Camaro you were eyeing Steve?
Hope to see some of you new folks there!
Old Jul 12, 2005 | 08:54 PM
oh guys i almost forgot, i also have a moroso 6 quart oil pan perfect for 82-92 camaro, doesnt interfeer with the crossmember and can retain stock Y pipe, 1 piece rear main seal and passenger side dip stick
lemme know if any of you guys are interested in any of my stuff so i can bring it with me
Old Jul 13, 2005 | 01:07 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I got the open Element, Hooker header 2055, 3" cat back, shift kit, AC delco rapid fire, Taylor wires, corvette servo, fresh tank of high octane gas, 170* stat, 195 fan temp switch. Nothing really but it takes off when you open it. So maybe around 170 then if you think ill get 140 stock
Old Jul 13, 2005 | 09:13 AM
Car: '72 Chevy Nova
I'm really hoping to see between 260 and 270 at the wheels.
What im REALLY curious about is my powerband, from a stock muffler'd LT1 dyno curve to my straight piped dyno curve. It will tell alot.
Old Jul 13, 2005 | 09:41 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Can't get ahold of the guy.
Old Jul 13, 2005 | 12:40 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
eh, its close - but no closer than Sac is from Fairfield. No sweat - when steve finds a car, and deezl is up and running we'll try again - maybe hit the one in Fairfield since it's literally right around the corner, also I'd like to see what the difference between the mustang dyno and dynojet numbers are.
Old Jul 13, 2005 | 12:58 PM
kairles's Avatar
Engine: 383/LGX
I hear the mustang dyno's are closer to real world #'s than dynojet, which tend to be some what inflated #'s
Old Jul 13, 2005 | 05:44 PM
Car: 92 RS
Engine: a slow one
Yeah I'm going, but I'm not going to dyno my car, it's still completely stock so no need since I never plan on modifying the 6 banger.
I'm just gonna run the 6 while I get the rest of the car sorted out suspension and cosmetic-wise, but money problems keep cropping up out of nowhere and killing my gameplan.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
