Can anyone reccomend a chip?
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Hey, i just got a 91 tbi firebird, she is bone stock, I am looking into getting a chip to help free up some power, just had a few questions. Does the chip actually work? If so should i wait until i have done more modifications to the car, or will the gains be the same even if the car is not modified.
Car: 1991 Chevy Camaro
A chip will definitely help even if the motor is bone stock. The stock tune on these cars really isn't all that great to begin with. With each modification you do, a new chip will probably be needed, it all just depends on the modification done. For example, install an open element, probably won't need a new chip, put in an LT4 cam, you will absolutely need a new chip.
But, first things first, stay away from those Jet, Hypertech, etc. off-the-shelf chips, as well as E-Bay "custom" PROMs/chips. They do nothing, absolutely nothing. All they do is make nice $150 paperweights (trust me, I know). All those chips do is add a little timing and fuel, that's it.
Now, for your options. The best option, by far, is to just do it yourself. The parts needed aren't very expensive, and all it really takes is patience and the know-how. Check out the stickies on the DIY-PROM board for some great write-ups on beginning to burn custom chips. It's all going to look like gibberish at first, but it will slowly sink in.
There are some other options, though. Many shops that have chassis dynamometers (dynos) offer custom dyno tuning. It's hard to find shops that still offer custom chips for our ECMs, but they are still out there. I have seen mixed reviews on dyno tuning, though. Your other option would be to have someone else burn you a custom chip. That usually requires you to datalog (how to datalog is covered in the PROM burning guides), send that info to them, and then they will send you a custom chip. An example of this would be TBIchips.com. I have seen mixed reviews of him, as well.
Car: 1991 Firebird
Well that answered my questions, i remebered seeing an ad in GM hightech performance for a company called TBIchips, i looked it up and for the price, and the suggested gains i think i just might have to order one, they cost half as much as ones i have seen in catalogs. When checking his stuff out on ebay, it said that insalling this chip will disable the 110-115mph speed governer. Do both auto and manual have this or just auto?
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
They both have the limiter.
I would wait on the chip, put an open element on, then full exhaust and some rear end gears, then maybe think about the chip (unless of course you do it yourself, in which case you could pick up some power). The chip is just not a good bang for your buck deal. You WILL feel the difference with an open element and full exhaust, it will be like a night and day difference in your car.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah i would recomend the open elemnt and full exhaust also. i would recomend the edelbrock tes headers, very nice response. those two do make a world of difference!!
Car: 1983 G20 Chevy
Then burn your own chips, it is well worth it. On my old 355 I went from LAME to FAST and TAME by burning my own chips. It is the ONLY way you are going to make a modified engine run up to its potential. ANYTHING that changes the volumetric efficiency of the engine needs to be calibrated for.
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Welcome to the boards. I see you are a newer member so I figure I'd let you know about the
function available to you. Just type in the keywords you are looking for (which, for what you are asking about in this thread, you'll find somewhere in the neighborhood of 4,238,095 threads covering what you are looking for. Since I know your topic has been covered QUITE a few times, I'm sure you'll find the info you need, so I'm going to close this thread. Good Luck!!
Bruce (90RS305)
function available to you. Just type in the keywords you are looking for (which, for what you are asking about in this thread, you'll find somewhere in the neighborhood of 4,238,095 threads covering what you are looking for. Since I know your topic has been covered QUITE a few times, I'm sure you'll find the info you need, so I'm going to close this thread. Good Luck!!Bruce (90RS305)
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
