Possible Useful Link for ThirdGen Wiring -
Old Aug 13, 2005 | 05:59 PM
Vader's Avatar
http://www.autozone.com/servlet/UiBr...3d801eef19.jsp
Old Aug 16, 2005 | 10:04 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Thanks Vader. That's a great resource!
Old Aug 16, 2005 | 10:28 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
Agreed! Thaanks!!!!
Old Aug 25, 2005 | 08:23 PM
Batts's Avatar
Hi, Vader I had talked to you about the electronics on my car, now if you can help me with an engine swap? I have a 1983 Trans Am original 305 Cross-Fire Fuel Injected, I want to swap it with a 350 Tuned port motor from a 87 GTA. Motor is complete, including pulleys, alt, a/c, p/s, exhaust manifolds, dist, engine harness, computer, complete injection, mas air sensor, and motor mounts. Will this work will I need to change anything else?? Fuel Pump, exhaust system, catalytic converter?
Old Oct 20, 2005 | 11:46 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Here's a very usefull site for tpi functions and swaps has all ecm pinouts and some other usefull info.
http://chevythunder.com/
Old Oct 25, 2005 | 09:33 PM
AegisJones54's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 5 Speed
Those diagrams are for a Firebird.
I just had a question about those diagrams. I have a 91 Camaro RS 5.0L TBI. How will these diagrams compare to my car since they are for a firebird? I've been told that they are basically the same car. It would make sense though that the differences between them would be small/electrical.
Please help, I'm getting ready to pull my dash to swap it with a 4th Gen.
Old Oct 30, 2005 | 02:27 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
VERY useful link!
Thanks Vader!
Sincerely,
Kurt
Old Dec 12, 2005 | 05:32 AM
mcbuff47's Avatar
Car: 88 bird
Transmission: 700 R-4
88F/Bird wiring diagrams
Vader,Thanks for the reply. My engine is a carbureted 355,and the high stall converter is locked up manually by a modification to the valve body involving a plastic check ball in a passage under the lockup switch.Works well,lockup is very firm,but not excessive.High Tech Transmission in Houma,did extensive modifications to my trans,and it has taken a good trouncing over the past two years,and still works just like it did when installed.
Thanks again,
"The Accelerator"
Old Dec 27, 2005 | 07:31 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
where can i find one of these for a 96 firebird? lt1
Old Mar 20, 2007 | 12:03 AM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
thought i would add this here as its mostly wiring related.
i did a quick read through on it & it seems pretty complete.
how to convert from manual to power windows on your thirdgen,.
http://www.p71interceptor.com/thirdgen/powerwindows/
Old Aug 11, 2007 | 05:47 PM
Brisco's Avatar
Re: Possible Useful Link for ThirdGen Wiring -
Hello. Do any of you know where I can get the pin outs for the engine to under dash wiring harness. I already have the pin outs for the ecm and have all that worked out but It is the harness that would connect the computer and the engine wiring harness to the underdash wiring harness. Please help me out if you have any information. I am stumped right now.
Old Apr 5, 2008 | 09:14 PM
Terrysz's Avatar
1987 iroc z z28 305 tpi 700 r4
i have a 1987 iroc z its a factory automatic car but i cannot find the torque converter lock sensor plug im not sure if its been cut off or it needs an extension plug can anyone help me with a wiring diagram for my car??
Old Apr 5, 2008 | 10:30 PM
Did the diagram in the first post in that thread not help at all?
Old Jul 17, 2008 | 02:13 PM
NBx33's Avatar
Car: 2006 Charger R/T Daytona / 87 Iroc-
Engine: Hemi 5.7l / 4 bolt 350
Axle/Gears: 2.82 / 2.73
Wow i know i revived a old thread but the author of chevythunder deserves a
Award.
That was by far the most helpful link PERIOD on any forum.
Old Aug 16, 2008 | 02:05 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
AWESOME!! thanks a ton! wish i had seen this earlier, but it will still answer tons of questions. huge thanks!
Old Oct 28, 2008 | 01:44 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Holy crap, I work at Autozone and I didn't even realize these resourses were available! Thanks!
Old Nov 28, 2008 | 03:01 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
thank you - thank you - thank you!
Old Nov 29, 2008 | 11:52 PM
slaman37's Avatar
Car: Current project is 70 Monte Carlo
Engine: 350 TPI (SD)
Transmission: 200-4R
Axle/Gears: 3:73, 12 bolt Limited Slip
Ok, I looked through a couple of the diagrams from up top. It looks to me that if I can find a 90 or 91 3.1L V6 engine harness, I can use it for my basis for a TPI retro fit. I would only have to add a couple injector plugs and do away with the temperature switch for the tranny? This maybe easier than trying to repin a tbi harness? Yes, no any thoughts, thanks.
Old Dec 6, 2008 | 10:32 AM
Car: 1990
Axle/Gears: stock
try these guys at Automotive Hobbyists (info@ahdol.com) - i paid 11.99 and i got an entire colorcoded set of diagrams for the entire car, which is a 90 camaro. does not matter what model they give you everything for that year.
EVERYTHING!
best 12.00 i ever spent on the car. and it is e-mailed to you so that you download it and only print the pages you need.
Old Mar 24, 2009 | 07:24 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
is the link working for the diagrams anymore? it shows as busted to me.
Old Mar 25, 2009 | 09:51 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Unfortunately, they now require you to register. Get to a point and select "Repair Guides", and they'll have you register. Then you can see all diagrams for all 82-92 of the model you've selected as your car.
Old Jun 28, 2009 | 10:09 PM
mechanic58's Avatar
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
^^^ That link no longer works btw...
Old Jun 28, 2009 | 10:41 PM
Yeah, I can't imagine why? The link was valid in 2005.
Old Aug 3, 2009 | 11:42 AM
wiseroc-z's Avatar
Car: IROC, 76 Cutlass, Durango
Anyone keep the info? We have some seriously foobarred wiring in our LeMon's Camaro due to too many kills switches, car alarms, remote start, and the like...
Old Aug 3, 2009 | 04:56 PM
mechanic58's Avatar
Car: 1991 Z28 1LE
Engine: LB9 305
I can only imagine what that **** must look like. lol...its giving me anxiety just thinking about it.
Old Aug 5, 2009 | 02:46 PM
hulkster1's Avatar
Car: 91 camero
Transmission: manuel
Axle/Gears: 5 speed
i have a question for you this is my first time on this website i have a problem with my car it starts and when i turn it of and try to turn it back on it hezatates to start then i wait a lil bit then it turns on would you happen to know wat the problem is i got a new battery and alternator would you happen to know
Old Sep 30, 2009 | 07:40 PM
menace156's Avatar
Link doesnt work.....for me at least.
Old Jan 18, 2010 | 12:17 AM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
me neither
Old Jan 29, 2010 | 08:30 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
that link hasnt been good for a while, Autozone's website has really stripped useful info for our cars, my uncle is a manager for pep boys service side and got me a whole lot of diagrams(dont know if its complete) but i will scan them and post a new thread, maybe it will come a new sticky
Old Jan 29, 2010 | 09:50 AM
Caveman305's Avatar
Engine: L03, LB9
For anybody needing thirdgen wiring schematics, i have a full set on my computer ready to send to anybody who wants them,
it is the 89 model year wiring for 2.8(dont know if its the same for 3.1),5.0 E,5.0F, and 5.7
also includes body wiring and ac/wiper washer assembly, i have 9 pages total but if you only want your motor it would be 6
if the mods would rather me post it in a thread i will be happy to do that as well
got them thanks to my dad and uncle back when i was 17 and just dug them up today
Old Feb 22, 2010 | 11:13 AM
jeremyseanholde's Avatar
I am trying to wire my wipers to a togal switch can anyone help?
Old Mar 13, 2010 | 10:31 PM
munch4lf's Avatar
Help with speed sensor wiring
ok, so heres the story... I started an engine fire and fried the computer wiring harness to the girlfriends 1986 Carberated 305 HO along with burning lots of other components...long story short we went back to vacuum controled while upgrading the cam, timing chain and cover, valve job, intake manifold, holly carb, valve covers, headers and new vacuum distributor...now we have an issue with the speedometer not working (since it was computer controlled) so...is there a way to bypass the computer and hook it up directly or is there another option besides going back old school with a cable on the speedometer?
Old Mar 13, 2010 | 11:35 PM
mos68x's Avatar
Re: Help with speed sensor wiring
Be sure that you have electrical speedo first, if you do then pull the dashboard back and be sure that the VSS buffer box wasn't damaged second. If the box still looks good visually then check your wiring behind the engine going to the drivers side. The wires for the speedo should be running that direction through the C100 at the firewall. With you having a fire my first guess would be that you burned up the wires coming from the transmission going to the VSS. You'll probably just have to splice a wire or two and have it back running again.
Old Mar 14, 2010 | 09:15 PM
munch4lf's Avatar
so the fire never got through the firewall behind the engine but burnt up the cable going to the transmission (the speed sensor cable that runs to the computer which we pulled out). The speed cable going to the cruise control is intact and the wires going to the c100 were all ok...so in order to get it running I have to splice some wires? to where? I think I have to get a new sensor clip also since it burned up...
Old Mar 14, 2010 | 09:31 PM
mos68x's Avatar
trace your wires from the speed sensor to the c100 and be sure that there aren't any damaged wires, if there are replace or repair them.
Old Mar 22, 2010 | 10:51 PM
jimeheat's Avatar
Car: 1988 Firebird Formula , 2 minivans
Engine: 305 TBI , stock
Transmission: auto - stock
Axle/Gears: stock
The link won't work for me ...
Old Mar 22, 2010 | 10:58 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Yes, it hasn't worked for quite a while now.
Old Dec 19, 2010 | 12:56 PM
fast z28's Avatar
Car: 1983 camaro z28
Engine: 305 HO.
Transmission: A5- 5 speed
Axle/Gears: 3.73 gears
VACUUM GAUGE INSTALLATION
hello, i need some help installing a vacuum gauge in my 83 z28.
My problem is, i cant find the 12v dash lights, and the 12v ignition switch under the dash, is it a fuse or what?
http://www.princessauto.com/componen...438_manual.pdf
Old Feb 7, 2011 | 11:44 PM
hjh916's Avatar
need help with wiring.
I put my 89 305 and harness into a 91 that had a v6 in it. Now I am having wiring trouble. My tbi injectors are giving me trouble. And my electric door locks not working, and acc fuse keeps popping.
are the harnesses not plug and play changable?
Old Feb 28, 2011 | 08:11 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Through work, I can look up any wiring diagram in mitchell. If someone could narrow down how interchangeable the wiring is for third gens, I can try to put them here for all to see. Its just a lot of diagrams to copy and paste.
Old Mar 4, 2011 | 12:06 PM
hjh916's Avatar
Thanks for responding. How can I get that info? Is it a site I can get on to?
Old Mar 7, 2011 | 07:56 AM
dellman83Z's Avatar
Its through mitchell, but how I need to look it up by exactly what it is. If you need one, just pm me with what you have and I will get them for you.
Old Mar 13, 2011 | 04:46 PM
hjh916's Avatar
I need the diagram for the plugs that are going to the ecm from inside the dash for a 91 rs v6 and also an 89 rs v8 305 tbi.
If I had the diagrams for bothe cars I could probably figure it out.
They seem to differ and I'm stuck.
Thanks for your help.
Old Apr 5, 2011 | 04:49 AM
mudmaster's Avatar
could you please send me the diagrams as well bro. I have a back halved 91 bbc blown ,nitroused t.a. on the street and am just looking for the gas gauge wire so i can hook up my fuel cell sending unit.. i was hoping for 80 mpg but i missed my mark..... grin. trying to find wire color,,, maybe purple?
Old Jun 8, 2011 | 03:45 PM
ocgael's Avatar
I have an 89 camaro 2.8. It appears as if a wire is missing from the rear of the alternator. There is just a connector with no wire. Do you know what this wire would do? The guage just shows an 8 not the 13 it used to. I am at a loss because I can't find a disconnected wire. Please help??
Thank you ocgael
Old Jun 21, 2011 | 06:04 PM
dillydog73's Avatar
hey,
im new on this website but i was wondering if someone could help me with my headlights?
i have a 1992 firebird and the headlights go up and make a klanking noise then when i hit the down button they klank more but dont go down. so i dont know?
Old Jan 9, 2012 | 07:17 PM
fastllort's Avatar
www.ssconnectors.com has a bunch of pigtails available.
They also custom make stuff too.
Old Jan 17, 2012 | 10:01 PM
jerrypittman's Avatar
Car: 81 c10
Engine: small block
Transmission: th350
Axle/Gears: 513
can any body answer this question why does my 07 4l60e take off in third i have just went through this trans with new lip seal kit and clutches wire harness and solenoids i have checked to make sure solenoids and harness are correct
Old Feb 21, 2012 | 05:04 PM
acer1864's Avatar
Car: 1985 Firebird
Transmission: A4
Axle/Gears: 9b posi
I get a generic AZ page
Old May 13, 2012 | 06:05 AM
91RSLS376's Avatar
I am putting an LS3 into a 1991 Camaro, and the engine comes with the GM harness. I need a wiring diagram for the wires that come out of the steering column, colors and function. Can someone please direct me to this information.
