Firebird interior to Camaro... any issues?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Except the dash, the entire 86 Firebird interior (including console) is going into my friend's 85 Berlinetta. The radio pod will have to be modified, but aside from that will there be any issues?
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The metal mounts in the doors that the arm rest attaches to/rests on is different. Can take that piece out of the donor cars doors by drilling out a few rivits.
You might be in for a nightmare with the radio pod unless you are good at fabbing up stuff like that.
Can't think of anything else.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Engine: SBC, LS-x
Originally posted by 91banditt2
the door arm rests from a camaro will directly bolt into a firebird
Engine: 5.7 HSR
An 86 won't unless you change the brackets I mentioned.
Car: 1985 Trans Am
Engine: LB9
The only thing that could make the door panels not fit is if they were GTA deluxe door panels on the Firebird. Those have a much different bracket. Otherwise, the bracket is exactly the same.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
halfinchwrench, you must have the deluxe option door panels. The standard door panels for camaros and firebirds share the same inside handle.
Engine: SBC, LS-x
I thought they were all like that from 86 and up. Before that the door trim was the same on both cars. I must be using the GTA as a firebird door reference.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
