DIY TPI Gasket Sets
Old Aug 26, 2005 | 10:54 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
DIY TPI Gasket Sets
Well for the few who actually paid attension to any of my posts here is a bit of an update.
I went and got the intake gasket, manifold set, from autozone today.
I told myself, i will not buy another runner gasket set. And iam keeping to it.
SO i started pondering.
Drank a couple beers.
then it came to me,
I can mark out the model on cardboard. The kind boxes are made from.
And cut that up to the size and shape needed. When applying the gasket. Use a lot of copper gasket spray sealant. As it helps keep the gasket water resistant. And helps in the long run many times over.
but after i finished a mockup set of gaksets, and set them up to the plenum, and checked it out. I'd say, that once the cardbaord compressed and stuff. It'd be a pretty stout seal and everything.
Has anyone on here even done this before?
Old Aug 26, 2005 | 10:58 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
I have made my own gaskets before for other appilications, but I went and bought gasket paper to use.
Old Aug 26, 2005 | 11:51 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
yeah, use gasket paper. That's what it's made for. $8/roll at advance.
Old Aug 27, 2005 | 10:05 AM
ChevyRacer's Avatar
Engine: 355 TPI
they didn't have gasket paper, except the kind with metal inside. I catn cut that stuff..
So i made my own gaskets.
I used Poster board carbcoard. The solid stuff for my gaskets.
Then i added a laminent, thart when heated, doesn't really melt it gegs sticky. So with the blow dryer i firmed up the lamiant, and made sure the gaskets were straight.
but the key really is the copper sealant, makes the seal from the start, then when the engine gets warm later, the laminant will melt, and seal it for good. No questions asked.
its a nice cheap, FREE!! gasket and only took 2 hours to perfect. And size the bores properly.
PS: i used door drill bits for the bores, made for a nice clean circle.
Old Aug 27, 2005 | 10:57 AM
Engine: LB9/383
why are you so against using a pre made gasket?
Old Aug 27, 2005 | 11:30 AM
ChevyRacer's Avatar
Engine: 355 TPI
had to order them, and they cost money.
Old Aug 27, 2005 | 11:33 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'd rather have 2 hours of my life. Good advice if you're in a pinch though.
Old Aug 27, 2005 | 11:43 AM
ChevyRacer's Avatar
Engine: 355 TPI
well if i coulda went and bought them, i woulda. but no dealership had them. and autozone, had to order them, they said since its the weekend, they'd be here monday.
I said screw it, and asked for gasket material. And to my luck they didn't have the proper material.
But the way i made mine, it'll be as good, if not better then stock.
Plus it was alot easier to port match the gaskets to help flow. Any difference in the size of the bores is bad for flow.
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
Sanjay
Aug 12, 2015 03:41 PM
