What The Crap Just Happened?
Old Oct 3, 2005 | 06:36 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Axle/Gears: 2.73 Posi w/Disc
OK...over the last two weeks since I put my new audio system in, it was obvious that my alternator was not able to keep up with the current demands of the amps. When I put the system in, I ran a 0 gauge wire from the battery (-) to a solid ground and did the same in the rear for the amp grounds. I remembered today that in my haste I neglected to run an auxiliary ground from the alternator to the battery (-). I did this today and saw something strange:
The charging system voltage now hangs at a solid +14V with the car on & the amps off. This is ~0.2V higher than before the ground upgrade. The weird part is, before the upgrade, hard bass notes would drop the charging system voltage to ~+12V. Now, the same songs at the same volume drop the voltage to ~+10V.
What the crap happened?
Old Oct 8, 2005 | 08:52 AM
Vader's Avatar
It seems that you have eliminated some resistance in the amplifier circuit, and have generally improved the gounding. The system voltmeter is now reflecting a more accurate reading.
Old Oct 8, 2005 | 09:25 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Makes sense. Also, less resistance means maybe the amp is working more at its full potential? Does it sound louder, better, cleaner?
Old Oct 8, 2005 | 10:56 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
I've tried listening to see if it sounds louder and/or better, but there's this one rattle that's driving me crazy. I thought the sub was blown, but then I realized there was a correlation between many different elements which must be present in order for the rattle/buzz to occur. I might sort it out today...probably passenger's side sail panel -- I don't have the screw in place.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
racereese
Oct 3, 2015 03:46 PM
