Maf problem
Car: 82 trans am,Project
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
Maf problem
How does my car operate if it has a broken maf sensor?will the ses light come on? how about performance?
thanks..
thanks..
Car: Firebird
Engine: 2.8
Transmission: 5spd
no.it drives..you will just have the engine light on. and when you let off the gas you will feel it. itdoesnt drive that much worse w.o it. Mine is off becaues its bad and im waiting to buy another one
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
I have taken the plug off the maf, and the cars run the same as when its on,but the ses light does not come on when the plug is on...what fault code is there on a broken maf?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
firebirdjosh: If you leave the broken MAF connected it will barely run. However, disconnect it, and the computer uses the default MAF values for the throttle position, so it runs alright
Car: 86 T/A
Engine: HSR 355
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
