Post your SINGLE exhaust pics!
Old Oct 5, 2005 | 09:30 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Alot of people on here seem to be going for the true duals, or dual exhaust theme. What about the guys/gals on here going for single exhaust. Me personally Im goin with the hedman 68470s with y-pipe, 3" pipe mod of course to the y-pipe, with a dynomax super turbo all before the axle. Ill get pics hopefully in a few weeks. Lets see what you single exhaust guys have!
Old Oct 6, 2005 | 09:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
From below.
Jet Hot coated 2055's, Pacesetter cat-back with a Flow muffler (I don't think I have a pic of the muffler itself).
Attached Thumbnails Post your SINGLE exhaust pics!-exhaust-ground-clearance1.jpg
Old Oct 6, 2005 | 09:44 AM
five7kid's Avatar
Close-up of my "high flow, tubular cat".
Old Oct 6, 2005 | 03:45 PM
spills's Avatar
Car: 89 RS
Looks good man. Did you use hookers Y-pipe, or fab yp your own?
Old Oct 6, 2005 | 05:04 PM
five7kid's Avatar
It's the Hooker 2055 y-pipe.
Old Nov 6, 2005 | 08:30 PM
spills's Avatar
Car: 89 RS
Come on guys, I know there are some more of you out there! As soon as I get my super turbo mounted up, Ill posy mine. right now all I got is a $20 3" summit muffler.
Post em up!!!
Old Nov 7, 2005 | 11:07 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Hey five7kid... What size is your "High Flowing Cat" i wanted to do that just havent had time to look for a pipe to go over my 3" pipe
Old Nov 7, 2005 | 06:00 PM
five7kid's Avatar
3".
I had the I-pipe inlet & one end of the tube expanded to 3" ID.
Old Nov 9, 2005 | 06:27 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I have the hedman shorties too, havent changed the Y pipe from 2.5 to 3 yet, dont know if Ill even bother, with a "high flow tubular cat" and a 3" hooker cat back.
Sorry for lots of photos, many more at my cardomain.
Old Nov 9, 2005 | 09:03 PM
spills's Avatar
Car: 89 RS
damn, that looks nice. I hear ya on the y-pipe modding too. Im still contemplating on if I want to do true 3" or just keep it the way it is. Then again, I got a stroker so it might be better if I did.
Did you get your headers JET coated, or did u get it like that from heddman? Either way, that finish looks good.
Old Nov 10, 2005 | 05:40 AM
MattODoom's Avatar
Car: '88 G T/A
I didnt get them JET-HOT coated, im working on a high schooler budget. That is Eastwood silver manifold paint.
I was surprised, it actually lasted all summer! I really was only expecting a month or so out of it, so I could get them ceramic coated this winter. But I may just leave it.
Old Nov 10, 2005 | 01:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
heres a link to mine .. it will be true dual 3" soon
http://www.team3rdgen.com/modules.ph...view_photo.php
Old Nov 10, 2005 | 03:20 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Sorry to hijack this thread, but I had a question for five7kid. When you did have a cat on your car, how did you mate the cat to the y-pipe? Both my cat and my y-pipe have the exact same diameter, so it doesn't "slip on" like I expected it to.
My friend said I should by some kind of piping that allows both pipes to connect by fitting over each pipe, which allows it to be welded. However, it looks like the cat sticks out further than it should because of length of piping on the cat inlet (too close to the driveshaft for my comfort). Any ideas?
Old Nov 10, 2005 | 03:50 PM
MattODoom's Avatar
Car: '88 G T/A
Have either the Y pipe or your cat enlarged by a muffler shop to slip over a 3" pipe.
Old Nov 10, 2005 | 03:57 PM
Nate86's Avatar
Engine: 4 cylinder
Is that what you did?
Old Nov 10, 2005 | 04:03 PM
MattODoom's Avatar
Car: '88 G T/A
I bought a peice of 3" tubing the length of the cat and had both ends enlarged to 3" ID and slipped it in there.
Old Nov 10, 2005 | 06:19 PM
five7kid's Avatar
The inlet of the 3" universal cat slipped right over the end of the 2055 y-pipe. I put a 3" clamp on it.
Old Nov 10, 2005 | 08:33 PM
spills's Avatar
Car: 89 RS
they make a few different types of clamps. Look into either a butt joint or slip joint style clamp. One of those, I believe, is to mate and seal 2 pipes of the same diameter. If you choose to go that route.
Old Nov 11, 2005 | 06:09 PM
Nate86's Avatar
Engine: 4 cylinder
Would it be better to weld it on or just to clamp it? I'm concerned about leaks, but I might need to unbolt part of the exhaust for a bigger engine later on (trying to think ahead).
Old Nov 13, 2005 | 02:13 PM
spills's Avatar
Car: 89 RS
If your gonna be upgrading down the line, it would be best to clamp it all together. Id clamp it all together personally. Unless you have open access to a welder, but even then youd have to cut the pipe and re-weld it. Might look better clamped together with butt or slip-type clamps.
Old Nov 13, 2005 | 08:30 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
we need more pictures of some single exhaust single exit setups. I dont see many at all anywhere and was hoping this thread would get them to show themselves. I really buy that the single exhaust single exit 3" setup is optimal on < 300-350hp since it has less turns to be restrictive and better exhaust flow characteristics. I'm undecided on if any prefabbed systems are worth the money though, and i'm thinking of building my own. Unfortunately with only dual exhaust or fake dual exhaust pics, i'm not getting very far with coming up with ideas on angles and lengthts and how the finished product will look. So more pics you guys with single exhausts.
Old Nov 16, 2005 | 07:44 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I'll post mine when it's done...
SLP 30005C 1.75" Primary Headers + 3" Y-Pipe
3" Elec. Exhaust Cutout w/ 3" turndown
Catco 3" Cat
Dynomax 3" Catback with Hooker dual tips
Old Nov 16, 2005 | 09:16 PM
spills's Avatar
Car: 89 RS
that sounds like a pretty good set up. Are you using SLPs y-pipe, or fabricated?
Old Nov 16, 2005 | 11:05 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
why not have long tube headers with y pipe??? i headers are tucked under pretty well....
Old Nov 17, 2005 | 06:01 PM
jimp2001's Avatar
Engine: LO3 305 TBI
I'm using the SLP Y-Pipe... it will be all bolt-on, I just have to take the Y-pipe and cutout to a shop to have Y-Pipe cut shorter and replace it with a cutout, then I can bolt it all up at home myself
Old Nov 17, 2005 | 07:38 PM
Nate86's Avatar
Engine: 4 cylinder
Do you know how these clamps work? Which one does what you are describing and what should I ask for?
Old Nov 17, 2005 | 09:08 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
http://viewmorepics.myspace.com/inde...D62F1673621534
Old Nov 17, 2005 | 09:33 PM
spills's Avatar
Car: 89 RS
lap-joint clamp seals 2 pipes of different diameters (when you got one pipe sliding inside another)
butt-joint clamp seals 2 pipes of the same diameter
Hope this helps.
Formula- are you trying to connect those 2 pipes? That might be a bit of a challenge
Old Nov 17, 2005 | 10:56 PM
Car: 89 Formula
Old vs new
Be careful with those strap clamps there great but after putting them on and taking them off a few times they stretch out and don't work so well anymore
Old Nov 18, 2005 | 04:32 PM
Nate86's Avatar
Engine: 4 cylinder
Thanks spills, you've been a great help!
One last question: Do the Hooker 2055s come with a "slip into" pipe on the end of the y-pipe? I can't remember what they looked like before I sent them to Jet-Hot but I thought I remember the y-pipe having that sort of end but I could be wrong. Don't know why Jet-Hot would remove that, though.
Old Dec 1, 2005 | 02:46 PM
rjmcgee's Avatar
Headman shorties with the Y pipe fixxed to 3 "
Summit cut out
McCord power plate
Banks 3" stainless catback with the 4th gen mufler and tail pipes
Made 297rwhp on dyno with cutout closed and 303rwhp with it open. Pretty loud though, I wanted it a little more on the quiet side than it is.
Old Dec 1, 2005 | 02:47 PM
rjmcgee's Avatar
Cut out and I pipe
Old Dec 1, 2005 | 02:49 PM
rjmcgee's Avatar
This was taken when testing my homemade subframe connectors, but shows the exhaust.
Old Dec 1, 2005 | 05:55 PM
spills's Avatar
Car: 89 RS
looks nice dude. I didnt now Banks made a 3" system for camaros. I thought he was all about turbos and diesels.
You got any sound clips of that 4th gen muffler?
Old Dec 4, 2005 | 08:26 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
You know ground clearance is an issue with our cars, so true duals where out of the question.
Old Dec 4, 2005 | 08:28 PM
zz17iroc's Avatar
here is another
Old Dec 14, 2005 | 01:00 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Bringing this back from last week: Here are a couple of mine, single 3", aftermarket cat, with custom flange, SLP headers and Y pipe. I-pipe unknown, look familiar to anyone? Single 3" 'shotgun' pipe on driver side, Originally a Dynomax ultra-flo, but too droning at highway speeds. Changed to a single super-turbo muffler.
Old Dec 14, 2005 | 01:01 PM
jwscab's Avatar
Engine: Many
another:
jwscab's Avatar
Engine: Many
last one:
Old Dec 17, 2005 | 05:03 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I have Hedman 1 5/8 inch ceramic coated headers with 3 inch collectors. I had a muffler shop make me a Y-pipe. There are two 3 inch pipes going into one single 4 inch pipe with flowmaster muffler. I love the way it sounds, but I have only gotten to drive it once because of issues with the LT1.
Old Dec 17, 2005 | 05:05 PM
Sorry pics where taken with my camera phone. I traded for a 4 inch exhaust and it was a little rusty so I scuffed it up and painted it black. It's kinda hard to see.
Old Dec 17, 2005 | 07:25 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
I am wanting to use SLP 1 3/4 shorty headers, homemade 2.5 or 3in y pipe and 4 inch mufflex catback. I am going to have dead bird do it if I ever get the car. Anyone done anything like this?
Old Dec 18, 2005 | 08:05 PM
spills's Avatar
Car: 89 RS
all I can say about the y-pipe is dont rush! make sure the 2 pipes merge together smoothly. I havent made any y-pipes myself, but Ive seen people around my area do it. Just look at a hedman y-pipe and DONT do it like that! lol
Old Dec 18, 2005 | 08:09 PM
MattODoom's Avatar
Car: '88 G T/A
I have a hedman y pipe on my car. It is a perfectly fine Y pipe...
Old Dec 18, 2005 | 09:22 PM
Mine is temporary so I can get back to driving the car again. I haven't driven it in 4 months and I don't have the $ at the moment to buy a good Y-pipe. I knew the owner of the muffler shop so it didn't cost much.
Old Dec 19, 2005 | 11:45 AM
spills's Avatar
Car: 89 RS
I meant in the terms that it cant, straight out of the box, be made into a true 3". you have to modify it. And the fact that you hace to u-bolt the downpipe to the y-pipe right under the oil pan, which is verrry close to the point of Im woried about boiling the oil, or at least raising the oil temp very high.
Old Dec 19, 2005 | 02:41 PM
MattODoom's Avatar
Car: '88 G T/A
My YPipe was cut off right at the union and a 3" pipe was welded on. What did you need to modify? Also... I dont see why having a UBolt there verse a solid pipe would cause any more heat? Or perhaps you mean an under the oil pan y Pipe vs a y pipe that crosses after the tranny?
Old Dec 19, 2005 | 06:10 PM
spills's Avatar
Car: 89 RS
that 3" mod on mine has yet to be completed. And no, I didnt mean that the u-bolt made extra heat. Just that its a pain in the a$$ on mine to get the bolt to go between the oil pan and the pipe. And, since the pipe is so close to the pan, theres a chance of raising the oil temp higher than I would like it.
Old Dec 19, 2005 | 06:44 PM
MattODoom's Avatar
Car: '88 G T/A
I havent really worried about it too much. There is nothing major done to my motor, and the stocker YPipe was run through there anyways. Also.. the 5.7s have an oil cooler which im sure doesnt help much but hey, its there
Old Dec 19, 2005 | 09:18 PM
spills's Avatar
Car: 89 RS
Ya, damn RS's! I need to put one on my 383 with that y-pipe being there. I might just be ****, but whatever, its another project.
