LT1 rear brakes on Dana 44?
Old Oct 14, 2005 | 07:18 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I'm about to put (I hope) a set of 97-Z28 rear brakes on my '82 Camaro..I currently have a Dana 44 rear end (from the Chevy performance parts catalog, back in the 80's).
Will the 4th gen backing plates work?
Update: Well it is coming soon, I'm still working on the conversion and getting my pictures lined up...check back in a few days...
I finally found the correct parking brake cables for this conversion. NAPA #93858
Old Oct 16, 2005 | 07:40 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
Looks like I'll have to answer my own question.
Yes. The caliper brackets with the funny lopsided/out of square bolt pattern fit perfecly. Didn't need shimming, grinding or anything.
Although with the Dana 44 it is not as easy a swap as it might otherwise be. The 44 doesn't use c-clips to hold the axles in. They are held in by retainer plates bolted to the axle flanges.
So after locating and renting a slide hammer axle puller, I had to press the old bearings off of the axles. Then I could finally remove the bearing retainer plates and old caliper brackets, install the new brackets and old retainer plates and call it a day.
Now I have to locate new bearings to replace the old ones I destroyed while pressing them off.
I did mock up an axle with the new caliper bracket and everything seems to fit perfectly. At least as well as you could expect with no bearing.
Old Oct 16, 2005 | 11:49 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
I have a dana 44 rear. I am running 89+ PBR brakes on it, I may have miss read your post but you do not need to press off the bearings to change the brake brackets. The hole in the brackets is big enough for the bearing and bearing race to fit through it.
Old Oct 17, 2005 | 08:49 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
But not big enough for the bearing/seal retainer plate, which must come off before the brake bracket can.
Maybe yours was different than mine, but there was no way to get those parts off of the axle without removing the bearing. Which, BTW, is a Timken U298, just incase anyone needs to know. Bit it turns out that the local parts stores all know it as an "A9" assembly.
Old Oct 19, 2005 | 11:25 PM
anthony714's Avatar
yes,i have a dana also and upgraded to ls1 brakes and you need to remove bearing to get backing plate on,heck i even had to remove bearing to get the old early style backing plates off
Old Oct 20, 2005 | 07:40 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
Yep, that is exactly what I found.
Old Nov 9, 2005 | 07:53 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
This shows the bolt pattern on the axle flange.
Old Nov 9, 2005 | 07:55 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
These are the axle flange bolts that came on the Dana 44. Re-use these bolts. Do NOT use the bolts from the LT1 rear end axle flange, the heads are not cut and they will not fit properly.
Old Nov 9, 2005 | 07:57 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
This is the Dana 44 axle, re-assembled with the bearing retainer plate and LT1 brake bracket installed.
Old Nov 9, 2005 | 08:00 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
This is a picture of a special press rig. It is designed to press the bearings off of the axle with-out destroying them. It didn't fit right and they were destroyed anyway.
Oh well, it was worth a try. If it had been complete and was not missing the insert that would have been a perfect fit it probably would have worked as advertised.
Old Nov 9, 2005 | 08:07 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
After re-assembeling the axles and putting them in the car it was clear that the brackets placed the calipers too close to the rotor. There was not enough clearance on the inside of the rotor for the caliper cage to fit properly. It would just barely fit and scraped the rotor.
So I dis-assembled the axles again (destroying another set of bearings) and milled .075" off of the brackets The surface that needed to be milled is shown below the axle, where the two bolt holes are. If you look carefully you can see the marks-a-lot writing indicating where it was to be milled and .075.
After the milling and re-assembly, everything fit. The 4th gen hard brake lines were close enough that with a little convensing they could be made to work.
The 4th-gen parking brake cables DO NOT WORK. I ordered a set of '91 Z-28 parking brake cables. I'll post another update later telling whether or not they fit properly.
BTW, I had to cut the bolt and remove the funny weights on the bottom of the calipers in order to clear my adjustable trailing arm re-location brackets.
Old Dec 10, 2005 | 01:03 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Bump. Any more updates?
Old Dec 10, 2005 | 09:41 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
I got a set of '89-92 brake cables. I got the second version (slightly longer) and put them on. They didn't fit over the levers on the caliper so I had to file the openings a little to get them on. One side never really went on properly.
Then the unsheathed part of the cable was about 2" too long. When I tightened up the adjustment in the middle of the car (above the drive shaft) all the way there was still 2" of loose cable.
So I looked around my junk pile for something likely to use and came up with a screw down wire connector thing. It has a brass housing with a bolt in the side to tighten it down on two battery cable sized wires, one would go in from each end. I poked the brake cable through one end then put a big bolt through from the other side (so that tightening the brakes will pull the head towards the connector and, of course, the head of the bolt will not fit through). Then I loosened up the cable adjustment all the way, pulled the cable through snug and tightened up the connector thing. The connectors bolt tightened the cable up against the threads of the other bolt, making a VERY secure attachment. Reapet for other cable and tighten factory adjustment (you know the thing aboove the drive shaft). It was some pretty tight work with the drive shaft, exhaust and torque arm all in place, so I didn't get any pictures.
I know my description is not very good, but the bottom line is the later version of the third-gen cable did not fit right, they are TOO LONG, but I made it work. The first (earlier?) version of the 3rd-gen brake cables for these calipers MIGHT fit a little better.
So I now have a functional parking brake for the first time in 20 yerars! It isn't
The reast of the brake conversion is also working great. I have never had better pedal feel or more consistant braking. The spongey feeling that I had grown so acustomed to over the years is gone at last.
I am VERY happy with how this all worked out, and my total investment was less than $250.00, including parking brake cables, brake cleaner, fluid and the the other incidentals. I have not rebuilt the calipers turned the rotors or replaced the pads, I'm using everything as it was deliverd from the junk yard.
BTW, it anyone wants to know I got my brakes from HP Salvage in San Antonio, no relation just a satisfied customer.
Old Dec 12, 2005 | 12:19 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
no no no...
The caliper mounting bracket goes before the bearing retainer plate on the axle not after. So the brake bracket is between the bearing retainer plate on the axle and the housing flange. You don't press off the bearings to change the caliper mounting bracket.
I used the 89-92 Camaro 10 bolt backing plates, not the LT1 ones. The LT1 ones will probably not fit correctly because they are too thick. You can buy new 89-92 10 bolt PBR backing plates for about $20.
Old Dec 12, 2005 | 12:39 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Here are the part numbers for the thinner mounting brackets that where used on the thirdgen 10-bolt PBR setup & thirdgen Dana 44's.
Right Rear: 10136854 $11 at GM parts direct
Left Rear: 10136853 $11 at GM parts direct
Old Dec 12, 2005 | 01:49 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
YES, YES, YES!
I don't know what you're working on but
#1 there is no way to remove the old brackets without pressing off the bearings
and
#2 if the new brackets were placed between the axle flange and the retaining plate, the axle would not be able to seat properly.
Following your directions would result in a dangerous and UNSAFE situation. Maybe you have some other version of a Dana 44. Where did you get it? I got mine over the parts counter at my local Chevy dealer.
With the MINOR milling indicated the LT-1 brackets work great, they are also a LOT stronger/less flexible than the 3rd-gen brackets.
Originally posted by 89 Iroc Z
no no no...
Old Dec 12, 2005 | 01:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
That really doesn't sound right.
Old Dec 12, 2005 | 03:40 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Well on my Dana 44 if you didn't put the bracket between the axle retainer and housing flange the bearing would stick out way to far. If I were to take the axle with the bearing pressed on it and put it into the housing without the caliper bracket on the bearing would stick out about 1/4 a inch. The hole in the center of my caliper bracket was also big enough to slide the bearing through.
Here is a picture of the flange on mine.
Old Dec 12, 2005 | 03:41 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I didn't really take many pics of the rear before I put it into my car but here is a picture of the day it came off the truck before I painted it and all that.
This pic is just to show that it is infact a dana 44.
Old Dec 12, 2005 | 05:34 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Mine came from Chevy with the brakes already installed. Although it appears to be a Dana 44, yours is NOT THE SAME type of Dana 44 that I got from Chevy. I even have my old Chevy HHP catalog from 18 years ago showing a picture of it (with the rotors and calipers installed).
When I put the axle (with the bearing in place) into the houssing, the bearing seats flush with the housing. Actually, the bearing goes a little farther into the housing to make room for the seal. It is hte seal that actually sits flush with the end of the axle tube.
BTW, if your bearing protrudes from your axle, where does the seal go?
Since it was done at the factory I am confident that the parts went together in the correct order. That order being Axle, Brake bracket, Bearing retainer, seal, bearing.
The bearing retainer, being designed to retain hte berings will not come off unless the bearings are removed. The brake bracket, being behind the bearing retainer will not come off until the bearing retainer is removed.
The only way the brake bracket would come off without first removing the bearing and retainer plate would be to cut it in half.
Old Dec 12, 2005 | 05:45 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I have no idea why ours are different. The seal on yours is slightly different then mine. The seal on mine goes about 3/4 of the way into the axle housing, which is the part that has the actual seal contact area, the rest is sticking out but it is definitely designed to do that because the outside diameter is smaller on the part that sticks out and not meant to make a seal. Also if you look at the flange on my housing it has a lip / ridge / ring (not sure what to call it) where the caliper mounting bracket seats on. Yours doesn't have that. There must have been two different designs or something??
Old Dec 12, 2005 | 05:48 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I don't think there where any other manufactures then the ones that came form the GM parts direct / SLP catalog. Also I highly doubt mine was custom fabricated up since the pumpkin has the torque arm mount cast into the housing.
Old Dec 12, 2005 | 05:55 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
It looks used. I take it you were not the origional owner?
At first glance it looks a little different that mine. My guess is that it was not one of the ones that Chevy made specifically for 3rd-gen Camaro's. If I am correct, that would explain the difference.
I just read your reply above...
If you don't know the origional source of yours for a fact, we really can't come to any conclusion other than "it's different".
But this occurs to me as a possible explination.
I have HEARD (I don't know) that hte ones from SLP came WITHOUT brakes. If that is true, it would make sence to modify the design to allow for easy bracket removal/installation.
MINE came from my local Chevy dealer in 1987 or 1988. At that time there had only ever been one rear disk design, and since replacing the brake brackets requires removing the berings from the axles, it makes sence that they would come with the brackets pre-installed. With the brackets pre installed, if you wanted to put it in a drum brake car you would then have to hunt down hte remainder of the parts. Which may be why MINE came with the the complete brake system pre-installed.
Again this is all speculation, but hte later ones delivered by SLP may have been a different design to allow for the brackets to be changed more easily, so that htey would work with either type of rear disks.
Old Dec 12, 2005 | 06:02 PM
Apeiron's Avatar
Engine: 383 Carb
It has the torque arm mount, which is unique to the thirdgen Dana 44 though.
Old Dec 12, 2005 | 06:32 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I don't know where my dana 44 was initially purchased from since I bought it used a few years ago. I bought it from a SCCA racer who had two laying around. It may have been a SLP unit but I was under the impression that the dana 44 from GM was the same one SLP sold. Anyone know the history of this? In the process of looking for almost a year to find the one I bought I came across a another dana 44 rear on ebay that had the exact same flange setup as mine.
Old Dec 12, 2005 | 06:37 PM
Apeiron's Avatar
Engine: 383 Carb
SLP bought GM's old stock of Dana 44's after they were discontinued.
Old Dec 12, 2005 | 07:37 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
There still may have been more than one model. Maybe pre and post '89.
Old Dec 12, 2005 | 08:11 PM
Apeiron's Avatar
Engine: 383 Carb
Or that SLP modified them.
I've never seen reference to more than one version in the service parts listed in the GMPP catalog.
Old Dec 12, 2005 | 09:04 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Until we find someone with first hand experience and 89 Iroc Z's style of Dana 44 we may never know.
But I can tell you, with first hand authority, that the early Dana 44's had flanges like mine.
Humm... This sounds like an issue for a different thread...
Old Dec 12, 2005 | 09:08 PM
Apeiron's Avatar
Engine: 383 Carb
So does mine, as far as i can recall.
Old Dec 12, 2005 | 09:19 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
How many versions of the Dana 44 did GM make?
I started a new thread in the history/restoration board.
https://www.thirdgen.org/techbb2/sho...hreadid=335867
I'll also be linking to it from the transmission and drive train board.
Old Feb 18, 2007 | 08:20 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
I know I am reviving an old thread here, but I have some new news that someone might find helpfull. When doing my conversion I could not find anyone who knew what the correct parking brake cables would be.
Napa had two types for third gens with PBR calipers, one longer, one shorter. I origionally got the long ones and they didn't fit properly. Not only were they TOO LONG, but they had a cylinder crimped on the end that goes to the front of the car. My origional cables had ***** crimped on the end.
So I ordered the other cables from Napa, the shorter ones. I finally got around to putting them on yesterday and they fit perfectly. They have the correct ball crimped on to the end that goes to the front of the car.
Both of these sets had to have the caliper end opened up a little in order to fit over the lever on the LT1 style 4th gen rear brakes. With a small grinding bit (like you would use for porting aluminum heads) in a drill it took about 20 seconds (going slow).
To sum up, if you are putting 4th-gen LT1 style PBR brakes on to an early style Dana 44 in an '82 Camaro the correct parking brake cable is:
NAPA Part # 93858
Old Mar 6, 2007 | 06:50 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
NAPA Part # 93858
These cables are off of what year 90-92 and did you have to add an exstra bracket to where they hook to your stock front cable, or did they join right up to the existing front cable. Thanks for any info
Old Mar 6, 2007 | 07:43 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
I don't know what year they are SUPPOSED to go on, but they did fit properly with my origional front cable. My '82 origionally came with drum brakes, but I don't think that makes any difference on the front cable.
Old Mar 7, 2007 | 07:19 AM
84TranzAm's Avatar
I have an 84 Trans Am at the moment and have a moser 9 inch that arrived at the shipping facility as we speak. I have drums on the back right now. I am debating on what style of brakes to put on the rear as I want to be able to run a 15 inch slick. Clearance is an issue and i am sure LT1 will work with no problems but LS1 will not work for me is my understanding. Then the cable set up. So thanks for the info
Old May 12, 2007 | 10:01 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: LT1 rear brakes on Dana 44?
After reading this thread I was a little unsure of my own setup. It seems mine is like yours ESC, as the seal is pretty much flush with the ends of the tubes. The rubber around the axle sticks out very slightly. If I were to put the backing plate between the axel and bearing retainer there would be nothing to hold the bearing in place.
I've had this rear for close to 2 years and am only now getting to putting brakes on it. I bought it used and the last owner took the brakes and backing plates off before selling it. Looks like I have to go through the hassle of pressing the bearings on and off.. might as well get new ones.
It seems like a lot of work to bother with taking that old backing plate off.. not sure why the last owner did it.. lol would make things easier on me if he hadn't. Oh well..
Good info in this post. I need to get brake cables as well so now I know which ones to order.
Old May 12, 2007 | 04:32 PM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
I put 1989 PBRs on mine. You do not want more brake back there as in the LS1 set-up, you will get wheel hop if you ever do any hard braking. Mine was used in a race app so I know. I had to get a proportioning valve and practically dial the rear brakes out!
Old Sep 24, 2007 | 09:41 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
im putting on ls1 brakes on a dana 44 as well, but the guy whom i got if from sold the brakes off of it and i dont think i have the bearing retainer plate because the bearings just slide in and out.. where can i find a pair of these bearing retainer plates.. thanks..
Old Mar 11, 2018 | 06:18 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Further info on differences between the two different runs of Dana 44: see page 3
https://www.thirdgen.org/forums/tran...ml#post6206864
Old Mar 11, 2018 | 07:01 PM
skinny z's Avatar
I was just about to post here when I read yours.
Yes, it appears that there two distinct models of D44 for the 3rd gen. One with a flat faced axle tube flange (as described by the OP) and another with a "shoulder" that protrudes past the axle tube end (as described by 89 Iroc Z and also on my own D44). The former requires the backing plates to go on before the bearings is pressed on. The latter has the backing plate (which is really a caliper mount in this case) fitted around the shoulder. The assembled axle (retaining plate, bearing, lock ring in that order) is then installed. The bearing retaining plate bears against the caliper mount which is through bolted to the axle flange.
There are also two models of D44 listed in the Yukon Gear catalogue.
Old Mar 11, 2018 | 07:22 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
I suspect that the difference in any "gear catalog" would have more to do with the gear ratio than the design of the axle tubes. If it originally came with a 3.31 gear ratio you get one style of gear, if it came with 4.11's you get the other.
Old Mar 11, 2018 | 10:01 PM
skinny z's Avatar
I suspect that the difference in any "gear catalog" would have more to do with the gear ratio than the design of the axle tubes..
When I can, I'll dig a little deeper into the Yukon catalogue. It seems there's a part listing for each of the iterations. I don't recall seeing any reference to any particular year when I was sourcing wheel bearings and seals but I did come across more than one PN from any given manufacturer.
I recall some Dana 44's used a "Set 10" wheel bearing. I ended up with an SKF BR9 VP. Not sure how that translates.
Old Mar 11, 2018 | 10:32 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
It has been a long time, but ...
As I recall, there were different carriers for the 3X:1 gears vs the 4X:1 gears. So depending on what your axle originally came with , there will be some internal differences.
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
