powdercoating intake
Old Nov 2, 2005 | 05:50 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
Hey any one heard of powdercoating their airgap intakes? Was worried about heat, my guy says he bakes at a higher temp than operating temp, will it last?
Old Nov 2, 2005 | 05:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It should hold up pretty well I think. The intake manifold doesn't get anywhere near as hot when the engine is running as it will get being baked. The powdercoating process bakes the parts at something like 500*F, which is much hotter than it will ever get from engine heat alone.
Old Nov 3, 2005 | 01:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use an intake manifold gasket that will block off the exhaust crossover. Even though the Air Gap doesn't have the passages, having the flange exposed to the port could still allow excessive heat to the coating.
Old Nov 3, 2005 | 04:49 PM
w1964bgta's Avatar
Thanks alot five 7 I would not have thought about that
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
