MSD 6a
Old Dec 8, 2005 | 12:17 PM
devilfish's Avatar
MSD 6a
Hello
To install a MSD 6A on a camaro -88, is this all you need to do?..
First the MSD 6A ( of course )
Then this wiring setup from MSD.
Old Dec 8, 2005 | 12:18 PM
devilfish's Avatar
and then connect it like this..
Old Dec 8, 2005 | 12:32 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
if you use the plug in harness, you don't do the install like mentioned above, you just plug everything in.
Here is a link to the instructions for a 6-series ignition.. Instructions
Old Dec 8, 2005 | 01:54 PM
devilfish's Avatar
THanks for the answer.
I did read the manual, but my english is bad so I just need to clear som things out
Did I get this right?
Original there is 2 connectors on the coil. If I use the plug in harness there is only one connection going to the coil, right?
The other orginal coil connector is instead going to the MDS?
Thanks.
Old Dec 8, 2005 | 05:19 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
CORRECT PLUG
goes right on
both existing coil connectors go to harness
then one to coil
fits only one way
i have the msd coil too
and a spare one, since i sold my truck
was gonna use it on my jeep if i connect my msd box to it
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
