I think this is a tranny problem?
Old Jan 30, 2006 | 07:18 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
I was racing last night and i have a 700R and i was fine 1st and 2nd gear and when i hit 3rd gear the car started spuddering and it acted terrible and bogged almost down but 1st and 2nd were strong. I also thought it could be a timing issue were the timing is off and 1st and 2nd are fine becuase there small gears but 3rd is a long gear so if the timing is off then the car couild do this right?
Old Jan 30, 2006 | 08:37 AM
No it is not the timing.
Not the EGR either.
Let's get past the "noob" blame-everything-on-timing stuff, and apply some logic.
It's fuel delivery.
I'm guessing this is a carb conversion, fuel pump still in the tank?
Old Jan 30, 2006 | 09:36 PM
its been a carb but its a junk edelbrock 650 carb and its junk that could be it i guess
Old Jan 30, 2006 | 10:35 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
is it a new or use carb cuz sometimes they are good out of the box and somtimes they need to be jetted down or up. personal experience is that holley's need more work out of the box then edelbrocks
Old Jan 31, 2006 | 06:46 AM
its an old edelbrock carb and its been junk and i cleaned it up and its still junk
Old Jan 31, 2006 | 07:17 AM
No, it's not "jetting" either.
No, it's not because the carb is "junk".
There might be other problems or imperfections that could be attributed to those things; but they are not the cause of the issue at hand.
It's because the fuel system can't keep up with the rate that the engine drains the fuel from the carb. What happens is, while it's idling or cruising (conditions with relatively low fuel demand), the carb's fuel bowl gets kept full, without too much trouble, by the fuel system; when you punch it in fist, and the engine's fuel demand goes up by a factor of 10 or more, the bowl starts to drain down, as the fuel demand exceeds the fuel supply; all through 1st and 2nd the fuel level in the bowl is getting lower and lower; then about the time you hit third, there's no more fuel there, and the engine starts sputtering and coughing and falls flat on its face, and otherwise acts like it's running out of gas. Because, IT IS.
Leave the carb alone, leave the timing alone, go to the root of the problem, which is, INADEQUATE FUEL DELIVERY.
Until the fuel delivery problem is fixed, NOTHING ELSE will EVER fix this. You could buy youself a $1000 totally worked-up carb from a shop that builds them for professional racers, and your car will STILL fall on its face about the time it hits 3rd gear, if you don't fix the actual problem at hand.
Back to the original question, since we're kind of on a roll with wild guesses here, is the original (electric) fuel pump still in the tank, and you're using a block-mounted mechanical pump to draw through the electric?
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
