t56 speedometer
Old Jan 29, 2006 | 06:39 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
t56 speedometer
im doing a t56 swap into my 85 camaro and was curious what i have to do to make the speedometer work properly. i know you can buy a autometer speedometer and hook it up but i was curious if i could just by a used electric speedometer from a 3rd gen and make it work with the t56 properly?
Old Jan 29, 2006 | 07:41 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
you have to use a digital dakota SGI-5a box to convert the signal
Old Jan 29, 2006 | 07:42 PM
n8sz28's Avatar
Car: 85 camaro z28
but i can use the stock 3rd gen electric speedometer with the swap as long as i have the dakota digital?
Old Jan 29, 2006 | 07:44 PM
Engine: 383
yup
Old Jan 30, 2006 | 06:14 AM
Your Camaro has a cable, not electronic, speedo.
The box will not work for you.
Here's the solution you need. http://www.jagsthatrun.com/Pages/Par...ilHousing.html Unfortunately, it's not cheap. Or even very inexpensive either.
Old Jan 30, 2006 | 09:29 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
there are new tail housings now. there is also a signal box that will run a motor specifically for the cable too
Old Jan 30, 2006 | 09:45 AM
The Cable-X box costs about the same as the right housing; and just adds another layer of something to break. I see no benefit there. Others might, but I don't. Less stuff to go bad strikes me as a virtue.
I'd be interested in seeing the facts and details about this supposed other extension housing. I just got through doing this conversion in a cable speedo car about a year and a half ago, so I know what was out there at the time; but if someone has come out with something new, I'd like to know about it.
Old Jan 30, 2006 | 06:45 PM
n8sz28's Avatar
Car: 85 camaro z28
when do third gen become electronic speedometers?
and how hard is it to switch from cable to electric?
Old Jan 30, 2006 | 06:54 PM
The Firebirds switched in 85, and the Camaros switched in about 89 or 90.
It is not trivial to switch over, since the ECM runs the speedo in the electronic version.
Old Jan 30, 2006 | 11:19 PM
n8sz28's Avatar
Car: 85 camaro z28
will someone please briefly explain what this means "It is not trivial to switch over, since the ECM runs the speedo in the electronic version."
thank you i just got a little lost and want to make sure i understand it properly.
Old Jan 30, 2006 | 11:21 PM
Engine: ls1, LB9
here do a quick search t56 speedo housing it will show several options souch as the home job http://www.jagsthatrun.com/Pages/Par...pp6-3_6-4.html
and the carcraft one that lists just one of the makers of cast housings just for the cable speedo cars
they are out there just look
http://www.carcraft.com/howto/1061/index4.html
this last one has the shifter moved (which could be nice too) but, they make them with only the sensor hole moved too
Old Jan 30, 2006 | 11:26 PM
Engine: ls1, LB9
well I won't say what I am thinking but.........
no it is an easy swap. ecm control? with the later systems yes. MAF cars and TBI cars used a buffer box which split the speed signal to the cluster,ecm and cruise control.
if I were you I would get the dakota box, an electric speedo cluster and just wire it up
Old Jan 30, 2006 | 11:58 PM
n8sz28's Avatar
Car: 85 camaro z28
so should i not use a electric speedometer from a later 3rd gen year?
Old Jan 31, 2006 | 07:22 AM
From the Car Craft article:
Rockland sells the housing, along with new shift rails, a shifter, a speedo drive gear, snap-rings, and seals for $685
Wow.... and I though the JTR thing was slightly $$$$$, at about HALF that..... too bad, because that's the PERFECT solution for our cars.
Incidentally, there is only one company that "makes" those, althought there might be numerous ones that SELL (distribute) them. That one maker is Tremec, who now owns the Borg-Warner name for manual transmissions.
As far as the electronic speedo thing, it wouldn't be too hard to try; just buy yourself a later-model cluster and buffer box and the Dakota box, and wire it up, and see. You wouldn't really even have to "install" it in the car until you got it to work.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
