LG4 or other?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
LG4 or other?
The engine in my car has always been a mystery since day 1 (previous owner, long story) , so now that I pulled off the 416 heads to put on to a 350, I got to see the pistons.
I thought that an LG4 has dished pistons, hence the 8.5:1CR, and the L69 had flat tops, hence the 9.5:1 or whatever.
These sure look like flat top pistons:
pic1
pic2
does this look like an LG4, L69, or other? When I pull the motor, i'll check casting #'s on the block, but that won't be for a while....
Any thoughts?
pic1
pic2
Any thoughts?
Transmission: 4L80E/4L80E
From https://www.thirdgen.org/techbb2/sho...hreadid=261488
"The '82-'84 3rd gen LG4's had lower compression because they had dished pistons in them, which, when combined with the 58cc chamber 416 heads, produced 8.5:1 compression ratio. The L69's and '85-'86 LG4's & LB9's had flat top pistons with 4 valve reliefs that, when combined with the 58cc chamber 416 heads, produced 9.5:1 compression ratio. '87-up used a slight dish piston with 4 valve reliefs that reduced compression to 9.3:1."
Car: 1983 G20 Chevy
Looks like the LE9 van engine that came in my 1983, except trucks/vans/SUVs came with the 601 heads and a 350 truck cam.
That means that it was over 9.5:1? Flattops w/4 valve reliefs, 52 CC chambers, steel shim head gasket?
Car: 1982 Trans-Am
ok, so five7, you think this may be an L69, since it has flat tops?
Anyone know which casting # would be for an LG4, and which would be L69?
I figure once I pull the motor out, if it's an LG4, i'll probably drop it off at the wreckers to recycle for me, but if it's an L69, I *might* be able to sell it, due to it's popularity... oooh, 305 HO!
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
My 86 LG4 had flattops when i took it apart, Sonix. I think only the early lg4's had the dished pistons.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Even if it was an L69, I wouldn't count on anyone paying anything for it.
Car: 1982 Trans-Am
Well this ought to be fun bringing to the auto recycler.... I hope they can just take it off my hands, and I don't have to pay a fee to get rid of it.... Moderator
Engine: 383 Carb
If you don't want it, you could just stick an ad in the Bargain Finder and give it away for free to whoever will come and take it away.
85ws6TA
Jun 27, 2001 12:25 PM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
