Good way to hide nitrous?
Old Nov 16, 2001 | 09:39 AM
brian89transam's Avatar
Has anyone found a good way to hide nitrous? If i get it i'll be using a TB plate kit. I I don't see how you could hide the plate without a lot of "customizing," but you could hide the bottle. Where do you guys put yours? Is there a way to make it look stock? Just wondering, thanks guys.
Old Nov 16, 2001 | 10:11 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You can paint or polish the plate to match the rest of the intake. As far as lines go... try running them under the plenum or close to wires so you can put some wire loom over them and no one will be the wiser. As far as hiding the solenoids, i think they fit under the plenum, i am not sure. Covering them with a stock looking cover would be an easy method... the sky is the limit.
Old Nov 16, 2001 | 10:33 AM
BahamutRS's Avatar
It's not too hard...but once they see the bottle, it's all over
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Old Nov 16, 2001 | 02:16 PM
SoCo80p's Avatar
if you just use wire looms and just to have everything crammed under some wires or other crap then it can be somewhat hidden and the average hot rodder wont notice, but the real street racers and others can see a NOS kit in a second
Old Nov 16, 2001 | 02:49 PM
chevyboy07 91's Avatar
thats easy...check out the links hehehehehe 175 shot and nobody knows nuthin http://photos.yahoo.com/bc/chevyboy07_91/vwp?.dir=/&.src=ph&.dnm=i-6.jpg&.view=t&.done=http%3a//photos.yahoo.com/bc/chevyboy07_91/lst%3f%26.dir=/%26.src=ph%26.view=t
http://photos.yahoo.com/bc/chevyboy0...c=ph%26.view=t
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Nov 16, 2001 | 05:29 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Here's my future plans(as of now at least):
Hook up the N02. Make it look neat but don't even try to hide it.
Put your bottle with a remote opener where the spare tire/jack go.
Get another bottle and mount it in the rear trunk well or on top behind the rear seats. Run a nice steel braided line from this "dummy" bottle to and under the plastic interior panel. Make it long and tight enough that if someone tugs it it will seemed hooked up.
Then, it goes like this. "Ok, we'll go motor to motor" and you unhook the bottle while everyone watches. Get in the car, open the REAL bottle with the remote opener and you're done.
Old Nov 16, 2001 | 07:01 PM
johnsjj2's Avatar
Car: 1991 Z-28
A fogger system can be hidden under the intake in the lifter valley, with the nozzles going into the runner from underneith the intake. A plate system can be hidden, with some creative line bending, under a carb heat shield. Solenoids and all. I've seen some where the a plate system was used, and the lines ran with a wire loom over them back to the firewall. Inside the heater box was the solenoids. This made the initial hit a lot softer, and helped not blow the tires off, like the "hidden under the shield idea" might have.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Nov 16, 2001 | 10:35 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
<font face="Verdana, Arial" size="2">Originally posted by ryn28:
</font>
Awesome, I like the way you think.
89 IROC-SuperRammed 355 w/ AFR 190's and LPE 219/219 cam-http://www.geocities.com/buckeyeroc
Old Nov 17, 2001 | 02:35 AM
89ProchargedROC's Avatar
you want the ultimate hidden n20 system do ya?
i did one once
PITA but i was paid good
---was a dry kit, i hid the solenoids in the ac/heater box
ran the n2o line through one of the a/c lines up to a non stock condenser
drilled through the condenser to route the n2o line over the radiator and under the MAF
this is a street raced car and has been on the street for over a year and no one has known
bottle is hidden in trunk and since the n2o line is sooo long it hits soft and you cant really notice it
Old Nov 17, 2001 | 10:55 AM
JucinGTA's Avatar
</font>
Dude you must be kidding me, You think that wont be found. I have the ultimate hiddin kit for a firebird that I will never reveal, involved a differnt fuel line and everything, I have only givin it to one member on this board that lives far away from me. If you want to be an Avid Street racer you will have to brainstorm more then that, you are gettin there just make it better. They didnt call me Shady for nothin
Old Nov 17, 2001 | 07:47 PM
ryn28's Avatar
Engine: Chevy ZZ4
No one would see the second bottle. Anyone who's been around for awhile will want you to disconnect the solenoids up front anyway. There are plenty of people who aren't wouldn't suspect. Besides, to win you need to do alot more then hide your N02 on the street but I won't go into tactics.
Old Nov 18, 2001 | 12:03 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Wow, Alex, that's a really neat and clean install; is it yours? Did you do the work or a professional shop? Cost? *G*
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
