SUPERCHAGER FOR TBI????
Old Dec 13, 2001 | 01:49 PM
OC305RS's Avatar
DOES ANYONE MAKE A S/C FOR A TBI MOTOR..AND CAN NOS BE TIMED IN WITH IT????
Old Dec 13, 2001 | 02:01 PM
Dan W's Avatar
I dont know if anyone makes a kit... I visited a local shop recently that was just finishing up a custom vortec install on a 350 TBI motor. The shop is RMCR in colorado springs. If you call, dont expect the cost to be as low as a manufacturers kit.
Old Dec 14, 2001 | 02:53 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Vortech has kits for GM TBI Trucks:
http://www.vortechsuperchargers.com/.../appguide.html
This is an installation manual for a 5.7 Truck. Here you can read about the modifications needed for the TBI:
http://www.vortechsuperchargers.com/...s/4gb218im.pdf
Perhaps you can buy a mix of parts from an F-Body kit and the Trick kit ...
Jonas Bylund
Old Dec 24, 2001 | 09:47 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I believe that if you were to talk to procharger and get the intercooled kit for a tpi car and get the assorted pieces used on a TBI truck you could complete a TBI kit for a camaro or firebird. I feel very strongly about this because I have installed both tpi and TBI truck kits for customers. dont even get started if you are not willing to discuss the fact that there is currently no CARB (emmis legal kit yet available). I would suggest collecting info and pictures of truck and tpi installs and discussing it with a state of california employee called an "emissions referee" he is the guy you will end up at if you go to a regular smog shop and the smog tech says, "what is all this stuff, here is your referal to the state referee."
Old Jan 5, 2002 | 10:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here is a crappy pic of the truck sys installed:
File Type: bmp
Old Jan 6, 2002 | 12:20 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
greg320
Sep 8, 2008 03:01 PM
Robby42164
Apr 18, 2006 03:28 AM
chevy8ford
Sep 22, 2003 09:09 AM
JucinGTA
Aug 30, 2002 04:14 PM
