Stk TPI Fuel Pump --->
Old Sep 14, 2000 | 06:56 PM
Brent's Avatar
How many gal/hr is it rated at?
Old Sep 14, 2000 | 08:43 PM
Mark 89Formula's Avatar
The 305 pump is 24 gal/hr @ 50 psi. The 350 pump is 28 gal/hr @ 50 psi.
Old Sep 15, 2000 | 10:18 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
the 305s and 350s had different pumps!?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 15, 2000 | 11:30 PM
Yep, they do according to Fuel Injection Specialties. The Delco part # for the 305 pump is EP-241 and the 350 pump is EP-242.
Old Sep 16, 2000 | 12:26 AM
Blade's Avatar
Learn somethin new everyday!...
Old Sep 16, 2000 | 09:40 AM
Kevin G's Avatar
damn, I had no idea either.. Good information!!!
Old Sep 23, 2000 | 10:01 PM
gravitar's Avatar
damn, didn't know that either! is it the same for all years?
This is dumb to ask, but, if you go from 305 to 350, how important is it to get the 350 pump?
Old Sep 24, 2000 | 02:53 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
TPI 350 pump is the same as the TTA pump! Figured that one out when I replaced my pump, I asked for the TTA pump, ended up being the same damn thing! Pablo was there I think ... hehe ...
Old Sep 24, 2000 | 04:07 PM
Many people successfully swap more powerful engines into 305 cars w/o a problem so it certainly can be done. I'd make sure ANY pump holds pressure during a full throttle run via a gauge or by monitoring oxygen sensor output.
If you're looking to upgrade, the Walbro 255 lph pump is a great choice. When my stock pump was dying I replaced it with a Delco EP-381 rated at 41 GPH (155 lph) @ 50 psi. I'm told this pump was used in the GMC Syclone/Typhoon but I don't know that for a fact. Cost $88 from Fuel Injection Specialties a few years ago.
Old Sep 25, 2000 | 06:26 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Hey Mark I think your part #s may be off. I just went to my GM dealer here in Germany and there computers show that the 305 TPI and the 350 TPI having the same EP-241 pump (for a 92 at least). When I asked about a 91 L98 Corvette he gave me EP-245 part no. How much do these usually cost? My dealer told me $137.00.
I did replace my 305 with a 350 and Im replacing my fuel sender anyways, so Id like to replace the pump while Im at it.
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Old Sep 25, 2000 | 08:52 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Randy,
Don't waste your money on a stock pump. You can buy a Walbro 255ltr/hr pump that looks stock and fits in the stock location perfectly. This pump will support 550hp ... and its cheaper than a GM pump. Do a search on the internet.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Sep 25, 2000 | 07:48 PM
blowen90ta's Avatar
check this place out just got my 255lph walbro pump from them 108 delivered,couldent get the stock one for that. http://members.home.com/syclone/APE/fuelpump.html
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Sep 25, 2000 | 08:13 PM
Randy, the part #s I listed came from Fuel Injection Specialties (they sell both) and are the best info I have. I have no way of knowing what the service books for the different years x-reference as a substitute.
You are a wise man to replace the pump while the tank is down. My stock pump was slowly dying @ 65K miles. Do yourself a favor and get the Walbro pump like the guys recommend.
Old Sep 26, 2000 | 01:11 AM
Randy92Z's Avatar
Engine: Miniram 383
Thanks fellas, thats what Ill do.
Old Oct 13, 2000 | 10:04 PM
Sinful One RS's Avatar
TRAXION,
I have a question for you...actually 2.
I have a stock 305 TBI and I'm going to be putting a TPI in and was wondering if I need to change the fuel pump at all? For right now I'm just going to put the TPI on the 305, but later it will be put on a built 350 and I know I need to change the pump then. I just wanted to make sure I could just hook up the fuel lines as is now with putting a TPI on the 305.
Plus, you are close to me (if you're in Frederick, MD) and I was wondering if there are any speed shops around? I'm closer to BWI airport, but still, I'm willing to travel for good prices on parts.
Thanks again...
Sinful One RS
91 Camaro RS w/305 TBI
3.23 posi w/disc brakes
145 speedo
Z-28 Fog Lights & grille
Sinful One RS's Domain
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
