What grease should I use on poly and rubber bushings? castrol spf any good?
Old Aug 2, 2001 | 07:56 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
The castrol is suppose to be fully or half sintheic (sp) it is the purple stuff any buddy ever use it?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Aug 2, 2001 | 08:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Don't know about the rubber, but urethane doesn't like hydrocarbon-based grease, regardless of whether its natural or synthetic.
Old Aug 2, 2001 | 09:11 PM
BLACK Z's Avatar
Car: 86 Z28
What is hydro carbon greas?
Old Aug 2, 2001 | 10:38 PM
Apeiron's Avatar
Engine: 383 Carb
Petroleum-based.
Old Aug 3, 2001 | 08:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Argh, and I was planning on using my regular chassis lube (Valvoline Synpower, 100% synthetic) on the sway bar bushings I'm doing this weekend! Why doesn't polyurethane like synthetic (or dinosaur) grease? I thought the poly was impervious to everything... road salt, trans fluid, tar, other car fluids, etc? Why is grease different than oil? I really don't want to buy another air-powered grease gun just to hold silicone grease...
Old Aug 4, 2001 | 01:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Back to the top... anyone know why?
Old Aug 4, 2001 | 04:30 AM
Apeiron's Avatar
Engine: 383 Carb
Who knows, maybe its BS, but all I've ever heard is if you use anything other than silicone on poly bushings, it'll eat them.
Old Aug 4, 2001 | 06:58 PM
CamaroZ_85's Avatar
energy suspension recommends the following grease for their poly bushings: Sta-Lube Multi-Purpose Marine Grease. SL3120 is the p/n for the regular grease gun tube. hope this helps
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Aug 5, 2001 | 03:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I see Pep Boys carries a 3-pak of "mini" grease cartridges called "Marine Grease".. I wonder if it's the same stuff. The back of the package said it was colored blue, and didn't mention anything about a silicone base. I'd still rather use synthetic grease, though...
Does ES just recommend the marine grease (silicone) because it's less likely to wash away? Maybe it's not an issue with greasable bushings, but for the normal bushings, it is?
I remember when I put on my Energy Suspension torque arm bushing; that little packet of grease was annoying- I couldn't get the stuff off my hands. At last check, the bushing's still greasy; synthetic probably would've washed away by now. So.... does that make that theory of "silicone's less likely to wash away" sound good? See what I mean?
The greasable rear bushings (by ES) that I just bought have an instruction sheet; they don't mention anything about the type of grease to use. The sheet basically says to pre-pack the grease channels (in the poly bushing) with grease, and then to grease the bushing via the zerk fitting after installation. It doesn't say anything about which grease to use.
[This message has been edited by TomP (edited August 05, 2001).]
Old Aug 7, 2001 | 10:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
back to top...
Old Aug 7, 2001 | 01:05 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
Steve Spohhn has the grease you need in the big cartridge. I just received my order the other day. Here is the info from his web site:
Polyurethane Bushing & Chassis Grease
Price:$14.00
Item #902
This is the good stuff!
Polyurethane bushing manufacturers advise to never use a petroleum based grease for poly bushing lubrication. Polyurethane should only be lubricated with one specific type of grease to insure a long bushing life, and squeak-free performance. Silicone based synthetic water-proof grease, the white sticky stuff!
We've found this grease to be so good, we use it for the entire chassis lubrication on the cars we build and race out of our shop. It stays where you put it, it doesn't wash away.
Don't pay the other guys $9.95 for a little foil pack of this stuff. It's a low volume use grease, and thus most local stores do not carry it. We special order it in large quantities, and can pass the savings on to you, our customers.
From Spohn Performance you get a full-size grease gun cartridge of the good stuff for $14.00.
Get 'em sticky!
1990 RS Camaro 305 TBI
700R4 Tranny
3" cat back system with flowmaster mufler
Edelbrock strut brace tower and rear panhard bar
Spohn subframe conectors and lower control arms
all polyurithene bushing under the car
March underdrive pully
K&N filter
Hypertech chip
Aluminum driveshaft
3.42 posi rearend
Killer sound system
Many new mods to come
Old Aug 7, 2001 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, but like I said, I really don't want to pick up another pneumatic grease gun (don't want to go back to a manual-op one) just to hold a silicone grease cartridge.. I guess I'll run with my normal Valvoline synthetic, and if the bushing starts to erode, I'll move to the silicone grease. If I'm going to be greasing these bushings regularly, it doesn't matter to me if the grease washes away..! I don't see it washing away, anyway; the bushing seals pretty tightly against the stabilizer bar.
Old Aug 7, 2001 | 09:36 PM
BLACK Z's Avatar
Car: 86 Z28
CAn the sillicon stuff be used on rubber bushings? This is what energy suspension said,Yes, You'll need a teflon base grease. Or any waterproof grease will do.
performanse suspension had this to say,> Thanks for taking the time to check out our website. In regards to your
> e-mail you can use any kind of grease or a Teflon based grease. If you
have
> any questions please let us know. Not sure about the rubber bushings.
> Thanks
> Sonny
spohn had this to sayUse synthetic silicone grease (marine grease) only on poly, and it
works great on rubber as well.
We sell it on our website.
Old Aug 8, 2001 | 09:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks, BlackZ, for digging that info up! I feel better about using the synthetic now. I suppose eventually, when I rebuild my front suspension with poly, I'll load my gun with the silicone- but I'm not near that step yet.
Thanks again!
Old Aug 12, 2001 | 12:09 PM
BLACK Z's Avatar
Car: 86 Z28
When I say bushings you guys know I mean the tie rod ends ball joints and rear lower control arms and things like that.
Old Sep 19, 2001 | 08:24 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Apr 28, 2002 | 09:47 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
so what's the verdict is marine grease ok for poly?
Old Apr 29, 2002 | 10:06 AM
grafx's Avatar
Car: 91 Camaro RS
Transmission: Pro-Built Automatic/Vigilante 2800
Just go with the Energy Suspension grease. This is what I used when installing mine. Comes in a little container or depending on what size you order, and just applies with your finger. This stuff is awsome, real sticky and doesn't wash away, will stay put for a long time. Also contains teflon to help keep them from sqeeking. Better to go with a good grease such as the ES stuff so that you don't have to service the sqeeking bushings as much. Especially when it comes to the front control arms, because the only way to service them is to remove them and everyone knows what a bi*ch that is.
Old Apr 29, 2002 | 10:29 AM
BLACK Z's Avatar
Car: 86 Z28
What I meant meant buy grease is the kind you use at every oil change on the grease fittings, not when you first install the bushings.
Old Apr 29, 2002 | 10:40 AM
Car: '87 Camaro LT
Engine: 355 L98
so if i use marine grease on my poly sway bar bushings, i cant use it on anything else? ball joints and the like...
Old Apr 29, 2002 | 12:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I figure when I move over to a full poly front end, I'll buy another grease gun to hold the marine grease. But for now, with the only poly bushings on my car being the end links and the sway bar mounts, I'll stick with the synthetic gun.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 5, 2015 07:57 PM
