targa top part 2
Car: 1991 Corvette Coupe
targa top part 2
why dont we talk to GT Auto Accessories and see if they will make us a one piece (or two piece if storage is a problem) top that we can either put over the t-bar with the rib removed or just if we want, cut out the t-bar and have a true targa
i think subframe connectors will work just fine
that would be so cool, wouldnt it???
who's with me on this?
Car: 1990 Camaro RS
the only thing i would worry about if we cut the t-bar, will the windshield support itself correctly when traveling at any speed???
i sure would not want to be driving along, showing off my new targa top, and get on the freeway, boom, the windsheild buckles in on me.
<font face="Verdana, Arial" size="2">Originally posted by Dewey316:
i sure would not want to be driving along, showing off my new targa top, and get on the freeway, boom, the windsheild buckles in on me.</font>
i could be wrong but by judging on how small and light the T bar is.......i would say that it wouldnt really make a difference...i could be wrong, but i would gladly pay for a true targa top
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
<font face="Verdana, Arial" size="2">Originally posted by 1991tealRSt-topGuy:
(or two piece if storage is a problem) top that we can either put over the t-bar with the rib removed </font>
I'm sure it's been seen more than once but here....
http://www.angelcities.com/members/gtaz/others/crx5.jpg
That's my old CRX, they are much more flimsy around the windshield area than a 3rd gen and I had no problems up the whopping, *****-out 87mph the car would get to (regardless of the 120 speedo).
The problem would be even less of a worry with the top on.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited December 04, 2001).]
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I don't believe that the windshield pillars on convertables are reinforced to any extent, so I seriously doubt that would be a problem. The car caving in on itself, now that could be a problem.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Take a car with ttops and drive over a speedbump diagonally, or up a driveway diagonally and listen to the creaks and noises, and watch the hood and notice that you can see more of it as the car flexes, then rethink whether you want to make it even more flimsy than it already is.
<font face="Verdana, Arial" size="2">Originally posted by Drew:
Take a car with ttops and drive over a speedbump diagonally, or up a driveway diagonally and listen to the creaks and noises, and watch the hood and notice that you can see more of it as the car flexes, then rethink whether you want to make it even more flimsy than it already is. </font>
is there any sort of device i can get to join
temporaraly join my t-tops together if i cut my t-bar out and put on SFC's?
lets put it that way
Car: 1990 Camaro RS
With SFC's the flex isn't an issue, i can park my car on a driveway, and it will hold one wheel off the groud, with the tops off. and if the convertables don't have ANY extra re-enforcement for the windsheild pillars, i don't see that it would be any harder than cutting, and getting a peice made to go across the top, and connect to the existing T-top connecting points, and that is sturdy enough to to bend from the forces of the wind over the car at speeds.
Hi I am new to the forum but I think that I remember seeing a true Targa roof on a Z-28 on an old TV show, Riptide. It was red and I swear that it didn't have the t-bar in the middle. I could be wrong though. If someone gets that show in reruns they should watch it to see of I'm right.
Car: C1500
It was "Simom and Simon"
1992 Trans Am
May 10, 2023 07:19 PM
