Guide on doing the 2.8/3.1 to 3.4 swap
Old Feb 10, 2002 | 11:25 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I tried to get the thread address, but the post seems to have been deleted. I'm glad I saved this to my hard drive. This is a guide on doing the swap written by KED85. Long but informative, enjoy:
The 2.8-3.4 Swap Boogie by Karl Dresing
This is for all that want to do the 3.4 swap boogie.
IF you want every detail, well, some may be missing.
Why?
I used a 1985 engine platform.
Your project may be different.
What I did, was keep this goal in mind.
I recreated exactly what I took out.
It allowed my computer, wiring, etc to be assured to function, properly.
It has.
I have heard variations, too.
One guy used the 3.4 oil pan and already on the timing chain cover & matching water pump 3.4.
Another "hole" was made, for mounting some bracketry.
His platform was a 1989.
Again, this is my tips for my package, a 1985 Firebird, starting with a 2.8 Multi Port Fuel Injection.
I will not go into removing engines.
I will give tips.
DO NOT disturb your throttle body settings or cables. My tranny shifted perfect and the car, idled well. So I only removed it off the intake and shoved it aside. You can do this and not break wires, cables etc.
AC Compressor- Even tho, I had no AC charge, I only removed it from the bracketry and shoved it aside.
Alternator- same idea, move it to the side.
NOW, Start labeling the OBVIOUS items.
In my instance, I'm stupid.
I marked the Fuel Injector harness (my way, you can mark yours your way. I use Front passenger side, Front driver side, Middle ,etc...).
Same idea with spark plug wiring. I did not remove wires from dist. cap. Why should I, no need. I'm being lazy, less to re-hook up.
Then start unbolting, wires, hoses, etc.
Again, the obvious.
If you can get away without touching the hose, wire, bolt, LEAVE IT!!
Eventually, the engine will be ready to remove.
The fun part is the tranny bolts. They are (my instance) 15mm and NO WORKING ROOM AT ALL.
But..
Some tranny bolts, you can only slide back, not remove. The firewall is in the way.
Oh, why not!
How else I cheated.
I disconnnected the torque convertor from the flex plate, left it attached to the tranny. NO TRUE NEED TO REMOVE MOVE IT!
Exhaust was easy, difficult. Recall Tom's fun? So was mine. Those bolts have gone thru a heating cycle, many times over. Be prepared for fun, there.
But, it can be removed, without destroying what you need to keep in mind, the pipes and manifolds separate.
Then after, you feel you have removed, labeled everything. Stop. Go have lunch, dinner. Come back again, later. Look at where you are.
Examine.
Is this labeled, so I can reinstall, easy? Is this outta the way?
Opps, this got broken, better make a note and make sure to get this part, now.
Again, obvious, easy solutions. It's all in the details.
Get ready.
Remove the engine. Lots of fun, excitment, cursing, worry.
GO SLOW, OBSERVE, GO SLOW, OBSERVE.
Have help, too!
To aid my job, I removed the hood. I removed the hood at the fenders, not the hood. No adjustment, needed to reinstall. I'm lazy.
If you're gonna climb into the bay, to help engine out, be careful.
Get it out, now and put it on a tire or leave in the air.
Start removing the old motor mounts, old oil filter housing, old balancer, old oil pan, old starter, old timing chain cover, old distributor.
That should do the block.
Start cleaning. I used a paint brush & kerosene. Then a rag with brake cleaner on it. I cleaned gasket surface. Then I cleaned surface again. I put it aside. I layed engine, pretty stripped now, onto the tire. It's a dead engine, you cannot hurt it. Then started with the top end. I have a three piece intake system. Yours may/may not. Again, every version will be different/same. I put all parts from the 2.8, cleaned, ready for installing, aside.
Oh, I forgot the vacuum hoses are fragile. But, you already discovered that, didn't you!
Let's start wiht the other block, the 3.4.
How I ordered it. I asked for the intake system attached, Ex. manifolds attached, oil pan attached, 3.4 balancer & flex plate, plug wires attached, I forgot to ask for the extra starter, drat!
You do not need the 3.4 ignition system. You cannot use it!
Get the 3.4 up in the air. Strip the oil pan, filter housing, timing chain cover, flex plate, etc.
Now, start attaching the old 2.8 stuff onto the 3.4 block.
USING A NEW TIMING CHAIN & NEW WATER PUMP (chains are about $30-ish, pump was $19).
AGAIN, YOU ARE RECREATING THE OLD 2.8 BLOCK, JUST USING THE 3.4 BLOCK, NOW TO PUT BACK ON THE "OTHER 2.8" STUFF!!
Keep this goal in mind.
IT ALL FITS, WORKS!
DO NOT TOUCH THE 3.4 EXHAUST MANIFOLDS, LEAVE THEM ALONE!!
This is easy, detailed. Start at one end, side, complete it with the parts, move on. You have 3 sides to work on, drivers, bottom, passenger sides.
THEN go to the front! The timing chain cover, the chain, the balancer.
Yea, there are exact details how to reinsatll. That's what the shop manulas are for. USE IT! They do have some helpful tips. AGAIN USE YOUR RESOURCES.
We are done with the short block. Lets' go up top.
On the 3.4 block, I really ran into ONLY ONE PROBLEM! The block at the back of the passenger side cylinder head, where (for me) the electric fan switch sensor went into the head. Tha block, is a 5/16' size plug.
HOW I DID IT.
I almost abandoned the project!
I went to the hardware store and got a 5/16 steel stud rod item. Paid about $1.50. my friend took out his torch (REAL, NOT THE TOY ONES) and heated it. Out it came. I slipped pipe sealant onto the threads (but, that's obvious, anytime you put a bolt, into a water passage, ISN'T IT!!), inserted new sensor (destroyed old one removing-remember I said, observe, be careful, I wasted $22 for that!). Done.
Driver side, had no problems.
NOW the intake, etc.
YOU NEED TO SWAP THE 3.4 INJECTORS ONTO THE 2.8 FUEL RAIL. How? I used a screwdrive to assist to remove the clips. BUT in the process, I got dirt inside the fuel rail. Guess what, I cleaned and cleaned and cleaned and cleaned. INSIDE TOO! I mean sparkle! Then used a oily substance (that won't break down that rubber seal) and slipped on the 3.4 injectors.
Done. I also swapped fuel pressure regulators, even tho they are identical. WHY. The 3.4 one was newer, & newer rubber seals.
Intakes.
I removed the push rods.
THIS IS YOUR CALL.
I put on the new gaskets, cleaned all areas, real through, layed on the RTV black into the corners, pushed it in, worked it into the crevices. Let it cure for a few moments. Layed down intake. That was done. Valve adjustment.
Had a real hard time.
Eventually set the valves by a compression tester. We needed it. Any extra little twist generated no cylinder compression.
We set the valves in the engine bay using the starter to turn over the engine. I ended up with 175-200 compression, each cylinder.
THEN lay down the valve covers, middle and upper intake. Try to do it a different way and you cannot!
Distributor. There is a block in the back of the block to remove. It's a "short oil gear drive off the cam, for the oil pump". That's what that does. Swap in your old distrbutor.
Now you're ready to go.
Hook up exhaust manifolds, start engine, time, drive away, happy.
IS it this simple, yes.
Again, keep the goal in mind, recreate exactly what you started with. That's the easiest way to go.
What I bought.
A COMPLETE ENGINE GASKET KIT FOR THE OLD OLD OLD OLD ENGINE. Not the new 3.4.
I also got a rear main seal.
I also got new hoses (dealer item!) for the bypass area up in the front.
New timing chain.
New water pump.
I USED A SMLAL BLCOK CHEVY DISTRIBUTOR GASKET FOR THE DISTRIBUTOR, not that hookey rubber joke of a ring thing!
NEW EXHAUST MANIFOLD DOUGHNUTS. The RIGHT ONES! Not the hookey generic ones!
I SPENT ONE WHOLE DAY ON VACUUM HOSES AND SEALING ANY LEAKS! Everytime I touched those plastic things, it broke,. I used 5/16" windshield hose to band aid, patch, you name it! I even used electrical tape (to take up slack, looseness), at that fitting at the back, by the distributor, because the 1/2" hose was to large, 3/8" was to small.
But, I am running at 20-22 inches of vacuum at idle, in gear idle is 15-17 inches of vacuum. THAT'S INCREDIBLE!
I have no oil leaks.
I have no water leaks (my bypass metal hose cracked, got it fixed for $5). I use no oil, I use some water.
I think I've given ya a good foundation to understand what is necessary to do this swap.
NOW...I've done two swaps before I did this (I'm 44). Both worked, but, not great!
This one, is perfect!
I took my time, I rushed, I observed, I checked, I asked, I cheated, I double checked, I WAS ****!
I now let my Wife take the car with my Son as a passenger.
You need time, space, common sense, knowledge and friends to pull this off. And a good garage close by, for questions, special fluids, etc.
Also this place. I asked lots of questions, I printed out 8 pages of notes from 3-4 different forums, I had both engines side by side, LOOKED AT MY NOTES! and then I went to work.
Did I leave out some details, Sure I did, Reno.
I don't know every detail of your vehicle. BUT, I layed out the general guidelines for the swap. Again, it's all there, you need the patience to do this job. When you get the 3.4 block, look at it, become familar with it, before you rip apart your old block or even take it outta the car.
Again, observe, look, check, double check, etc.
Oh, did I remove radiator?
Why? It's not in the way.
How did I hold up tranny, Floor jack and a stick, cause two bolts hung out to support the tranny.
Before you ask any questions, consider this.
Until you have the engines out, or even the 3.4 in your posession, you cannot really understand what the simple solution may really be.
I gave guide lines.
I'm not there to help ya, but, I'm here to answer questions.
Maybe not exactly the timely answer, but, that's good. You are thinking outside of the box.
Be careful, these things can hurt and kill ya if you are stupid. Check everything before you start removing and keep stupid friends clear out of harms way. Who needs their aggrivation, when you are on a mission!
After I did my swap, I had a few teething pains (like my 7 month old!).
I used the computer reader tool to answer my questions (I had a bad mass air flow sensor). I used extra time to reseal or wrap an extra hot air source (the EGR valve stuff).
That's pretty much about it.
I now need to swap in guage panel (what I haven't sone that yet, oh well, I check fluids OFTEN!!).
OH, ONE FINAL WORD, CHECK ALL ALL ALL ALL WATER HOSE CONNECTIONS, EVEN ONES YOU DID NOT TOUCH!
This swap is so worth it.
IF ya gotta rebuild something, do it now. Distributor, rebuild it! Don't even think of just slapping it back in, as it was. Get new electronics under there.
Best thing about rebuilding stuff now, with the old block, it'll put off having to swap blocks, as you'll discover a smoother running more powerful 2.8/3.1 engine.
Oh, can you bore this or that to make a 3.4?
Be my guest.
For $800 I got it all, warrantied for 30-60 days. I sold the left over 3.4 stuff for $105. I didn't waste time trying to create what I could buy, complete for so little pocket change! Compared to machining costs etc.
Until you get both engines, just print this out. And read it. And get a shop manual and look for your answer. You may gain more knowledge in the process.
When you get the chance to do this swap, you'll see the answer, too! You really do need the engines side by side to see all the differences and similarities.
Another reason why I did this swap was to fool the smog police. He thinks I have the original 2.8 in there! I'd have to pay an extra $300 for asmog recertification sticker to get a smog test. NOPE! I pay for smog test & go goodbye!
Have a pleasant time!
And a wonderful Easter holiday. Count your blessings! I do and I am, every mornign with my Wife and Son.
I'll be porting and polishing my other cylinder heads for my small block Chevy's and maybe swapping a motorcycle engine for the third time (remember I told you I wasn't successful on a swap!! This was it!).
Old Feb 11, 2002 | 01:47 PM
Damon's Avatar
That's good stuff. I'm sure many people would consider a 3.4 swap if it was easy and their old 2.8 was worn out. Swapping in a V8 in place of the 6 is much more expensive and really not for the novice. Most give up and sell the car before they ever get it finished and running right.
However, let's see if I can break this down to the "Reader's Digest" level...............
Start with what you have to take off your old 2.8 to put onto the new motor:
1. Intake (remove old injectors to make room for the 3.4's)
2. Oil pan
3. Timing cover
4. Distributor
5. etc...
Then with what you take off the 3.4 (BTW- which 3.4 did you start with? One from a 4th gen Camaro? I assume it's gotta be the RWD version of the V6 block):
1. Pan
2. Timing cover
3. Timing Chain
4. Intake
5. Injectors
6. etc.
Maybe you could fill in the blanks like that so somebody could do a parts list check before they start the project.
BTW- my brother shoehorned a 3.4L quad cam motor in place of his Fiero's original 2.8. That swap was NOT easy! But the thing rips like no Fiero has a right to.
Old Mar 4, 2002 | 10:15 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
so is the swap the same if going from a 3.1 to the 3.4,
Do you keep all the same things you would keep of the 2.8 off the 3.1, and what if i just wanted to pay somebody to do it because i dont have the time to do it, i have found a 3.4 for 450$ and it seems about right
Old Mar 5, 2002 | 03:09 AM
Snowdog 91 Formula's Avatar
I'd like to as well.
Yeah this is one thing I am considering too for my wife's bird. It's 2.8 is dead as a doorknob. I really want to replace her motor with a new one. Just don't know what to do at the moment.
Cameeeero
Sep 18, 2015 04:00 PM
hydrolic144
Sep 8, 2015 06:55 PM
camaro71633
Sep 1, 2015 10:24 AM
BrianI
Aug 9, 2015 11:52 AM
92projectcamaro
Aug 6, 2015 01:20 PM
