Diy Afpr
Old Mar 21, 2002 | 05:17 PM
DM91RS's Avatar
Car: 91 RS
Diy Afpr
I have not read the tech article on doing the afpr lately but someone reminded me on another thread that you have to remove the reg pod to adjust the pressure the way it's done in the tech article. I don't think that's an eazy way to tune so heres what I did;
Old Mar 21, 2002 | 05:28 PM
DM91RS's Avatar
Car: 91 RS
I didn't say I was a photographer so please forgive the pic quality.
1. You just drill the weld out of the hole with a "Q" size drill bit or a 11/32" bit if you don't have or can't get any letter size bits.
2. Tap the hole out to 3/8-24 thread size.
3. Next remove the screw from the spring cup and disgard it.
They should look like this now
Old Mar 21, 2002 | 05:34 PM
DM91RS's Avatar
Car: 91 RS
You will need a 3/8-24 hex head bolt around 2-1/4" long. Screw the bolt in the reg housing and it should look like this.
Old Mar 21, 2002 | 05:37 PM
DM91RS's Avatar
Car: 91 RS
Reassemble and check for proper movement
Old Mar 21, 2002 | 05:40 PM
DM91RS's Avatar
Car: 91 RS
Next clearance the casting to clear the bolt using a grinder or a file
Old Mar 21, 2002 | 05:44 PM
DM91RS's Avatar
Car: 91 RS
Put it all back together and use a 9/16 wrench to adjust. It's a little tight and I cut down an old wrench to be very short. If you have small fingers you might be able to turn it with them. LOL
Old Mar 21, 2002 | 06:28 PM
racereno's Avatar
Car: 91 Camaro RS
Axle/Gears: Stock
Now THATS learnin' boys. DM91RS you're tops on this mod. Thanks a million!
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
